ED350V-05P
ED350V-05P
    DINKLE(台湾町洋)
    插件,P=3.5mm
    接线端子 3.5mm 直插 每排Pin数:5
ED350V-05P 数据手册
ED350V-XXP PCB Terminal Blocks > PCB Terminal Blocks Date:2021-05-19Version:V1 The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design. The final product is made according to engineering drawing. Product Description Pitch : 3.50mm , 300V , 10A General information Short description Category Pitch (mm) Color Connection method Type of locking PCB Terminal Blocks , Wire Protector Type PCB Terminal Blocks 3.5 Green(default) Wire Protector Type Without Length (mm) 3.50xP Width (mm) 6.8 Height (mm) 8.4 Pin demensions (Thickness x Width)(mm) Ø0.77 PCB hole diameter (mm) 1.0~1.2 Number of positions 02~21 Level Single level Material information Insulation material TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED PA 1/4 Insulation material group Flame retardant rating , compliant with UL94 Conductor material Plating of conductor surface I V0 Copper Alloy Tinned Connection data-IEC Rated voltage (V) 130 Rated current (A) 10 Rated voltage (II/2)(V) 320 Rated voltage (III/2) (V) 160 Rated voltage (III/3)(V) 160 Rated impulse voltage (II/2)(KV) 2.5 Rated impulse voltage (III/2)(KV) 2.5 Rated impulse voltage (III/3)(KV) 2.5 Conductor cross section solid. min (mm²) 0.5 Conductor cross section solid.max (mm²) 1.5 Conductor cross section stranded. min (mm²) 0.5 Conductor cross section stranded. max (mm²) 1.5 Conductor cross section flexible, with min ferrule without plastic sleeve (mm²) 0.25 Conductor cross section flexible, with max ferrule without plastic sleeve (mm²) 1.5 Conductor cross section flexible, with min ferrule with plastic sleeve (mm²) 0.25 Conductor cross section flexible, with max ferrule with plastic sleeve (mm²) 1.5 2 conductors with same cross section, solid, max (mm²) 0.75 2 conductors with same cross section, stranded, max (mm²) 0.75 Screw thread M2 Rated torque (N.m) 0.2 Stripping Length (mm) 5~6 Connection data-UL Rated voltage (UL/CUL Group B)(V) 300 Rated current (UL/CUL Group B)(A) 10 Min. solid wire connection (AWG) acc. to UL/CUL 24 TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 2/4 Max. solid wire connection AWG acc. to UL/CUL 16 Min. stranded wire connection AWG acc. to UL/CUL 24 Max. stranded wire connection AWG acc. to UL/CUL 18 Environment & Safety Finger protection (YES or NO) YES Operating temperature. max (°C) 115 Operating temperature. min (°C) -40 UL Recognized Wire Range (Group B)(AWG) 24~16 Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 10 CUL Recognized Wire Range (Group B)(AWG) 24~16 Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 10 VDE Approval Wire Range (mm²) 0.5~1.5 Rated voltage (V) 130 Rated current (A) 10 Drawings TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 3/4 Approvals TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED Powered by TCPDF (www.tcpdf.org) 4/4
ED350V-05P 价格&库存
很抱歉,暂时无法提供与“ED350V-05P”相匹配的价格&库存,您可以联系我们找货
