EC350V-XXP
PCB Terminal Blocks > PCB Connector-Plug
Date:2021-06-02Version:1.1
The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design.
The final product is made according to engineering drawing.
Product Description
Pitch : 3.50 mm, 300V, 8A
General information
Short description
Category
Pitch (mm)
Color
Connection method
Type of locking
PCB Connector – Plug, Screw Connection
3.50
Green (default)
Screw Connection
Without
Length (mm)
3.50*P
Width (mm)
15.5
Height (mm)
11.1
Number of positions
Level
02P~24P
Single level
Material information
Insulation material
Insulation material group
Flame retardant rating , compliant with UL94
TEL: +886-2-8069-9000 / E-mail: service@dinkle.com
© DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED
PA
I
V0
1/4
Insulation resistance
≥500MΩ at DC 500V
Conductor material
COPPER ALLOY
Plating of conductor surface
Tin PLATED
Connection data-IEC
Rated voltage (V)
320
Rated current (A)
14
Rated voltage (II/2)(V)
320
Rated voltage (III/2) (V)
160
Rated voltage (III/3)(V)
160
Rated impulse voltage (II/2)(KV)
2.5
Rated impulse voltage (III/2)(KV)
2.5
Rated impulse voltage (III/3)(KV)
2.5
Conductor cross section solid. min (mm²)
0.2
Conductor cross section solid.max (mm²)
1.5
Conductor cross section stranded. min (mm²)
0.2
Conductor cross section stranded. max (mm²)
1.5
Conductor cross section flexible, with min ferrule
without plastic sleeve (mm²)
0.25
Conductor cross section flexible, with max ferrule
0.75
Conductor cross section flexible, with min ferrule with
0.25
Conductor cross section flexible, with max ferrule with
0.5
2 conductors with same cross section, solid, min (mm²)
0.2
2 conductors with same cross section, solid, max (mm²)
0.75
2 conductors with same cross section, stranded, min
(mm²)
0.2
2 conductors with same cross section, stranded, max
(mm²)
0.75
2 conductors with same cross section flexible, with min
ferrule without plastic sleeve (mm²)
0.5
2 conductors with same cross section flexible, with max
0.5
2 conductors with same cross section flexible, min twin
ferrules with plastic sleeve (mm²)
0.5
2 conductors with same cross section flexible, max twin
0.5
2/4
Screw thread
Slotted screwdriver size (Blade thickness x Width)(mm)
M2
0.4x2.5
Philips screwdriver size
PH0
Rated torque (N.m)
0.2
Stripping Length (mm)
6~7
Connection data-UL
Rated voltage (UL/CUL Group B)(V)
300
Rated current (UL/CUL Group B)(A)
8
Rated voltage (UL/CUL Group D)(V)
300
Rated current (UL/CUL Group D)(A)
8
Min. solid wire connection (AWG) acc. to UL/CUL
28
Max. solid wire connection AWG acc. to UL/CUL
14
Min. stranded wire connection AWG acc. to UL/CUL
28
Max. stranded wire connection AWG acc. to UL/CUL
14
Environment & Safety
Finger protection (YES or NO)
YES
Operating temperature. max (°C)
120
Operating temperature. min (°C)
-40
UL Recognized
Wire Range (Group B)(AWG)
28~14
Rated voltage (Group B)(V)
300
Rated current (Group B)(A)
8
Wire Range (Group D)(AWG)
28~14
Rated voltage (Group D)(V)
300
Rated current (Group D)(A)
8
CUL Recognized
28~14
300
8
Wire Ranget (Group D)(AWG)
28~14
300
3/4
8
VDE Approval
Wire Range (mm²)
0.2~1.5
Rated voltage (V)
320
Rated current (A)
14
Drawings
Approvals
Powered by TCPDF (www.tcpdf.org)
4/4
很抱歉,暂时无法提供与“EC350V-08P-BK”相匹配的价格&库存,您可以联系我们找货
