ECH381VM-10P
ECH381VM-10P
    DINKLE(台湾町洋)
    插件,P=3.81mm
    接线端子 间距:3.81mm 1x10P 直插
ECH381VM-10P 数据手册
ECH381VM-XXP PCB Terminal Blocks > PCB Connector-Socket Date:2021-09-09Version:V1 The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design. The final product is made according to engineering drawing. Product Description Pitch : 3.81 mm, 300V, 8A General information Short description Category Pitch (mm) Color Type of locking PCB Connector – Socket, Wave soldering PCB Connector – Socket 3.81 Green (default) With threaded flange Soldering method Wave soldering Length (mm) 3.81*(P-1)+14.4 Width (mm) 7.2 Height (mm) 9.2 Pin demensions (Thickness x Width)(mm) 0.8x0.8 PCB hole diameter (mm) 1.2~1.3 Number of positions Level 02P~24P Single level Material information Insulation material TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED PA 1/3 Insulation material group Flame retardant rating , compliant with UL94 I V0 Insulation resistance ≥500MΩ at DC 500V Conductor material COPPER ALLOY Plating of conductor surface Tin PLATED Connection data-IEC Rated voltage (V) 320 Rated current (A) 14 Rated voltage (II/2)(V) 320 Rated voltage (III/2) (V) 160 Rated voltage (III/3)(V) 160 Rated impulse voltage (II/2)(KV) 2.5 Rated impulse voltage (III/2)(KV) 2.5 Rated impulse voltage (III/3)(KV) 2.5 Tightening torque with flange. max (N.m) 0.3 Connection data-UL Rated voltage (UL/CUL Group B)(V) 300 Rated current (UL/CUL Group B)(A) 8 Rated voltage (UL/CUL Group D)(V) 300 Rated current (UL/CUL Group D)(A) 8 Environment & Safety Finger protection (YES or NO) YES Operating temperature. max (°C) 120 Operating temperature. min (°C) -40 UL Recognized Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 8 Rated voltage (Group D)(V) 300 Rated current (Group D)(A) 8 CUL Recognized TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 2/3 Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 8 Rated voltage (Group D)(V) 300 Rated current (Group D)(A) 8 VDE Approval Rated voltage (V) 320 Rated current (A) 14 Drawings Approvals TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED Powered by TCPDF (www.tcpdf.org) 3/3
ECH381VM-10P 价格&库存
很抱歉,暂时无法提供与“ECH381VM-10P”相匹配的价格&库存,您可以联系我们找货
