4173003XX-3
4173003XX-3
    DIGITALVIEW
    CONTROLLER HDMI HEADER HDD-1920
4173003XX-3 数据手册
HARSH ENVIRONMENT HDMI INTERFACE CONTROLLER FOR TFT PANEL Model: HDD-1920 Part number: 4173003XX-3 INSTRUCTIONS CONTENTS Page: 2. Introduction, How to Proceed, Usage Note, Disclaimer 3. System design – Diagram of a suggested system 4. Assembly notes – Important information about system elements 6. Connection & Operation – How to use the controller 10. Connectors, pinouts & jumpers – Essential connection information 18. Controller dimensions 19. Application notes 21. Troubleshooting 22. Specifications 23. Appendix I – Mode Support Table 24. Appendix II – RS-232 control protocols 28. Appendix III – Appendix III – DDC/CI support at HDMI port 29. Appendix IV - Mapping definition 31. Appendix V – DV remote control unit work for HDD-1920 32. Warranty, Caution & Limitation of Liability, Trademarks 33. Contact details It is essential that these instructions are read and understood before connecting or powering up this controller. Page 1 of 30 Introduction Harsh Environment version of the HDD-1920. Provides full DD-1920 feature set, plus wide range operating temperature and voltage range; shock and vibration tolerance and conformal coating for extreme environment applications     TFT (active matrix) LCDs with LVDS interface of 1920x1200, 1920x1080, 1920x480, 1680x1050, 1600x1200, 1400x1050, 1366x768, 1280x1024, 1280x800, 1280x768, 1024x768, 800x600, 800x480, 640x480, 480x640 resolution Support HDMI 1.3 input up to 1080p/WUXGA input resolution Low mass tantalum capacitors for maximum vibration and shock tolerance, conformal coating, operating temperature range from 40oC to +80oC plus calculated MTBF in excess of 100K hours. Overall suitability for usage in critical applications must be independently tested and verified by the user. Ordering information : Controller HDD-1920 Part number P/N 4173003XX-3 Ordering part number P/N 4173003XX-3 HOW TO PROCEED  Ensure you have all parts & that they are correct, refer to:  Connection diagram (separate document for each panel)  Connector reference (in following section)  Assembly notes  Check controller switch & jumper settings (errors may damage the panel)  Prepare the PC  Connect the parts  Understand the operation and functions (in following section) IMPORTANT USAGE NOTE This product is for use by system developers and integrators, the manufacturer accepts no liability for damage or injury caused by the use of this product. It is the responsibility of the developer, integrators or other user of this product to:  Ensure that all necessary and appropriate safety measures are taken.  Obtain suitable regulatory approvals as may be required.  Check power settings to all component parts before connection.  Understand the operation and connectivity requirements of this controller. DISCLAIMER There is no implied or expressed warranty regarding this material. Page 2 of 32 SYSTEM DESIGN A typical LCD based display system utilising this controller is likely to comprise the following: HDD-1920 Summary: 1. LCD panel 2. LCD controller card, HDD-1920 3. LVDS cable (for connection with LVDS panel) 4. Inverter for LCD backlight (if not built into LCD) 5. Inverter cable 6. Function controls 7. Function controls cable 8. Status LED (Optional) 9. IR sensor (Optional) 10. RS-232 control interface 11. HDMI signal source 12. Audio output (Stereo) 13. SPDIF audio output 14. Power input (12VDC) Digital View offers a range of accessories such as listed above, to make up complete display solution. Page 3 of 30 ASSEMBLY NOTES This controller is designed for monitor and custom display projects using 1920 x 1200, 1920 x 1080, 1920 x 480, 1680x1050, 1600x1200, 1400x1050, 1440x900, 1366x768, 1280x1024, 1280x800, 1280x768, 1024x768, 1024x600, 800x600, 800x480, 640x480, 480x640 resolution TFT panels with a VGA, SVGA, XGA, SXGA, UXGA, WUXGA signal input. The following provides some guidelines for installation and preparation of a finished display solution. Preparation: Before proceeding it is important to familiarize yourself with the parts making up the system and the various connectors, mounting holes and general layout of the controller. As much as possible connectors have been labeled. Guides to connectors and mounting holes are shown in the following relevant sections. 1. LCD Panel: This controller is designed for typical LVDS interface TFT panels with panel voltage 3.3V or 5V or 12V LVDS interface. Due to the variation between manufacturers of signal timing and other panel characteristics factory setup and confirmation should be obtained before connecting to a panel. (NOTE: Check panel power jumper settings before connection) 2. Controller card: Handle the controller card with care as static charge may damage electronic components. 3. LVDS signal cable : In order to provide a clean signal it is recommended that LVDS signal cables are no longer than 46cm (18 inches). If loose wire cabling is utilized these can be made into a harness with cable ties. Care should be taken when placing the cables to avoid signal interference. Additionally it may be necessary in some systems to add ferrite cores to the cables to minimize signal noise. 4. Inverter: This will be required for the backlight of an LCD, some LCD panels have an inverter built in. As panels may have 1 or more backlight tubes and the power requirements for different panel models backlights may vary it is important to match the inverter in order to obtain optimum performance. See page 15 for the Application notes “Inverter connection section for more informations. 5. Inverter Cables: Different inverter models require different cables and different pin assignment. Make sure correct cable pin out to match the inverter. Using wrong cable pin out may damage the inverter. 