DP6-TR
DP6-TR
    DINKLE(台湾町洋)
    PUSH IN TERM BLK FEED THROUGH 20
DP6-TR 数据手册
DP6-TR DIN Rail Terminal Blocks > Push-in Design Date:2020-08-04Version:V1.1 The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design. The final product is made according to engineering drawing. Product Description 600V, 40A, Grey(default) General information Short description Category Pitch (mm) Color Single level Feed-Through Terminal Block, Push-in Design Single level Feed-Through Terminal Block 8 Grey(default) Connection method Push-in Design Type of locking Rail mounting Length (mm) 8 Width (mm) 91.40 Height (mm) 42 Number of positions Level Connection points ≥1P Single level 4 Material information Insulation material TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED PA 1/4 Insulation material group Flame retardant rating , compliant with UL94 Insulation resistance I V0 />/500MΩ at DC 500V Connection data-IEC Rated voltage (V) 1000 Rated current (A) 41 Rated voltage (II/2)(V) 1000 Rated voltage (III/2) (V) 1000 Rated voltage (III/3)(V) 1000 Rated impulse voltage (II/2)(KV) 8 Rated impulse voltage (III/2)(KV) 8 Rated impulse voltage (III/3)(KV) 8 Conductor cross section solid. min (mm²) 0.5 Conductor cross section solid.max (mm²) 10 Conductor cross section stranded. min (mm²) 0.5 Conductor cross section stranded. max (mm²) 6 Conductor cross section flexible, with min ferrule without plastic sleeve (mm²) 0.5 Conductor cross section flexible, with max ferrule without plastic sleeve (mm²) 6 Conductor cross section flexible, with min ferrule with plastic sleeve (mm²) 0.5 Conductor cross section flexible, with max ferrule with plastic sleeve (mm²) 6 Slotted screwdriver size (Blade thickness x Width)(mm) 0.8×4 Stripping Length (mm) Mounting rail 13 TS-35 End cover plate required YES Grounding connections NO Connection data-UL Rated voltage (UL/CUL Group B)(V) 600 Rated current (UL/CUL Group B)(A) 40 Rated voltage (UL/CUL Group C)(V) 600 Rated current (UL/CUL Group C)(A) 40 Min. solid wire connection (AWG) acc. to UL/CUL 20 TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 2/4 Max. solid wire connection AWG acc. to UL/CUL 8 Min. stranded wire connection AWG acc. to UL/CUL 20 Max. stranded wire connection AWG acc. to UL/CUL 8 Environment & Safety Back of the hand protection (YES or NO) YES Finger protection (YES or NO) YES Operating temperature. max (°C) 120 Operating temperature. min (°C) -40 UL Recognized Wire Range (Group B)(AWG) 20~8 Rated voltage (Group B)(V) 600 Rated current (Group B)(A) 40 Wire Range (Group C)(AWG) 20~8 Rated voltage (Group C)(V) 600 Rated current (Group C)(A) 40 CUL Recognized Wire Range (Group B)(AWG) 20~8 Rated voltage (Group B)(V) 600 Rated current (Group B)(A) 40 Wire Range (Group C)(AWG) 20~8 Rated voltage (Group C)(V) 600 Rated current (Group C)(A) 40 VDE Approval Wire Range (mm²) 0.5~6 Rated voltage (V) 1000 Rated current (A) 41 Drawings TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 3/4 Approvals TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED Powered by TCPDF (www.tcpdf.org) 4/4
DP6-TR 价格&库存
很抱歉,暂时无法提供与“DP6-TR”相匹配的价格&库存,您可以联系我们找货
