2ESDPL-10P
2ESDPL-10P
    DINKLE(台湾町洋)
    TERM BLK 10POS 5.08MM SCRW PLG
2ESDPL-10P 数据手册
2ESDPL-XXP PCB Terminal Blocks > PCB Connector-Plug Date:2021-05-19Version:1.1 The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design. The final product is made according to engineering drawing. Product Description Pitch : 5.08 mm, 300V, 15A General information Short description Category Pitch (mm) Color Connection method Type of locking PCB Connector Plug, Screw Connection PCB Connector – Plug 5.08 Green (default) Screw Connection Without Length (mm) 5.08*P Width (mm) 12.55 Height (mm) 26.05 Number of positions Level 02P~24P Single level Material information Insulation material Insulation material group Flame retardant rating , compliant with UL94 TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED PA I V0 1/4 Insulation resistance ≥500MΩ at DC 500V Conductor material COPPER ALLOY Plating of conductor surface Tin PLATED Connection data-IEC Rated voltage (V) 600 Rated current (A) 18 Rated voltage (II/2)(V) 600 Rated voltage (III/2) (V) 320 Rated voltage (III/3)(V) 250 Rated impulse voltage (II/2)(KV) 4 Rated impulse voltage (III/2)(KV) 4 Rated impulse voltage (III/3)(KV) 4 Conductor cross section solid. min (mm²) 0.2 Conductor cross section solid.max (mm²) 2.5 Conductor cross section stranded. min (mm²) 0.2 Conductor cross section stranded. max (mm²) 2.5 Conductor cross section flexible, with min ferrule without plastic sleeve (mm²) 0.25 Conductor cross section flexible, with max ferrule without plastic sleeve (mm²) 2.5 Conductor cross section flexible, with min ferrule with plastic sleeve (mm²) 0.25 Conductor cross section flexible, with max ferrule with plastic sleeve (mm²) 2.5 2 conductors with same cross section, solid, max (mm²) 1.5 2 conductors with same cross section, stranded, max (mm²) 1.5 2 conductors with same cross section flexible, with min ferrule without plastic sleeve (mm²) 0.25 2 conductors with same cross section flexible, with max ferrule without plastic sleeve (mm²) 0.75 2 conductors with same cross section flexible, min twin ferrules with plastic sleeve (mm²) 0.5 2 conductors with same cross section flexible, max twin ferrules with plastic sleeve (mm²) 1.5 Screw thread Slotted screwdriver size (Blade thickness x Width)(mm) Philips screwdriver size TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED M2.5 0.6x3.5 PH1 2/4 Rated torque (N.m) 0.5 Stripping Length (mm) 7~8 Connection data-UL Rated voltage (UL/CUL Group B)(V) 300 Rated current (UL/CUL Group B)(A) 15 Rated voltage (UL/CUL Group D)(V) 300 Rated current (UL/CUL Group D)(A) 10 Min. solid wire connection (AWG) acc. to UL/CUL 28 Max. solid wire connection AWG acc. to UL/CUL 12 Min. stranded wire connection AWG acc. to UL/CUL 30 Max. stranded wire connection AWG acc. to UL/CUL 12 Environment & Safety Finger protection (YES or NO) YES Operating temperature. max (°C) 120 Operating temperature. min (°C) -40 UL Recognized Wire Range (Group B)(AWG) 30~12 Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 15 Wire Range (Group D)(AWG) 30~12 Rated voltage (Group D)(V) 300 Rated current (Group D)(A) 10 CUL Recognized Wire Range (Group B)(AWG) 30~12 Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 15 Wire Ranget (Group D)(AWG) 30~12 Rated voltage (Group D)(V) 300 Rated current (Group D)(A) 10 VDE Approval TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 3/4 Wire Range (mm²) 0.2~2.5 Rated voltage (V) 600 Rated current (A) 18 Drawings Approvals TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED Powered by TCPDF (www.tcpdf.org) 4/4
2ESDPL-10P
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管输出,6脚光电晶体管负极。
4. 参数特性:工作温度范围为-20℃至+70℃,输入电流为10mA,输出电流为50mA。
5. 功能详解:EL817通过光电效应实现电-光-电转换,实现信号隔离。
6. 应用信息:广泛应用于工业控制、仪器仪表等领域。
7. 封装信息:采用DIP6封装。
2ESDPL-10P 价格&库存
很抱歉,暂时无法提供与“2ESDPL-10P”相匹配的价格&库存,您可以联系我们找货
