5ESDSR-06P
5ESDSR-06P
    DINKLE(台湾町洋)
    P=5mm
    接线端子 间距:5.00mm 自由悬挂(直插式)
5ESDSR-06P 数据手册
5ESDSR-XXP PCB Terminal Blocks > PCB Connector-Plug Date:2021-05-19Version:1.1 The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design. The final product is made according to engineering drawing. Product Description Pitch : 5.00 mm, 300V, 10A General information Short description Category Pitch (mm) PCB Connector Plug, Push-in design PCB Connector – Plug 5.00 Color Green (default) Connection method Push-in Design Type of locking Without Length (mm) 5.00*P Width (mm) 25.9 Height (mm) 15 Number of positions Level 02P~24P Single level Material information Insulation material Insulation material group Flame retardant rating , compliant with UL94 TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED PA I V0 1/4 Insulation resistance ≥500MΩ at DC 500V Conductor material COPPER ALLOY Plating of conductor surface Tin PLATED Connection data-IEC Rated voltage (V) 600 Rated current (A) 12 Rated voltage (II/2)(V) 600 Rated voltage (III/2) (V) 320 Rated voltage (III/3)(V) 250 Rated impulse voltage (II/2)(KV) 4 Rated impulse voltage (III/2)(KV) 4 Rated impulse voltage (III/3)(KV) 4 Conductor cross section solid. min (mm²) 0.2 Conductor cross section solid.max (mm²) 2.5 Conductor cross section stranded. min (mm²) 0.2 Conductor cross section stranded. max (mm²) 2.5 Conductor cross section flexible, with min ferrule without plastic sleeve (mm²) 0.25 Conductor cross section flexible, with max ferrule without plastic sleeve (mm²) 2.5 Conductor cross section flexible, with min ferrule with plastic sleeve (mm²) 0.25 Conductor cross section flexible, with max ferrule with plastic sleeve (mm²) 2.5 2 conductors with same cross section flexible, min twin ferrules with plastic sleeve (mm²) 0.5 2 conductors with same cross section flexible, max twin ferrules with plastic sleeve (mm²) 1 Stripping Length (mm) 12 Connection data-UL Rated voltage (UL/CUL Group B)(V) 300 Rated current (UL/CUL Group B)(A) 10 Rated voltage (UL/CUL Group D)(V) 300 Rated current (UL/CUL Group D)(A) 10 Min. solid wire connection (AWG) acc. to UL/CUL 26 Max. solid wire connection AWG acc. to UL/CUL 12 TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 2/4 Min. stranded wire connection AWG acc. to UL/CUL 26 Max. stranded wire connection AWG acc. to UL/CUL 12 Environment & Safety Finger protection (YES or NO) YES Operating temperature. max (°C) 120 Operating temperature. min (°C) -40 UL Recognized Wire Range (Group B)(AWG) 26~12 Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 10 Wire Range (Group D)(AWG) 26~12 Rated voltage (Group D)(V) 300 Rated current (Group D)(A) 10 CUL Recognized Wire Range (Group B)(AWG) 26~12 Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 10 Wire Ranget (Group D)(AWG) 26~12 Rated voltage (Group D)(V) 300 Rated current (Group D)(A) 10 VDE Approval Wire Range (mm²) 0.2~2.5 Rated voltage (V) 600 Rated current (A) 12 Drawings TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 3/4 Approvals TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED Powered by TCPDF (www.tcpdf.org) 4/4
5ESDSR-06P 价格&库存
很抱歉,暂时无法提供与“5ESDSR-06P”相匹配的价格&库存,您可以联系我们找货