6. OSD switch mount controls: The following section discusses the controls required and the section on connectors provides the detail. The controls are minimal: On/Off, Backlight Brightness (depends on inverter), OSD (5 momentary buttons) analog VR type or (8 momentary buttons) digital type. 7. OSD switch mount controls cable: The cables to the function switches should be of suitable quality and length so that impedance does not affect performance. Generally lengths up to 1 metre (3 feet) should be acceptable. 8. Controller status LED (Optional) : This LED indicates the controller status. The pin direction of the LED should be corrected for right colour indication. Red colour stands for standby. Green colours stands for signal on. The status LED is an optional part only, can be unconnected. Controller LED status (LED1) : State No signal & backlight off No signal & backlight on With signal & backlight on 9. LED color RED ORANGE GREEN IR sensor: It is an optional part only, can be unconnected if not using IR remote control. See Appendix V for button definition. 10. RS-232 control interface : Firmware upgrade and serial control via this interface port. 11. HDMI input : Support HDMI 1.3 input up to 1080p/WUXGA resolution. Plug the HDMI cable to the connector J1 on the controller board. 12. Audio output (Stereo) from HDMI : This port support Stereo audio output (no amplification) from the HDMI audio source inputted. It requires to select the audio port “Speakers” via OSD menu under “Sound” > “Output” OSD menu page. 13. SPDIF Audio output : This port support SPDIF audio output from the HDMI audio source inputted. It requires to select the audio port “SPDIF” via OSD menu under “Sound” > “Output” OSD menu page. 14. Power Input: 12VDC is required, this should be a regulated supply. Although the controller provides power regulation for the LCD power this does not relate to the power supplied to the backlight inverter. If an unregulated power supply is provided to an inverter any fluctuations in power may affect operation, performance and lifetime of the inverter and or backlight tubes.  Power Safety: Note that although only 12VDC is supplied as „power-in‟ a backlight inverter for panel backlighting produces significantly higher voltages (the inverter does not connect to the ground plane). We strongly advise appropriate insulation for all circuitry.  EMI: Shielding will be required for passing certain regulatory emissions tests. Also the choice of external Controller to PC signal cable can affect the result.  Ground: The various PCB mounting holes are connected to the ground plane.  Servicing: The board is not user serviceable or repairable. Warranty does not cover user error in connecting up to the controller and is invalidated by unauthorized modification or repairs. Page 4 of 32  Controller Mounting: It is recommended that a clearance of at least 10mm is provided above and 5mm below the controller when mounted. Additionally consideration should be given to:  Electrical insulation.  Grounding.  EMI shielding.  Cable management. Note: It is important to keep panel signal cables apart from the inverter & backlight cables to prevent signal interference.  Heat & Ventilation: Heat generated from other sources, for example the backlight of a very high brightness panel may generate significant heat which could adversely affect the controller.  Other issues that may affect safety or performance. IMPORTANT: Please read the Application Notes section for more information. Page 5 of 30 CONNECTION & OPERATION CAUTION: Never connect or disconnect parts of the display system when the system is powered up as this may cause serious damage. CONNECTION Connection and usage is quite straight forward (it is useful to have the relevant connection diagram available at this time): LCD panel & Inverter: Connect the inverter (if it is not built-in the panel) to the CCFT lead connector of the LCD panel. LVDS type panels: Plug the LVDS signal cable direct to J3. Insert the panel end of the cable to the LCD panel connector. Inverter & Controller: Plug the inverter cable to CNB1 and CNA1 (if necessary). Plug another end to the connector on the inverter. Function switch & Controller: Plug the OSD switch mount cable to CNC1 on the controller board and another end to the OSD switch mount. LED 1 : Plug in a 3-way with dual colour LED to connector LED1 on the controller board for indicating the controller status. IR & Controller: Plug in a 3-way with IR sensor to connector IR1 on the controller board. Jumpers : Check all jumpers are set correctly. Details referring the connection diagram. Jumpers & Inverter & Panel voltage: Particularly pay attention to the settings of JA3, JB1, JB2, JB3. JB2 & JB3 are used for inverter control (read inverter specification and information on the jumper table to define the correct settings). JA3 is used for panel voltage input (read panel specification and information on the jumper table to define the correct settings). HDMI cable : Plug the HDMI cable to the connector J1 on the controller board. SPDIF audio connector : audio output ports CN11 supports audio SPDIF audio output from HDMI audio source inputted. It requires to select the audio port “SPDIF” via OSD menu under “Sound” > “Output” OSD menu page. Audio output (Stereo) from HDMI : audio output port CN1 supports Stereo audio output (no amplification) from the HDMI audio source inputted. It requires to select the audio port “Speakers” via OSD menu under “Sound” > “Output” OSD menu page. Power supply & Controller: Plug the DC 12V power in to the connector PP2. You can consider to use DigitalView mating power cable P/N 426013800-3, 160mm. Power on: Switch on the controller board and panel by using the OSD switch mount. CAUTION: Never connect or disconnect parts of the display system when the system is powered up as this may cause serious damage. Controller LED status (LED1) : State No signal & backlight off No signal & backlight on With signal & backlight on LED color RED ORANGE GREEN General:  If you are using supplied cables & accessories, ensure they are correct for the model of panel and controller.  