DP4-TFU(5X20)
DP4-TFU(5X20)
    DINKLE(台湾町洋)
    PUSH IN TERM BLK DISCONNECT 24~1
DP4-TFU(5X20) 数据手册
DP4-TFU(5X20) DIN Rail Terminal Blocks > Push-in Design Date:2020-08-04 The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design. The final product is made according to engineering drawing. Product Description 300V, 12A , Grey(default) General information Short description Category Pitch (mm) Color DIN Rail terminal blocks , Fuse terminal blocks Fuse terminal blocks 6.1 Grey(default) Connection method Push in Design Type of locking Rail Mounting Length (mm) 57 Width (mm) 6.1 Height (mm) 80.5(TS-35N)/88(TS-35/15N) Number of positions Level Connection points 1P Single level 2 Material information Insulation material Insulation material group TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED PA I 1/3 Flame retardant rating , compliant with UL94 Insulation resistance V0 ≥500MΩ at DC 500V Connection data-IEC Rated voltage (V) 400 Rated current (A) 10 Rated voltage (III/3)(V) 400 Rated impulse voltage (III/3)(KV) 6 Conductor cross section solid. min (mm²) 0.2 Conductor cross section solid.max (mm²) 6 Conductor cross section stranded. min (mm²) 0.2 Conductor cross section stranded. max (mm²) 4 Conductor cross section flexible, with min ferrule without plastic sleeve (mm²) 0.25 Conductor cross section flexible, with max ferrule without plastic sleeve (mm²) 4 Conductor cross section flexible, with min ferrule with plastic sleeve (mm²) 0.25 Conductor cross section flexible, with max ferrule with plastic sleeve (mm²) 4 2 conductors with same cross section, stranded, min (mm²) 0.5 2 conductors with same cross section, stranded, max (mm²) 1.0 Philips screwdriver size 0.8x4mm Stripping Length (mm) 12 Mounting rail TS-35N、TS-35/15N End cover plate required YES Grounding connections NO Connection data-UL Rated voltage (UL/CUL Group B)(V) 300 Rated current (UL/CUL Group B)(A) 12 Rated voltage (UL/CUL Group C)(V) 300 Rated current (UL/CUL Group C)(A) 12 Min. solid wire connection (AWG) acc. to UL/CUL 24 Max. solid wire connection AWG acc. to UL/CUL 10 Min. stranded wire connection AWG acc. to UL/CUL 24 TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 2/3 Max. stranded wire connection AWG acc. to UL/CUL 10 Environment & Safety Back of the hand protection (YES or NO) YES Finger protection (YES or NO) YES Operating temperature. max (°C) 120 Operating temperature. min (°C) -40 Drawings Approvals TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED Powered by TCPDF (www.tcpdf.org) 3/3
DP4-TFU(5X20)
物料型号:DP4-TFU(5X20) DIN Rail Terminal Blocks
器件简介:DINKLE品牌的DIN导轨端子排,具有推入式设计。
引脚分配:1P,即1个位置,2个连接点。
参数特性: - 额定电压:300V - 额定电流:12A - 颜色:灰色(默认) - 连接方式:推入式设计 - 尺寸:长57mm,宽6.1mm,高80.5mm(TS-35N)或88mm(TS-35/15N) - 绝缘材料:PA,符合UL94 V0阻燃等级 - 绝缘电阻:DC 500V下大于500MΩ
功能详解:端子排适用于DIN导轨安装,具有背手保护和手指保护功能,操作温度范围为-40°C至+120°C。
应用信息:适用于需要DIN导轨安装的电气连接场合。
封装信息:端子排需要端盖板,不适用于接地连接。
DP4-TFU(5X20) 价格&库存
很抱歉,暂时无法提供与“DP4-TFU(5X20)”相匹配的价格&库存,您可以联系我们找货
