DK10N-PE
DK10N-PE
    DINKLE(台湾町洋)
    SCREW TERM BLK GROUND 20~6AWG
DK10N-PE 数据手册
DK10N-PE DIN Rail Terminal Blocks > Screw Connection Date:2023-04-12Version:1.2 The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design. The final product is made according to engineering drawing. Product Description M4, Green-Yellow (default) General information Short description Category Color Connection method Type of locking DIN rail terminal blocks, Grounding terminal blocks Grounding terminal blocks Green-Yellow (default) Screw connection Rail mounting Length (mm) 47.2 Width (mm) 10 Height (mm) 48.8 Level Connection points Single level 2 Material information Insulation material Insulation material group Flame retardant rating , compliant with UL94 Insulation resistance TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED PA I V0 ≥500MΩ at DC 500V 1/4 Connection data-IEC Rated impulse voltage (III/3)(KV) 8 Conductor cross section solid. min (mm²) 0.5 Conductor cross section solid.max (mm²) 16 Conductor cross section stranded. min (mm²) 0.5 Conductor cross section stranded. max (mm²) 10 Conductor cross section flexible, with min ferrule without plastic sleeve (mm²) 0.5 Conductor cross section flexible, with max ferrule without plastic sleeve (mm²) 10 Conductor cross section flexible, with min ferrule with plastic sleeve (mm²) 0.5 Conductor cross section flexible, with max ferrule with plastic sleeve (mm²) 10 2 conductors with same cross section, solid, min (mm²) 0.25 2 conductors with same cross section, solid, max (mm²) 6 2 conductors with same cross section, stranded, min (mm²) 0.25 2 conductors with same cross section, stranded, max (mm²) 6 2 conductors with same cross section flexible, with min ferrule without plastic sleeve (mm²) 0.5 2 conductors with same cross section flexible, with max ferrule without plastic sleeve (mm²) 4 2 conductors with same cross section flexible, min twin ferrules with plastic sleeve (mm²) 0.5 2 conductors with same cross section flexible, max twin ferrules with plastic sleeve (mm²) 6 Screw thread Slotted screwdriver size (Blade thickness x Width)(mm) M4 1.0x5.5 Philips screwdriver size PH1 Rated torque (N.m) 1.4 Stripping Length (mm) 12~14 Mounting rail TS-35 End cover plate required YES Grounding connections YES Connection data-UL Min. solid wire connection (AWG) acc. to UL/CUL TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 20 2/4 Max. solid wire connection AWG acc. to UL/CUL 6 Min. stranded wire connection AWG acc. to UL/CUL 20 Max. stranded wire connection AWG acc. to UL/CUL 6 Environment & Safety Back of the hand protection (YES or NO) YES Finger protection (YES or NO) YES Operating temperature. max (°C) 120 Operating temperature. min (°C) -40 UL Recognized Wire Range (Group B)(AWG) 20~6 Wire Range (Group C)(AWG) 20~6 CUL Recognized Wire Range (Group B)(AWG) 20~6 Wire Range (Group C)(AWG) 20~6 VDE Approval Wire Range (mm²) 0.5~10 Drawings Approvals TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 3/4 TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED Powered by TCPDF (www.tcpdf.org) 4/4
DK10N-PE 价格&库存
很抱歉,暂时无法提供与“DK10N-PE”相匹配的价格&库存,您可以联系我们找货