If you are making your own cables & connectors refer carefully to both the panel & inverter specifications and the section in this manual, “Connectors, Pinouts & Jumpers” to ensure the correct pin to pin wiring. OPERATION Once the system has been connected and switched on there are a number of functions available to adjust the display image as summarized in the following sections. The settings chosen will be saved for each mode independently. Page 6 of 32 LCD DISPLAY SYSTEM SETTINGS NOTE: By way of explanation the following refers to a set of sample buttons that may be obtained as an option. In addition to power on/off and connection for backlight brightness the controller provides an On Screen Display of certain functions which are controlled by 5 momentary type buttons (analog VR type) or 8 momentary type buttons (digital type): Controls On/Off – turns controller board power on Brightness – controls backlight brightness Menu – turns OSD menu On or Off (it will auto time off) (Function with signal input only) Select – Select function / Confirm (under OSD menu on state) Move up to select individual RGB color level OSD page (under OSD menu on state) + – increase the setting / moves the selector to the next function (under OSD menu on state) - - decrease the setting / moves the selector to the previous function (under OSD menu on state) Reset to Factory Defaults Switch to next input source (under OSD menu off state) Analog VR type VR toggle switch Rotary VR Menu button Digital type On/Off button Brightness +/- buttons Menu button SEL DN SEL DN SEL UP SEL UP + + - - Press and hold SEL DN button, then power on the controller + Press and hold SEL DN button, then power on the controller SEL UP - + Menu ON/Off/Brightness SEL DN Analog VR type Digital type Page 7 of 30 + OSD Functions Image Brightness Increase/decrease brightness level. Press – or + (- Contrast Increase/decrease contrast level. Press – or + (Increase/decrease sharpness level. Press – or + (- Sharpness Color + ) Total : 100 steps + ) Total : 100 steps + ) Total : 8 steps Color temp (Adjust the warmness of the image displayed. The higher temperature the coolest image looks like. The lower temperature the warmest image looks like.) 4200k 5000k 6500k 7500k 9300k User  R Press – or + (+ ) Total : 100 steps G Press – or + (+ ) Total : 100 steps B Press – or + (+ ) Total : 100 steps Reset Gamma (0.4/0.6/1.0/1.6/2.2) Display Backlight** Invert B/L Invert : Invert for the backlight brightness Control D/A / PWM : Selection for voltage level dimming control / PWM dimming control Frequency Backlight frequency 100 ~ 440Hz in a step of 20 B/L Backlight brightness adjustment Sound Mute Mute Output Select audio output port Speakers : via CN1 & J1 connector SPDIF : via CN11 connector System Timer : OSD Timeout in seconds 3 sec 6 sec 12 sec Always On Rotation : OSD menu rotation in degree 0 90 180 270 Position : Adjust OSD menu position Transparency : Set OSD transparency Press – or + (Reset : Load factory default settings. Press down on OSD keypad to factory reset + ) Total : 100 steps [Firmware version : V1.04.00 or up] Page 8 of 32 Remark : ** - Only effective on V1.04.00 or up version. Items marked  have sub menus. Exit the OSD menu to save the setting chosen Page 9 of 30 CONNECTORS, PINOUTS & JUMPERS The various connectors are: HDD-1920 Summary: Connectors Ref Purpose CN1 Audio output (Stereo) from HDMI CN8 Serial control CN11 SPDIF Audio Output CNA1 Auxiliary power output CNB1 Backlight inverter CNC1 OSD controls IR1 LED1 J1 J3 PP2 Infra-Red sensor connector Dual color LED connector for controller status HDMI signal input LVDS panel signal Power input Description JST 4-way, S4B-ZR-SM4A (Mating type : ZHR-4) (Matching connection cable P/N 426685400-3) Molex 53261-0671, 6 ways 1.25mm pitch (Mating type : Molex 51021-0600) (Matching connection cable P/N 426171800-3) JST 2-way, S2B-ZR-SM4A (Mating type : ZHR-2) (Matching connection cable P/N 426007400-3) JST 4-way, S4B-XH-A (Mating type : XHP-4) (Matching cable P/N 426040200-3) JST 5-way, S5B-XH-A (Mating type : XHP-5) (Matching cable P/N 426058300-3) Hirose DF13A-12P-1.25H (Mating type : DF13-12S-1.25C) (Matching OSD switch mount cable P/N 426122200-3 (150mm) or P/N 426122210-3 (250mm) Molex 53261-0371, 3 way 1.25mm pitch (Mating type : 51021-0300) (Matching connection cable P/N 426031500-3) JST 3-way, S3B-ZR-SM4A (Mating type : ZHR-3) (Matching connection cable P/N 426031400-3) JST SM20B-SRDS (Matching type : JST SHDR-20V-S-B) (Matching connection cable connected to RM-DN5(VF ASSEMBLY) P/N 4171803xx-3 version : P/N 426008100-3) (Matching connection cable for HDMI(Type A) connector : P/N 426006600-3) JAE FI-RE51S-HF (Mating type : JAE FI-RE51HL) Molex 43650-0200 compatible (Mating type : Molex 43645-0200 compatible) (Matching power cable : P/N 426013800-3, 160mm) Page 10 of 32 Summary: Jumpers setting Ref Purpose JA1 On board +5V logic power enable JA3 Panel power voltage select JB1 Backlight brightness voltage range JB2 Backlight inverter on/off control – signal level JB3 Backlight inverter on/off control – polarity JB5 Backlight control type selection JP1 Reserved JP6 Input power control SW1 SW2 Panel selection Panel selection Table 1 : Panel voltage setting table : Input voltage via PP2 Panel Voltage 12VDC JA3 3.3V 3-4 closed 5V 1-2 closed 12V OPEN Note 1-3 & 2-4 closed, factory set, do not remove See panel voltage setting table 1 CAUTION: Incorrect setting will cause panel damage 1-2 closed = 3.3V max 2-3 closed = 5V max 1-2 = On/Off control signal „High‟ = +12V 2-3 = On/Off control signal „High‟ = +5V Open = On/Off control signal „High‟ = Open collector CAUTION: Incorrect setting can damage inverter. 