DK2.5N-TR
DK2.5N-TR
    DINKLE(台湾町洋)
    SCREW TERM BLK FEED THROUGH 22~1
DK2.5N-TR 数据手册
DK2.5N-TR DIN Rail Terminal Blocks > Screw Connection Date:2020-08-04Version:1.2 The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design. The final product is made according to engineering drawing. Product Description M2.5, 600V, 20A, Grey(default) General information Short description Category Color Connection method Type of locking DIN rail terminal blocks , Feed through terminal blocks Feed through terminal blocks Grey (default) Screw connection Rail mounting Length (mm) 5.1 Width (mm) 54.8 Height (mm) 48.5 Level Connection points Double level 4 Material information Insulation material Insulation material group Flame retardant rating , compliant with UL94 TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED PA I V0 1/4 Connection data-IEC Rated voltage (V) 1000 Rated current (A) 24 Rated voltage (III/2) (V) 1000 Rated impulse voltage (II/2)(KV) 8 Rated impulse voltage (III/2)(KV) 8 Rated impulse voltage (III/3)(KV) 8 Conductor cross section solid. min (mm²) 0.14 Conductor cross section solid.max (mm²) 4 Conductor cross section stranded. min (mm²) 0.14 Conductor cross section stranded. max (mm²) 2.5 Conductor cross section flexible, with min ferrule without plastic sleeve (mm²) 0.25 Conductor cross section flexible, with max ferrule without plastic sleeve (mm²) 2.5 Conductor cross section flexible, with min ferrule with plastic sleeve (mm²) 0.25 Conductor cross section flexible, with max ferrule with plastic sleeve (mm²) 2.5 2 conductors with same cross section, solid, max (mm²) 1.5 2 conductors with same cross section, stranded, max (mm²) 1.5 2 conductors with same cross section flexible, with min ferrule without plastic sleeve (mm²) 0.25 2 conductors with same cross section flexible, with max ferrule without plastic sleeve (mm²) 1 2 conductors with same cross section flexible, min twin ferrules with plastic sleeve (mm²) 0.5 2 conductors with same cross section flexible, max twin ferrules with plastic sleeve (mm²) 1 Screw thread Slotted screwdriver size (Blade thickness x Width)(mm) M2.5 0.6x3.5 Philips screwdriver size PH0 Rated torque (N.m) 0.39 Stripping Length (mm) 9~11 Mounting rail TS-35 End cover plate required YES Grounding connections NO TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 2/4 Connection data-UL Rated voltage (UL/CUL Group B)(V) 600 Rated current (UL/CUL Group B)(A) 20 Rated voltage (UL/CUL Group C)(V) 600 Rated current (UL/CUL Group C)(A) 20 Min. solid wire connection (AWG) acc. to UL/CUL 22 Max. solid wire connection AWG acc. to UL/CUL 12 Min. stranded wire connection AWG acc. to UL/CUL 22 Max. stranded wire connection AWG acc. to UL/CUL 12 Environment & Safety Back of the hand protection (YES or NO) YES Finger protection (YES or NO) YES Operating temperature. max (°C) 110 Operating temperature. min (°C) -40 UL Recognized Wire Range (Group B)(AWG) 22~12 Rated voltage (Group B)(V) 600 Rated current (Group B)(A) 20 Wire Range (Group C)(AWG) 22~12 Rated voltage (Group C)(V) 600 Rated current (Group C)(A) 20 CUL Recognized Wire Range (Group B)(AWG) 22~12 Rated voltage (Group B)(V) 600 Rated current (Group B)(A) 20 Wire Range (Group C)(AWG) 22~12 Rated voltage (Group C)(V) 600 Rated current (Group C)(A) 20 VDE Approval Wire Range (mm²) TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 0.14~2.5 3/4 Rated voltage (V) 1000 Rated current (A) 24 Drawings Approvals TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED Powered by TCPDF (www.tcpdf.org) 4/4
DK2.5N-TR 价格&库存
很抱歉,暂时无法提供与“DK2.5N-TR”相匹配的价格&库存,您可以联系我们找货
