4172701XX-3
4172701XX-3
    DIGITALVIEW
    CONTROLLER BOARD HLR-1920
4172701XX-3 数据手册
PRODUCT REVISION RECORD Part Number: DATE VERSION 4172701XX-3 Model: HLR-1920 SUMMARY OF CHANGES NOTE Conformal Coating Required 8 October 2015 20-3 Production release harsh environment version of ALR-1920 With reference to standard ALR-1920, 417270023-3 - Add conformal coating - Change ECAP to Tantalum Cap - Change ICs whatever the industrial grade is available - Change crystal to high temperature grade - Change Fuse to non-resettable type ECN# 870689530 Bare PCB: 017270002-3; P/N 417270120-3 BIOS: U10, V1.25.00 (Flash PCT25VF040)(same as 417270023-3) U13, V0.40 (ARGB DDC, 24C02) (same as 417270023-3) U12, V0.30 (HDMI DDC, 24C02) (same as 417270023-3) U20, V0.30 (Display Port DDC, 24C02) (same as 417270023-3) 2 June 2016 20-3 to 21-3 Release new firmware for HLR-1920 1. Fixed the accuracy of backlight level in PWM and D/A mode. (It was found that the backlight level is not linear to the percentage of the level and different ranges for different PWM frequency or in D/A mode, also the system backlight level control function was replaced by own method) 2. Add a RS-232 Backlight Status Query command - 0xe1 "S" or 0xe1 "s". ECN# 870689580 Bare PCB: 017270002-3; P/N 417270121-3 BIOS: U10, V1.28.00 (Flash PCT25VF040)(changed) U13, V0.40 (ARGB DDC, 24C02)(no change) U12, V0.30 (HDMI DDC, 24C02)(no change ) U20, V0.30 (Display Port DDC, 24C02)(no change) 16 February 2017 21-3 (Version remain unchanged) Update BOM Only - Change the VGA connector to black color (running change) - Change the jumper instruction tape to label. ECN# 870689631 Bare PCB: 017270002-3; P/N 417270121-3 BIOS: U10, V1.28.00 (Flash PCT25VF040)(no change) U13, V0.40 (ARGB DDC, 24C02)(no change) U12, V0.30 (HDMI DDC, 24C02)(no change ) U20, V0.30 (Display Port DDC, 24C02)(no change) 21 April 2017 21-3 to 22-3 Release new firmware V1.30.00 on U10 (1) Support “Resolution default by EDID” for different resolution panel. The controller will set the preferred timing based off the dip switch setting selection, but also be able to go higher to 1920x1200. For example, if the panel is a 1024x768 and the dip switch setting are set for 1024x768. The preferred EDID resolution should be 1024x768. It should also have the capability to set the max resolution to 1920x1200. Remark: This function supports on HDMI and Display port only (2) Bug fixed on overflow the RS-232 command Bare PCB: 017270002-3; P/N 417270122-3 BIOS: U10, V1.30.00 (Flash PCT25VF040)(changed) U13, V0.40 (ARGB DDC, 24C02)(no change) U12, V0.40 (HDMI DDC, 24C02) (changed, 1920x1200, CS= 45,48) U20, V0.40 (Display Port DDC, 24C02) (changed, 1920x1200, CS= 45,48) Page 1 of 2 ECN# 870689642 PRODUCT REVISION RECORD Prepared by: DV-HK Page 2 of 2 Date: 21 April 2017
4172701XX-3 价格&库存
很抱歉,暂时无法提供与“4172701XX-3”相匹配的价格&库存,您可以联系我们找货