1-2 = control signal „high‟ = CCFT ON 2-3 = control signal „low‟ = CCFT ON 1-2 = VR/Digital switch mount control 3-4 = Analog backlight brightness control via RS-232 command (0xe0) – voltage range 0~5V 5-6 = Reserved Reserved for internal programming use (Always 1-2 closed) Short = External switch control Open = Switch mount control See table below See table below Jumper on board CAUTION: Incorrect setting can damage panel & controller Page 11 of 30 ! JA3 DIP Switch selection – SW2 Pos #1 Pos #2 Pos #3 Pos.#4 OFF OFF OFF OFF ON OFF OFF OFF OFF ON OFF OFF ON OFF OFF OFF ON ON OFF ON OFF OFF OFF OFF OFF OFF ON OFF ON OFF OFF ON OFF ON ON ON ON ON OFF ON OFF OFF OFF OFF ON ON OFF ON OFF OFF ON ON ON OFF OFF ON OFF OFF ON ON OFF ON ON ON OFF OFF ON OFF ON ON ON ON OFF ON OFF ON ON OFF ON OFF ON ON ON ON ON ON ON ON OFF OFF ON OFF ON OFF ON OFF ON ON ON ON OFF OFF OFF OFF ON OFF ON ON OFF OFF ON OFF OFF OFF ON ON Description For WUXGA panel Samsung LTM220CS01 AU Optronics B170UW02 V0 AU Optronics M215HW01 Samsung LTM230HT01 Samsung LTI400HA01(1) For UXGA panel NEC NL160120BC27-14 For WXGA panel Samsung LTA260W2-L01 Samsung LTA460WS-L03 Sharp LQ315T3LZ24 / AU Optronics M156XW01 V0 LG LC420W02-A4 NEC NL12880BC20-02D NEC NL12876BC26-21 AU Optronics M220EW01 For SXGA panels NEC NL128102BC29-01B Fujitsu FLC48SXC8V Sharp LQ181E1LW31 Samsung LTM170ET01 AU Optronics M190EG01 For XGA panel AUO M150XN07 V2 LG LM151X2 Sharp LQ150X1LGB1 Sharp LQ150X1LGN2A NEC NL10276BC12-02 NEC NL10276BC13-01C NEC NL10276BC30-18/ 30-18C NEC NL10276BC20-08 For SVGA panel PrimeView PD104SL5H2 Sharp LQ121S1DG11 Sharp LQ104S1DG21 Sharp LQ121S1DG41 Toshiba LTM12C289 Sharp LQ084S3DG01 Sharp LQ121S1LG41 NEC NL8060BC21-02 Sharp LQ104S1DG21 PrimeView PD104SL5 NEC NL8060BH18-02(1) For WVGA panel Page 12 of 32 Panel resolution 1920x1200 1920x1200 1920x1080 1920x1080 1920x1080 1600x1200 1366x768 1366x768 1366x768 1366x768 1280x800 1280x768 1680x1050 1280x1024 1280x1024 1280x1024 1280x1024 1280x1024 1024x768 1024x768 1024x768 1024x768 1024x768 1024x768 1024x768 1024x768 800x600 800x600 800x600 800x600 800x600 800x600 800x600 800x600 800x600 800x600 800x600 ON ON OFF OFF ON OFF OFF ON NEC NL8048BC19-02 Sharp LQ070Y3LG4A Others ON OFF OFF ON Samsung LTI430LA01(1) ON ON ON OFF AU Optronics M200RW01 V1 ON OFF OFF OFF Sharp LQ150F1LH22 ON ON OFF OFF Samsung LTM190M2-L31 ON OFF ON OFF LG LM171WX3-TLA1 OFF ON ON OFF LG LM171WX3 OFF OFF ON OFF CPT CLAA102NA0ACW For additional and recent added panels, please contact us to support. (1) Only effective on V1.04.00 or up version. Page 13 of 30 800x480 800x480 1920x480 1600x900 1400x1050 1440x900 1440x900 1440x900 1024x600 Pos #5 OFF ON OFF ON OFF ON OFF ON Pos #6 OFF OFF ON ON OFF OFF ON ON Pos #7 OFF OFF OFF OFF ON ON ON ON Description WUXGA UXGA SXGA WXGA XGA SVGA VGA / WVGA Others SW1 Pos 8 = Reserved. DIP switch selection – SW1 Pos. # Function 1 Panel pixel format 2 LVDS data mapping select 3 4 Reserved Operating mode selection** Description OFF : Double Pixel ON : Single Pixel ON : Mapping A (LVDS panel) OFF : Mapping B (LVDS panel) Please adjust to get the correct picture. See as Appendix III for details of mapping A and B. Reserved OFF : General application ON : Work with RM-DN5 (firmware version E1.12.10a) from HDMI port# ** - Only effective on V1.04.00 or up version. Remark : # Assign SW1 position 4 to ON for connection to RM-DN5 (Firmware version : E1.12.10a) from HDMI port with the following changes : - Add “Loading…” message on screen while startup and stay until the valid signal. - Changed the default Auto Source Seek to Off - Changed the IR key from "Display" key to "OSD Next" key for menu function - Extend longer delay time approx. (4 secs) to detect signal for "No Signal" state - Only HDMI input and disabled all other "Source" selections in OSD, IR hotkeys & RS-232 for RM-DN5 mode Page 14 of 32 CN1 – Audio output (Stereo) from HDMI : JST 4-way, S4B-ZR-SM4A PIN 1 2 3 4 (Mating type : ZHR-4) DESCRIPTION Audio Left channel (Negative) Audio Left channel (Positive) Audio Right channel (Negative) Audio Right (Positive) SYMBOL AMP LAMP L+ AMP RAMP R+ CN8 – RS-232 serial control: Molex 53261-0671, 6 ways 1.25mm pitch PIN SYMBOL 1 SDATA 2 SCLK 3 VCC 4 TXD 5 GND 6 RXD CN11 – SPDIF Audio Output JST 2-way, S2B-ZR-SM4A PIN SYMBOL 1 SPDIF_OUT 2 GND CNA1 - Auxiliary power output: JST S4B-XH-A PIN SYMBOL 1 AUX POWER 2 GND 3 GND 4 AUX 5V CNB1 – Backlight inverter connector: JST S5B-XH-A PIN SYMBOL 1 GND 2 VBKL 3 BLCTRL 4 BVR_WIP 5 BVR_A (Matching type : Molex 51021-0600) DESCRIPTION Reserved Reserved +5V RS-232 Tx data Ground RS-232 Rx data (Mating type : JST ZHR-2) DESCRIPTION SPDIF audio out Ground (Matching type : XHP-4) DESCRIPTION +12V DC, 500mA max Ground Ground +5V DC, 500mA max (Matching type : XHP-5) DESCRIPTION Ground Backlight power supply, +12VDC, 3A max Backlight On/Off control signal (refer to JB2 & JB3) Backlight brightness VR pin WIP Backlight brightness VR pin A CNC1 – OSD switch mount control, Hirose DF13A-12P-1.25H (Mating type : DF13-12S-1.25C) PIN SYMBOL DESCRIPTION 1 PSWIN Power button A 2 SW_ON Power button B 3 BVR_A Backlight Brightness VR pin A 4 BVR_WIP Backlight Brightness R pin WIP 5 BVR_B Backlight Brightness VR pin B (470 ohm resistor to +5V Vcc) 6 GND Ground 7 MENU OSD menu 8 -/LEFT OSD -/Left 9 +/RIGHT