DP2.5-PE
DP2.5-PE
    DINKLE(台湾町洋)
    PUSH IN TERM BLK FEED THROUGH 26
DP2.5-PE 数据手册
DP2.5-PE DIN Rail Terminal Blocks > Push-in Design Date:2020-08-04Version:1.1 The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design. The final product is made according to engineering drawing. Product Description 600V, Green-Yellow (default) General information Short description Category Color Connection method Type of locking DIN Rail terminal blocks, Push-in design Terminal Block Push-in Design Terminal Block Green-Yellow (default) Grounding Terminal Block Rail Mounting Length (mm) 5.1 Width (mm) 49 Height (mm) 35.5 Level Connection points Single level 2 Material information Insulation material Insulation material group Flame retardant rating , compliant with UL94 Insulation resistance TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED PA I V0 ≥500MΩ at DC 500V 1/4 Connection data-IEC Rated voltage (V) Rated impulse voltage (III/3)(KV) 800 6 Conductor cross section solid. min (mm²) 0.14 Conductor cross section solid.max (mm²) 4 Conductor cross section stranded. min (mm²) 0.14 Conductor cross section stranded. max (mm²) 2.5 Conductor cross section flexible, with min ferrule without plastic sleeve (mm²) 0.2 Conductor cross section flexible, with max ferrule without plastic sleeve (mm²) 2.5 Conductor cross section flexible, with min ferrule with plastic sleeve (mm²) 0.2 Conductor cross section flexible, with max ferrule with plastic sleeve (mm²) 2.5 2 conductors with same cross section flexible, min twin ferrules with plastic sleeve (mm²) 0.5 2 conductors with same cross section flexible, max twin ferrules with plastic sleeve (mm²) 0.5 Slotted screwdriver size (Blade thickness x Width)(mm) 0.6X3.5 Stripping Length (mm) Mounting rail 10 TS-35 End cover plate required YES Grounding connections YES Connection data-UL Rated voltage (UL/CUL Group B)(V) 600 Rated voltage (UL/CUL Group C)(V) 600 Min. solid wire connection (AWG) acc. to UL/CUL 26 Max. solid wire connection AWG acc. to UL/CUL 12 Min. stranded wire connection AWG acc. to UL/CUL 26 Max. stranded wire connection AWG acc. to UL/CUL 12 Environment & Safety Back of the hand protection (YES or NO) YES Finger protection (YES or NO) YES Operating temperature. max (°C) 120 TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 2/4 Operating temperature. min (°C) -40 UL Recognized Wire Range (Group B)(AWG) Rated voltage (Group B)(V) Wire Range (Group C)(AWG) Rated voltage (Group C)(V) 26~12 600 26~12 600 CUL Recognized Wire Range (Group B)(AWG) Rated voltage (Group B)(V) Wire Range (Group C)(AWG) Rated voltage (Group C)(V) 26~12 600 26~12 600 VDE Approval Wire Range (mm²) 0.14~2.5 Rated voltage (V) 800 Drawings Approvals TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 3/4 TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED Powered by TCPDF (www.tcpdf.org) 4/4
DP2.5-PE 价格&库存
很抱歉,暂时无法提供与“DP2.5-PE”相匹配的价格&库存,您可以联系我们找货
