DP1.5
DP1.5
    DINKLE(台湾町洋)
    PUSH IN TERM BLK FEED THROUGH 26
DP1.5 数据手册
DP1.5 DIN Rail Terminal Blocks > Push-in Design Date:2020-08-04Version:1.1 The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design. The final product is made according to engineering drawing. Product Description 300V, 15A , Grey(default) General information Short description Category Color DIN Rail terminal blocks , Push-in design Terminal Block Push-in Design Terminal Block Grey(default) Connection method Push in Design Type of locking Rail Mounting Length (mm) 3.5 Width (mm) 46.64 Height (mm) 30.63 Level Connection points Single level 2 Material information Insulation material Insulation material group Flame retardant rating , compliant with UL94 TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED PA I V0 1/4 Insulation resistance ≥500MΩ at DC 500V Connection data-IEC Rated voltage (V) 500 Rated current (A) 17.5 Rated voltage (III/3)(V) 500 Rated impulse voltage (III/3)(KV) 6 Conductor cross section solid. min (mm²) 0.14 Conductor cross section solid.max (mm²) 1.5 Conductor cross section stranded. min (mm²) 0.14 Conductor cross section stranded. max (mm²) 1.5 Conductor cross section flexible, with min ferrule without plastic sleeve (mm²) 0.14 Conductor cross section flexible, with max ferrule without plastic sleeve (mm²) 1.5 Conductor cross section flexible, with min ferrule with plastic sleeve (mm²) 0.14 Conductor cross section flexible, with max ferrule with plastic sleeve (mm²) 1 Slotted screwdriver size (Blade thickness x Width)(mm) 0.4X2.5 Stripping Length (mm) Mounting rail 8 TS-35 End cover plate required YES Grounding connections NO Connection data-UL Rated voltage (UL/CUL Group B)(V) 300 Rated current (UL/CUL Group B)(A) 15 Rated voltage (UL/CUL Group C)(V) 300 Rated current (UL/CUL Group C)(A) 15 Min. solid wire connection (AWG) acc. to UL/CUL 26 Max. solid wire connection AWG acc. to UL/CUL 14 Min. stranded wire connection AWG acc. to UL/CUL 26 Max. stranded wire connection AWG acc. to UL/CUL 14 Environment & Safety Back of the hand protection (YES or NO) TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED YES 2/4 Finger protection (YES or NO) YES Operating temperature. max (°C) 120 Operating temperature. min (°C) -40 UL Recognized Wire Range (Group B)(AWG) 26~14 Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 15 Wire Range (Group C)(AWG) 26~14 Rated voltage (Group C)(V) 300 Rated current (Group C)(A) 15 CUL Recognized Wire Range (Group B)(AWG) 26~14 Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 15 Wire Range (Group C)(AWG) 26~14 Rated voltage (Group C)(V) 300 Rated current (Group C)(A) 15 VDE Approval Wire Range (mm²) 0.14~1.5 Rated voltage (V) 500 Rated current (A) 17.5 Drawings TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 3/4 Approvals TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED Powered by TCPDF (www.tcpdf.org) 4/4
DP1.5
物料型号:DP1.5
器件简介:DINKLE品牌的DIN导轨端子,采用推入式设计,适用于DIN导轨安装。
引脚分配:提供2个连接点。
参数特性: - 额定电压:300V - 额定电流:15A - 工作温度范围:-40°C至120°C - 绝缘材料:PA,符合UL94 V0的阻燃等级 - 绝缘电阻:≥500MΩ(直流500V)
功能详解: - 推入式设计,便于快速接线 - 适用于固体或绞合导线,最小截面积0.14mm²,最大截面积1.5mm² - 需要端盖板 - 不适用于接地连接
应用信息: - 该端子适用于需要DIN导轨安装的电气连接,如自动化设备、控制柜等。
封装信息: - 产品颜色默认为灰色 - 尺寸:长3.5mm、宽46.64mm、高30.63mm - 符合RoHS标准 - 拥有UL、CUL和VDE认证
DP1.5 价格&库存
很抱歉,暂时无法提供与“DP1.5”相匹配的价格&库存,您可以联系我们找货