OSD +/Right 10 SEL_DN OSD Select down 11 SEL_UP OSD Select up 12 NC No connection IR1 – Infra-Red sensor connector: Molex 53261-0371, 3 way 1.25mm pitch (Matching type : Molex 51021-0300) PIN SYMBOL DESCRIPTION 1 GND Ground 2 STDBY_Vcc Stand by voltage 3 IR Data IR data Page 15 of 30 J1 – HDMI connector: JST SM20B-SRDS (Matching type : JST SHDR-20V-S-B) PIN SYMBOL DESCRIPTION 1 GND Ground 2 GND Ground 3 RXC+ TMDS Data C+ 4 RXCTMDS Data C5 RX0+ TMDS Data 0+ 6 RX0TMDS Data 07 RX1+ TMDS Data 1+ 8 RX1TMDS Data 19 RX2+ TMDS Data 2+ 10 RX2TMDS Data 211 GND Ground 12 GND Ground 13 MSTR2_SCL Reserved 14 MSTR2_SDA Reserved 15 DDC_5V +5V power supply for DDC (optional) 16 HPD Hot plug detection 17 DDC_SCL DDC serial clock 18 DDC_SDA DDC Data 19 VCC1 VCC 5V output 20 VCC2 VCC 5V output J3 – LVDS output connector: JAE FI-RE51S-HF (Matching type : JAE FI-RE51HL) PIN SYMBOL DESCRIPTION 1 VDD (+12V) Panel power supply (+12V) (selected by JA3) 2 VDD (+12V) Panel power supply (+12V) (selected by JA3) 3 VDD (+12V) Panel power supply (+12V) (selected by JA3) 4 VDD (+12V) Panel power supply (+12V) (selected by JA3) 5 VDD (+12V) Panel power supply (+12V) (selected by JA3) 6 VDD (3,3V/5V) Panel power supply (3,3V/5V) (selected by JA3) 7 VDD (3,3V/5V) Panel power supply (3,3V/5V) (selected by JA3) 8 VDD (3,3V/5V) Panel power supply (3,3V/5V) (selected by JA3) 9 VDD (3,3V/5V) Panel power supply (3,3V/5V) (selected by JA3) 10 VDD (3,3V/5V) Panel power supply (3,3V/5V) (selected by JA3) 11 GND Ground 12 GND Ground 13 GND Ground 14 GND Ground 15 GND Ground 16 NC No connection 17 NC No connection 18 NC No connection 19 NC No connection 20 GND Ground 21 GND Ground 22 NC No connection 23 NC No connection 24 TXA3+ Positive differential LVDS data bit A3 25 TXA3Negative differential LVDS data bit A3 26 GND Ground 27 TXAC+ Positive LVDS clock for A channel 28 TXACNegative LVDS clock for A channel 29 GND Ground 30 TXA2+ Positive differential LVDS data bit A2 31 TXA2Negative differential LVDS data bit A2 32 TXA1+ Positive differential LVDS data bit A1 33 TXA1Negative differential LVDS data bit A1 34 TXA0+ Positive differential LVDS data bit A0 35 TXA0Negative differential LVDS data bit A0 36 GND Ground 37 NC No connection 38 NC No connection 39 TXB3+ Positive differential LVDS data bit B3 40 TXB3Negative differential LVDS data bit B3 41 GND Ground 42 TXBC+ Positive LVDS clock for B channel 43 TXBCNegative LVDS clock for B channel 44 GND Ground 45 TXB2+ Positive differential LVDS data bit B2 46 TXB2Negative differential LVDS data bit B2 Page 16 of 32 47 48 49 50 51 TXB1+ TXB1TXB0+ TXB0GND Positive differential LVDS data bit B1 Negative differential LVDS data bit B1 Positive differential LVDS data bit B0 Negative differential LVDS data bit B0 Ground LED1 – Dual color LED connector for controller status, JST 3-way, S3B-ZR-SM4A PIN DESCRIPTION 1 Green LED pin (anode) 2 LED pin common (cathode) 3 Red LED pin (anode) PP2 - Power supply PIN 1 2 (Mating type : JST ZHR-3) (Mating type : Molex 43645-0200 compatible) DESCRIPTION +12VDC 5A max Ground Page 17 of 30 CONTROLLER DIMENSIONS HDD-1920 The maximum thickness of the controller is 13.95mm (measured from bottom of PCB to top of components, including any underside components & leads). We recommend clearances of:  5mm from bottom of PCB - if mounting on a metal plate we also recommend a layer of suitable insulation material is added to the mounting plate surface.  10mm above the components  3~5mm around the edges Any of the holes shown above can be used for mounting the PCB, they are 3.2mm in diameter. CAUTION: Ensure adequate insulation is provided for all areas of the PCB with special attention to high voltage parts such as the inverter. Page 18 of 32 APPLICATION NOTES USING THE CONTROLLER WITHOUT BUTTONS ATTACHED This is very straightforward by following the steps below :  Firstly setup the controller/display system with the buttons. With controls attached and display system active make any settings for colour and image position as required then switch everything off.  Use a jumper to close JP6 jumper, this will fix the board On.  Refer to inverter specifications for details as to fixing brightness to a desired level, this may require a resistor, an open circuit or closed circuit depending on inverter. INVERTER CONNECTION There are potentially 3 issues to consider with inverter connection:  Power  Enable  Brightness Please read the following sections for a guide to these issues. Inverter Power: As per the table for CNB1 pin 1 is ground and pin 2 provides 12VDC. This should be matched with the inverter specification: see table. CNB1 PIN DESCRIPTION 1 Ground 2 +12VDC Remark: For higher power inverter, more current for 12V can be taken from CNA1 pin 1. Maximum current drawn on CNA1 pin 1 and CNB1 pin 2 is 3A(12V) Enable: This is a pin provided on some inverters for On/Off function and is used by this panel controller for VESA DPMS compliance. If the inverter does not have an enable pin or the enable pin is not used then DPMS will not be operational. Pin 3 should be matched to the inverters specification for the „enable‟ or „disable‟ pin. CNB1 PIN 3 DESCRIPTION Enable Further, jumpers JB2 & JB3 should be set to match the inverters specification for the enable pin power and High or Low setting: see table. Ref JB2 JB3 Purpose Inverter enable voltage Inverter control Note 1-2 H = 12V, 2-3 H = 5V (Vcc), OPEN H = open collector 1-2 H = On, 2-3 L = On Brightness: There are various methods for brightness control and it is important to consider the specifications for the inverter to be used. Generally the situation is:  Brightness can controlled by using a resistor or VR (Variable Resistor).  Brightness controlled by adding a circuit such as PWM (Pulse Width Modulation).  