ECH381R-XXP
PCB Terminal Blocks > PCB Connector-Socket
Date:2023-01-26Version:V1
The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design.
The final product is made according to engineering drawing.
Product Description
Pitch : 3.81 mm, 300V, 8A
General information
Short description
Category
Pitch (mm)
Color
Type of locking
PCB Connector – Socket, Wave soldering
3.81
Green (default)
Without
Soldering method
Wave soldering
Length (mm)
3.81*(P-1)+4.6
Width (mm)
9.2
Height (mm)
7.2
Pin demensions (Thickness x Width)(mm)
0.8x0.8
PCB hole diameter (mm)
1.2~1.3
Number of positions
Level
02P~24P
Single level
Material information
Insulation material
TEL: +886-2-8069-9000 / E-mail: service@dinkle.com
© DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED
PA
1/3
Insulation material group
Flame retardant rating , compliant with UL94
I
V0
Insulation resistance
≥500MΩ at DC 500V
Conductor material
COPPER ALLOY
Plating of conductor surface
Tin PLATED
Connection data-IEC
Rated voltage (V)
320
Rated current (A)
14
Rated voltage (II/2)(V)
320
Rated voltage (III/2) (V)
160
Rated voltage (III/3)(V)
160
Rated impulse voltage (II/2)(KV)
2.5
Rated impulse voltage (III/2)(KV)
2.5
Rated impulse voltage (III/3)(KV)
2.5
Connection data-UL
Rated voltage (UL/CUL Group B)(V)
300
Rated current (UL/CUL Group B)(A)
8
Rated voltage (UL/CUL Group D)(V)
300
Rated current (UL/CUL Group D)(A)
8
Environment & Safety
Finger protection (YES or NO)
YES
Operating temperature. max (°C)
120
Operating temperature. min (°C)
-40
UL Recognized
Rated voltage (Group B)(V)
300
Rated current (Group B)(A)
8
Rated voltage (Group D)(V)
300
Rated current (Group D)(A)
8
CUL Recognized
300
2/3
8
300
8
VDE Approval
Rated voltage (V)
320
Rated current (A)
14
Drawings
Approvals
Powered by TCPDF (www.tcpdf.org)
3/3
很抱歉,暂时无法提供与“ECH381R-08P”相匹配的价格&库存,您可以联系我们找货
