ECH762R-03P
ECH762R-03P
    DINKLE(台湾町洋)
    插件,P=7.62mm
    接线端子 间距:7.62mm 插件
ECH762R-03P 数据手册
ECH762R-XXP PCB Terminal Blocks > PCB Connector-Socket Date:2021-10-04Version:V1 The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design. The final product is made according to engineering drawing. Product Description Pitch : 7.62 mm, 300V, 30A General information Short description Category Pitch (mm) Color Type of locking PCB Connector – Socket, Wave soldering PCB Connector – Socket 7.62 Green (default) Without Soldering method Wave soldering Length (mm) 7.62*(P-1)+7.62 Width (mm) 29 Height (mm) 14.3 Pin demensions (Thickness x Width)(mm) 0.8x1.0 PCB hole diameter (mm) 1.5~1.6 Number of positions Level 02P~12P Single level Material information Insulation material TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED PBT 1/3 Insulation material group IIIa Flame retardant rating , compliant with UL94 V0 Insulation resistance ≥1000MΩ at DC 500V Conductor material COPPER ALLOY Plating of conductor surface Tin PLATED Connection data-IEC Rated voltage (V) 1000 Rated current (A) 41 Rated voltage (II/2)(V) 1000 Rated voltage (III/2) (V) 630 Rated voltage (III/3)(V) 500 Rated impulse voltage (II/2)(KV) 6 Rated impulse voltage (III/2)(KV) 6 Rated impulse voltage (III/3)(KV) 6 Connection data-UL Rated voltage (UL/CUL Group B)(V) 300 Rated current (UL/CUL Group B)(A) 30 Rated voltage (UL/CUL Group D)(V) 300 Rated current (UL/CUL Group D)(A) 10 Environment & Safety Finger protection (YES or NO) YES Operating temperature. max (°C) 120 Operating temperature. min (°C) -40 UL Recognized Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 30 Rated voltage (Group D)(V) 300 Rated current (Group D)(A) 10 CUL Recognized Rated voltage (Group B)(V) TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 300 2/3 Rated current (Group B)(A) 30 Rated voltage (Group D)(V) 300 Rated current (Group D)(A) 10 VDE Approval Rated voltage (V) 1000 Rated current (A) 41 Drawings Approvals TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED Powered by TCPDF (www.tcpdf.org) 3/3
ECH762R-03P 价格&库存
很抱歉,暂时无法提供与“ECH762R-03P”相匹配的价格&库存,您可以联系我们找货