No adjustment of brightness is possible. CNB1 pins 4 & 5 are available for connecting to an inverter or circuit where VR control is supported. CNB1 PIN DESCRIPTION 4 VR WIP 5 VR A This can then be matched with function controls (OSD switch mount) pins 3 & 4: see cable design below . Page 19 of 30 Design Guideline for making VR circuitry : Signal description / Notes : 1) R1 : 470ohm on board 2) RPOT is an external potentiometer (in-line dip style) that can be plugged directly into CNC1 pins 3,4,5. RPOT must be supplied / installed by user. 3) BVR_B : Voltage tapped from “top” of potentiometer, the node of R1 and RPOT. 4) BVR_WIP : Voltage tapped from wiper arm of RPOT. 5) BVR_A : Voltage tapped from “bottom” of RPOT. Note : BVR_A voltage is left floating on the controller board. To use this circuit, you need to tie this point to a potential (usually GND, available at CNC1 pin 6). CNB1 – Backlight inverter connector: JST B5B-XH-A (Matching type : XHP-5) PIN SYMBOL DESCRIPTION 1 GND Ground 2 VBKL +12VDC, backlight power supply (selected by JA3 & JA6) 3 BLCTRL On/Off control (enable) – see JB2 & JB3 4 BVR_WIP Brightness VR - WIP 5 BVR_A Brightness VR A CNC1 – Control switch, JST B12B-XH-A (Matching type : XHP-12) PIN SYMBOL DESCRIPTION 1 PSWIN Power button A 2 SW_ON Power button B 3 BVR_A Backlight Brightness VR pin A 4 BVR_WIP Backlight Brightness R pin WIP 5 BVR_B Backlight Brightness VR pin B (470 ohm resistor to +5V Vcc) 6 GND Ground 7 MENU OSD menu 8 -/LEFT OSD -/Left 9 +/RIGHT OSD +/Right 10 SEL_DN OSD Select down 11 SEL_UP OSD Select up 12 NC No connection The VR for brightness depends on the inverter. The main power load for On/Off is handled by a relay on the controller. Example for circuit design : 1.)Choose RPOT = 10K 2.) Tie BVR_A to GND 3.) Circuit analysis gives BVR_WIP as the following (see Figure 1) BVR_WIP = 5 x (Rbc/10.47) where BVR_WIP is in Volts. And Rbc is the resistance from the wiper arm to bottom of pot in Kohms. To evaluate, plug in different values of Rbc : Rbc 0 2.5 K 5K 7.5 K 10 K BVR_WIP 0V 1.2 V 2.4 V 3.6 V 4.8 V So this circuit could provide Brightness adjust voltage ranging from 0V to 5V. Page 20 of 32 TROUBLESHOOTING General A general guide to troubleshooting a flat panel display system it is worth considering the system as separate elements, such as:  Controller (jumpers, PC settings)  Panel (controller, cabling, connection, panel, PC settings)  Backlight (inverter, cabling, backlight tubes)  Cabling  Computer system (display settings, operating system) Through step by step cross checking with instruction manuals and a process of elimination to isolate the problem it is usually possible to clearly identify the problem area. No image:  If the panel backlight is not working it may still be possible to just see some image on the display.  A lack of image is most likely to be caused by incorrect connection, lack of power, failure to provide a signal or incorrect graphic card settings. Image appearance:  A faulty panel can have blank lines, failed sections, flickering or flashing display  Incorrect graphics card refresh rate, resolution or interlaced mode will probably cause the image to be the wrong size, to scroll, flicker badly or possibly even no image.  Incorrect jumper settings on the controller may cause everything from total failure to incorrect image. CAUTION: Do not set the panel power input incorrectly.  Sparkling on the display: faulty panel signal cable. Backlight: Items to check include: Power input, Controls, Inverter and Tubes generally in this order. If half the screen is dimmer than the other half:  Check cabling for the inverter.  For a specific backlight tube check the AC pins orientation (CAUTION: Never reverse any DC power pins). Also:  If adjusting brightness control has no effect the chances are that the VR rating or method of adjusting brightness is not compatible or correctly connected to the inverter.  If system does not power down when there is a loss of signal Continued failure: If unit after unit keeps failing consider and investigate whether you are short circuiting the equipment or doing something else seriously wrong. Generally after common sense issues have been resolved we recommend step by step substitution of known working parts to isolate the problem. Page 21 of 30 SPECIFICATIONS Panel compatibility No. of colours Vertical refresh rate Dot clock (pixel clock) maximum Graphics formats Standard input at source Controls available Control interface Settings memory Language OSD support Voltage output for LCD Input voltage Controller power consumption Controller dimensions Storage temperature limits Operating temperature limits 1920x1200, 1920x1080, 1680x1050, 1600x1200, 1400x1050, 1440x900, 1366x768, 1280x1024, 1280x800, 1280x768, 1024x768, 1024x600, 800x600, 800x480, 640x480, 480x640 resolution TFT LVDS LCD‟s support. Up to 3 x 8 bit providing 16.7 million colours. WUXGA, UXGA, WXGA, SXGA, XGA, SVGA, VGA resolution up to 60Hz. 165 MHz Standard WUXGA, UXGA, SXGA, XGA, SVGA, VGA - HDMI (v1.3) - On/Off - Brightness (inverter) - OSD menu - OSD select - OSD setting + - OSD setting - Buttons, RS-232, IR remote control Settings are stored in non volatile memory Graphics OSD icons +3.3V, +5V, +12V The current drawn for 3.3V, 5V or 12V panel from 12VDC power input is limited to 3A. 12VDC , 5A max +/- 5% Approx 4W (controller logic only, no panel and inverter are involved) 59.7mm x 91.4mm x 13.95mm -40oC to +85oC -40oC to +80oC** Coating Silicone resin conformal coating. ** Overall suitability for usage in critical applications must be independently tested and verified by the user. NOTES Please note the following:  For specific panel setup a sample of an LCD may be required (this will be returned) and a copy of the full technical specifications for the panel from the manufacturer.  