0221-2407
0221-2407
    DINKLE(台湾町洋)
    TERM BLK 7POS 3.50MM PID PLG
0221-2407 数据手册
0221-24XX PCB Terminal Blocks > PCB Connector-Plug Date:2022-06-09 The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design. The final product is made according to engineering drawing. Product Description Pitch : 3.50 mm, 300V, 8A General information Short description Category Pitch (mm) PCB Connector – Plug, Push-in Design PCB Connector – Plug 3.50 Color Green (default) Connection method Push in Design Type of locking With lock flange Length (mm) 3.50*(P-1)+14.0 Width (mm) 29.9 Height (mm) 7.7 Number of positions Level 02P~20P Single level Material information Insulation material Insulation material group Flame retardant rating , compliant with UL94 TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED PA I V0 1/4 Insulation resistance ≥500MΩ at DC 500V Conductor material COPPER ALLOY Plating of conductor surface Tin PLATED Connection data-IEC Rated voltage (V) 320 Rated current (A) 8 Rated voltage (II/2)(V) 320 Rated voltage (III/2) (V) 160 Rated voltage (III/3)(V) 160 Rated impulse voltage (II/2)(KV) 2.5 Rated impulse voltage (III/2)(KV) 2.5 Rated impulse voltage (III/3)(KV) 2.5 Conductor cross section solid. min (mm²) 0.2 Conductor cross section solid.max (mm²) 1.5 Conductor cross section stranded. min (mm²) 0.2 Conductor cross section stranded. max (mm²) 1.5 Conductor cross section flexible, with min ferrule without plastic sleeve (mm²) 0.25 Conductor cross section flexible, with max ferrule without plastic sleeve (mm²) 1 Conductor cross section flexible, with min ferrule with plastic sleeve (mm²) 0.25 Conductor cross section flexible, with max ferrule with plastic sleeve (mm²) 0.75 Slotted screwdriver size (Blade thickness x Width)(mm) 0.4x2.5 Stripping Length (mm) 8~10 Connection data-UL Rated voltage (UL/CUL Group B)(V) 300 Rated current (UL/CUL Group B)(A) 8 Min. solid wire connection (AWG) acc. to UL/CUL 24 Max. solid wire connection AWG acc. to UL/CUL 16 Min. stranded wire connection AWG acc. to UL/CUL 24 Max. stranded wire connection AWG acc. to UL/CUL 16 Environment & Safety TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 2/4 Back of the hand protection (YES or NO) YES Finger protection (YES or NO) YES Operating temperature. max (°C) 120 Operating temperature. min (°C) -40 UL Recognized Wire Range (Group B)(AWG) 24~16 Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 8 CUL Recognized Wire Range (Group B)(AWG) 24~16 Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 8 VDE Approval Wire Range (mm²) 0.2~1.5 Rated voltage (V) 320 Rated current (A) 8 Drawings Approvals TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 3/4 TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED Powered by TCPDF (www.tcpdf.org) 4/4
0221-2407 价格&库存
很抱歉,暂时无法提供与“0221-2407”相匹配的价格&库存,您可以联系我们找货
