ECH116R-06P
ECH116R-06P
    DINKLE(台湾町洋)
    插件,P=10.16mm
    接线端子 间距:10.16mm 直插
ECH116R-06P 数据手册
ECH116R-XXP PCB Terminal Blocks > PCB Connector-Socket Date:2021-10-04Version:V1 The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design. The final product is made according to engineering drawing. Product Description Pitch : 10.16mm, 300V, 51A General information Short description Category Pitch (mm) Color Type of locking Soldering method PCB Connector – Socket, Wave soldering PCB Connector – Socket 10.16 Green (default) Without Wave soldering Length (mm) 10.16*(P-1)+10.16 Width (mm) 32 Height (mm) 13.7 Pin demensions (Thickness x Width)(mm) 1.0x1.2 PCB hole diameter (mm) 1.75~1.85 Number of positions 02P~10P Level Single level Material information Insulation material TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED PA 1/3 Insulation material group Flame retardant rating , compliant with UL94 I V0 Insulation resistance ≥500MΩ at DC 500V Conductor material COPPER ALLOY Plating of conductor surface Ag PLATED Connection data-IEC Rated voltage (V) 1000 Rated current (A) 76 Rated voltage (II/2)(V) 1000 Rated voltage (III/2) (V) 1000 Rated voltage (III/3)(V) 630 Rated impulse voltage (II/2)(KV) 8 Rated impulse voltage (III/2)(KV) 8 Rated impulse voltage (III/3)(KV) 8 Connection data-UL Rated voltage (UL/CUL Group B)(V) 300 Rated current (UL/CUL Group B)(A) 51 Rated voltage (UL/CUL Group D)(V) 600 Rated current (UL/CUL Group D)(A) 5 Environment & Safety Finger protection (YES or NO) YES Operating temperature. max (°C) 120 Operating temperature. min (°C) -40 UL Recognized Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 5 Rated voltage (Group D)(V) 600 Rated current (Group D)(A) 5 CUL Recognized Rated voltage (Group B)(V) TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 300 2/3 Rated current (Group B)(A) 5 Rated voltage (Group D)(V) 600 Rated current (Group D)(A) 5 VDE Approval Rated voltage (V) 1000 Rated current (A) 76 Drawings Approvals TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED Powered by TCPDF (www.tcpdf.org) 3/3
ECH116R-06P 价格&库存
很抱歉,暂时无法提供与“ECH116R-06P”相匹配的价格&库存,您可以联系我们找货