Re-layout and custom development services are available. Page 22 of 32 Appendix I – Mode Support Table HDMI (J1) port : Mode Resolution Clk Horizontal Vertical [MHz] freq freq [Hz] [KHz] V_60 SV_60 X_60 SX_60 640x480 60Hz 800x600 60Hz 1024x768 60Hz 1280x1024 60Hz 25.175 40.000 65.000 108 31.469 37.879 48.363 63.81 59.940 60.317 60.004 60.020 UX_60 WUX_60 WUX_60 1080p60 1080i60 1080i50 720p60 576p50 1600x1200 60Hz 1920x1080 60Hz 1920x1200 60Hz 1920x1080p 60Hz 1920x1080i 60Hz 1920x1080i 50Hz 1280x720P 60Hz 720x576P 50Hz 162 172.8 193.2 135 74.14 74.184 74.25 26.9568 75.000 67.5 74.5 67.5 33.7 28.1 45 31.2 60 60 60 60 60 50 60 50 480p60 720x480P 60Hz 26.9568 31.4 60 Page 23 of 30 Appendix II – RS-232 control protocols RS-232 Serial control (Baud rate 2400, 8 bits, 1 stop bit and no parity) Physical connection : Controller side Connector interface : CN8 Mating connector : Molex 51021-0600 6 5 PIN# 4 5 6 4 1 3 Mating face of CN8 Description RS-232 Tx Data Ground RS-232 Rx Data Computer side Connector interface : Serial port Mating connector : DB9 Female 1 4 3 6 PIN# 2 3 5 7 8 5 9 Mating face of RS-232 DB9 Male Description RS-232 Rx Data RS-232 Tx Data Ground Software connection : The OSD function can be controlled through sending the RS-232 protocol. The RS-232 program can be custom-made to fit for application or it can be used the program provided by Digitalview on request. Please contact your local sales for informations. 1. Commands to implement switch mount control buttons Functio Command Description Acknowledge (if enabled) n Menu Select-down button Select-up button Right/+ button Left/- button 0xf7 0xfa Button equivalent Button equivalent 0xfb Menu button pressed Select down button pressed Select up button pressed 0xfc 0xfd Right/+button pressed Left/- button pressed Button equivalent Button equivalent Button equivalent 2. Parameter setting - immediate, relative, reset and query Function Command Description Acknowledge (if enabled) Brightness 0x81, Set brightness = Brightness. control nn | “+” | “-” | value/increment/decrement “r” | “R” | Reset Range: “0””0”-“6””4” “?” Query Default: “3””2” Contrast 0x82, “a” | “A”, Set all contrast = Contrast. control nn | “+” | “-” | value/increment/decrement “r” | “R” | Reset Range: “4””0”-“6””4” “?” Query Default: “3””2” Sharpness 0x8a, Set sharpness= Sharpness nn | “+” | “-” |”r” | value/increment/decrement ”R” | Reset Range: “F””C”-“0””4” “?” Query Default: “0””0” OSD H position 0x90, Set osd_hpos = OSD horizontal position nnn | “+” | “-“ | value/increment/decrement “r” | “R” | “?” Reset Range: “0””0””0”-“3””E””8” Query Default: “1””F””4” OSD V position 0x91, Set osd_vpos = OSD vertical position nnn | “+” | “-“ | value/increment/decrement “r” | “R” | “?” Reset Range: “0””0””0”-“3””E””8” Query Default: “1””F””4” Page 24 of 32 Select menu timeout 0x93, Select menu timeout = nn | “+” | “-“ | “r” | value/increment/decrement “R” | “?” Reset Query GAMMA value select 0x9d, n| “r” | “R” | “?” Select GAMMA value = Value Reset Query Colour temperature select 0xb3, n| “r” | “R” | “?” Select colour temperature = value Reset Query Red level for selected colour temperature 0xb4, Set the level of the red channel for the selected colour temp. = value/increment/decrement Reset Query Set the level of the green channel for the selected colour temp. = value/increment/decrement Reset Query Set the level of the blue channel for the selected colour temp. = value/increment/decrement Reset Query Set backlight brightness = value/increment/decrement Reset Query Green level for selected colour temperature Blue level for selected colour temperature Backlight brightness control nn | “+” | “-” | “r” | “R” | “?” 0xb5, nn | “+” | “-” | “r” | “R” | “?” 0xb6, nn | “+” | “-” | “r” | “R” | “?” 0xe0, nn | “+” | “-” | “r” | “R” | “?” OSD menu timeout value. “00” – Continuous. Value – Round up to nearest available step. If value > max available step, set it to the max available step. “0” “0” – Always On. “0” “C” – 12 seconds (Default) “0” “6” – 6 seconds “0” “3” – 3 seconds GAMMA value: “0” – 0.4, “1” – 0.6 “2” – 1.0 (Default), “3” – 1.6 “4” – 2.2 Main selected. “0” – user defined RGB values. “1” – 4200K. “2” – 5000K. “3” – 6500K. “4” – 7500K. (Default) “5” – 9300K. Red level for selected colour temperature. Range: “0””0”-“6””4” Default: “6””4” Green level for selected colour temperature. Range: “0””0”-“6””4” Default: “6””4” Blue level for selected colour temperature. Range: “0””0”-“6””4” Default: “6””4” Backlight brightness. Range: “0””0”-“6””4” Default: “6””4” e.g “1””0”  0xe0 0x31 Page 25 of 30 0x30 * This control can only function when JB5 sets 3-4 closed Backlight on/off control Backlight PWM** Backlight PWM Frequency** 0xe1, “0” | “1” | “r” | “R” | “?” 0xe5, “0” | “1” | “r” | “R” | “?” 0xe6, nnn | “+” | “-” | “r” | “R” | “?” Set backlight brightness = Disable backlight Enable backlight Reset Query Set backlight type D/A or PWM Reset Query Set Backlight PWM Frequency = Value/ increment/ decrement Reset Query Backlight Invert** 0xe7, Set backlight invert 0” | “1” | Normal or Invert “r” | “R” | Reset “?” Query OSD menu 0xf6, OSD menu lock Off/ On lock n | “0” | “1” | Reset “r” | “R” | Query “?” ** - Only effective on V1.04.00 or up version. Page 26 of 32 * Apply for inverter control voltage in range of 0~5V. Each step interval is in 1 Backlight on/off. “1” – PWM “0” – D/A +/- 20Hz Value 100Hz : “0”, “6”, “4” 120Hz : “0”, “7”, “8” 140Hz : “0”, “8”, “C” 160Hz : “0”, “A”, “0” 180Hz : “0”, “B”, “4” 200Hz : “0”, “C”, “8” 220Hz : “0”, “D”, “C” 240Hz : “0”, “F”, “0” 260Hz : “1”, “0”, “4” 280Hz : “1”, “1”, “8” 300Hz : “1”, “2”, “C” 320Hz : “1”, “4”, “0” 340Hz : “1”, “5”, “4” 360Hz : “1”, “6”, “8” 380Hz : “1”, “7”, “C” 400Hz : “1”, “9”, “0” 420Hz : “1”, “A”, “4” 440Hz : “1”, “B”, “8” “1” – Invert “0” – Normal “0” – OSD menu lock Off “1” – OSD menu lock On 3. Other control Function Command Select RS-232 0xc1, “0” | “1” acknowledge Command availability Soft Power On/Off** 0xc4, n 0xc8, “0” | “1” | “?” 