4175701XX-3
4175701XX-3
    DIGITALVIEW
    CONTROLLER DD-1920-HDMI-T
4175701XX-3 数据手册
DD-1920-HDMI-T (Preliminary) 4mm Thick Full-HD LCD Controller The DD-1920-HDMI-T LCD controller is an adaption on the existing and well- established DD-1290-HDMI controller redesigned to reduce the thickness to within 4mm. Designed to support 8 bit LCD panels up to 1920x1200 resolution with LVDS input it provides HDMI input via a micro-HDMI connector. Both standard and custom panel and input resolutions are supported. Key Features: »» Up to 1920x1200 input / Up to 1920x1200 LCD panels »» HDMI 1.4, Micro-HDMI connector »» LVDS panel connection @60Hz »» Very low latency »» RS-232, I2C for command & control »» Harsh environment version to be relased following this model Panel Connectivity Features LVDS up to 1920 x 1200 @60Hz Standard and custom panel resolutions are supported Colors: Up to 8 bit per color Function Display: On Screen Display (OSD) menu Function Controls: External buttons, Infra-Red controls, Serial Port Image Scaling: Image Control: Up / Down scaling to fit input to panel resolution Brightness, Contrast, Color Temperature, Image position, Saturation, Hue, Sharpness Communication: RS-232, I2C Firmware upgrade: RS-232, Smart-ISP Power: Panel Power: Input HDMI 1.4 60Hz up to 1920x1200 75Hz up to 1280x1024 Panel Signal: +12VDC / +24VDC ±5%, 10W (controller only) Supports 3.3V, 5V, 12V panels LVDS Inverter Support: DPMS Enable pin (3.3V or 5V), PWM Plug & Play: DDC 1,2/b compatible Audio: Analog line-out Size: 91.4mm x 91.4mm x 4mm Status Indicator: Dual color LED support Reliability Calculated MTBF: Warranty: In excess of 250,000 hours 3 years Specifications subject to change without notice © 2016 Digital View DD-1920-HDMI-T April 2016 v0.1v DD-1920-HDMI-T 4mm Thick LCD Controller Mechanical Drawing Connector Definitions CN1 CN8 CNA1 CNB1 CNC1 IR1 J3 P1 PP2 Ordering Options DD-1920-HDMI-T P/N: TBA Accessories - TBA Stereo audio out from HDMI RS-232 serial control Ambient light sensor connector Reserved for fan & backlight power monitoring SPDIF Audio output Reserved Reserved for Line in Reserved for Speaker out Power connector for IE-2000 Drawings Available Resources »» 2D (jpg) »» 3D (SLDPRT) »» »» »» »» »» Download at: TBA Instruction manual Revision control documentation Firmware upgrade manual** Mechanical drawing Custom engineering: Splash screen, OSD menu, coatings, & more... ** Available on request Controller Solution Generator http://www.digitalview.com/csg USA 18440 Technology Drive, Morgan Hill, CA 95037, USA t: +1 (408) 782-7773 www.digitalview.com EUROPE The Lake House, Knebworth Park, Herts, SG3 6PY, UK t: +44 (0) 20-7631-2150 ASIA 2/F Bamboos Centre, 52 Hung To Rd, Kwun Tong, Hong Kong t: (852) 2861-3615 The QR code above links to the product page on the website
4175701XX-3 价格&库存
很抱歉,暂时无法提供与“4175701XX-3”相匹配的价格&库存,您可以联系我们找货