0xcb, “0” Description Disable/enable command acknowledge. Acknowledge (if enabled) “0” – acknowledge disabled. “1” – acknowledge enabled. Check whether a command “0” – not available. is available. “1” – available. Soft power “0” – soft power off. On/off “1” –soft power on. query Read BIOS version “nnnn” = BIOS ver. “nn.nn” Query BIOS version Query PCBA 0xcb, “1” Read PCBA number number Load factory 0xce Reset all parameters to defaults factory default value ** - Only effective on V1.04.00 or up version. Hex to ASCII conversion table Hex ASCII Hex ASCII 0x30 0 0x41 A 0x31 1 0x42 B 0x32 2 0x43 C 0x33 3 0x44 D 0x34 4 0x45 E 0x35 5 0x46 F 0x36 6 0x47 G 0x37 7 0x48 H 0x38 8 0x49 I 0x39 9 0x4A J 0x4B K 0x4C L 0x4D M 0x4E N 0x4F O 0x50 P 0x51 Q 0x52 R 0x53 S 0x54 T 0x55 U 0x56 V 0x57 W 0x58 X 0x59 Y 0x5A Z Hex 0x61 0x62 0x63 0x64 0x65 0x66 0x67 0x68 0x69 0x6A 0x6B 0x6C 0x6D 0x6E 0x6F 0x70 0x71 0x72 0x73 0x74 0x75 0x76 0x77 0x78 0x79 0x7A ASCII a b c d e f g h i j k l m n o p q r s t u v w x y z Page 27 of 30 Hex 0x2B 0x2D 0x3F “nnnn” = PCBA number DD-1920=”41730” “1” – successful. ASCII + ? Appendix III – DDC/CI support at HDMI port This controller (start from V1.04.00 or later firmware revision) supports the following DDC/CI commands at HDMI port : Brightness Contrast RGB Color Input Source (VGA, HDMI & Displayport) Power States (On, Standby, Sleep)  On mode: Always on. Display No sync message and never goes off when no signal  Standby mode: Off backlight & Off panel power when no signal  Reduced power off / Sleep mode: Screen saver on = Always On; Screen saver off = Backlight off. Display "No sync" message for 10sec, then off backlight Page 28 of 32 Appendix IV – Mapping definition  Definition of Mapping A : Page 29 of 30  Definition of Mapping B : Page 30 of 32 Appendix V – DV remote control unit work for HDD-1920 P/N 559000106-3 : DigitalView remote control unit (without DV logo silk screen printing) P/N 559000105-3 : DigitalView remote control unit (with DigitalView logo silk screen printing) BUTTON POWER BUTTON FUNCTION Soft power ON/OFF button. Use combined with digit keys to enable/disable the IR function. HDD-1920 : “Attention” + “1” ATTENTION BUTTON MUTE BUTTON ( ) SEL UP ( ) / SEL DN ( + / - BUTTON DISPLAY BUTTON HDMI BUTTON Switch to mute on/off mode. ) Press this button to select the items in the OSD menu. Use “+” button to direct control the hotkey function for switching to next input source. In OSD menu, pressing this button to adjust the settings. Activate the OSD menu display on screen. Press this button in the non OSD menu display mode to select DVI source. Page 31 of 30 WARRANTY The products are warranted against defects in workmanship and material for a period of three (3) year from the date of purchase provided no modifications are made to it and it is operated under normal conditions and in compliance with the instruction manual. The warranty does not apply to:  Product that has been installed incorrectly, this specifically includes but is not limited to cases where electrical short circuit is caused.  Product that has been altered or repaired except by the manufacturer (or with the manufacturer‟s consent).  Product that has subjected to misuse, accidents, abuse, negligence or unusual stress whether physical or electrical.  Ordinary wear and tear. Except for the above express warranties, the manufacturer disclaims all warranties on products furnished hereunder, including all implied warranties of merchantability and fitness for a particular application or purpose. The stated express warranties are in lieu of all obligations or liabilities on the part of the manufacturer for damages, including but not limited to special, indirect consequential damages arising out of or in connection with the use of or performance of the products. CAUTION Whilst care has been taken to provide as much detail as possible for use of this product it cannot be relied upon as an exhaustive source of information. This product is for use by suitably qualified persons who understand the nature of the work they are doing and are able to take suitable precautions and design and produce a product that is safe and meets regulatory requirements. LIMITATION OF LIABILITY The manufacturer‟s liability for damages to customer or others resulting from the use of any product supplied hereunder shall in no event exceed the purchase price of said product. TRADEMARKS The following are trademarks of Digital View Ltd:  Digital View  HDD-1920 Page 32 of 32 CONTACT DETAILS USA: Digital View Inc. 18440 Technology Drive Building 130 Morgan Hill, CA 95037 USA Tel: (1) 408-782 7773 Sales: ussales@digitalview.com EUROPE: Fax: (1) 408-782 7883 Digital View Ltd. The Lake House Knebworth Park Herts, SG3 6PY UK Tel: +44-(0)20-7631-2150 Fax: +44-(0)20-7631-2156 Sales: uksales@digitalview.com ASIA: Digital View Ltd 16th floor Millennium City 3 370 Kwun Tong Road Kwun Tong Hong Kong Tel: (852) 2861 3615 Sales: hksales@digitalview.com Fax: (852) 2520 2987 WEBSITE www.digitalview.com Brand names belong to their respective owners. Specification subjects to change without notice. _________________________________________________________________________________________________________________ 1st issue: April, 2015 (HDD-1920 –1x manual.doc) © Digital View Ltd 2005 Page 33 of 30
4173003XX-3 价格&库存
很抱歉,暂时无法提供与“4173003XX-3”相匹配的价格&库存,您可以联系我们找货
