EHK2V-03P
EHK2V-03P
    DINKLE(台湾町洋)
    插件
    接线端子 5.08mm 插件 每排Pin数:3
EHK2V-03P 数据手册
EHK2V-XXP PCB Terminal Blocks > PCB Terminal Blocks Date:2022-06-09Version:V1 The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design. The final product is made according to engineering drawing. Product Description Pitch : 5.08mm, 300V, 25A General information Short description Category Pitch (mm) Color Connection method Type of locking PCB Terminal Blocks, Screw Connection PCB Terminal Blocks 5.08 Green (default) Screw Connection Without Length (mm) 5.08*(P-1)+5.08 Width (mm) 11.2 Height (mm) 18 Pin demensions (Thickness x Width)(mm) PCB hole diameter (mm) Number of positions Level 0.7x1.1 1.6 02P~24P Single level Material information Insulation material TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED PA 1/4 Insulation material group Flame retardant rating , compliant with UL94 I V0 Insulation resistance ≥500MΩ at DC 500V Conductor material COPPER ALLOY Plating of conductor surface Tin PLATED Connection data-IEC Rated voltage (V) 320 Rated current (A) 24 Rated voltage (II/2)(V) 630 Rated voltage (III/2) (V) 320 Rated voltage (III/3)(V) 320 Rated impulse voltage (II/2)(KV) 4 Rated impulse voltage (III/2)(KV) 4 Rated impulse voltage (III/3)(KV) 4 Conductor cross section solid. min (mm²) 0.2 Conductor cross section solid.max (mm²) 2.5 Conductor cross section stranded. min (mm²) 0.2 Conductor cross section stranded. max (mm²) 2.5 Conductor cross section flexible, with min ferrule without plastic sleeve (mm²) 0.25 Conductor cross section flexible, with max ferrule without plastic sleeve (mm²) 2.5 Conductor cross section flexible, with min ferrule with plastic sleeve (mm²) 0.25 Conductor cross section flexible, with max ferrule with plastic sleeve (mm²) 2.5 2 conductors with same cross section, solid, min (mm²) 0.5 2 conductors with same cross section, solid, max (mm²) 1.5 2 conductors with same cross section, stranded, min (mm²) 0.5 2 conductors with same cross section, stranded, max (mm²) 1.5 Screw thread Slotted screwdriver size (Blade thickness x Width)(mm) M2.5 0.6x3.5 Rated torque (N.m) 0.45 Stripping Length (mm) 7~8 TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 2/4 Connection data-UL Rated voltage (UL/CUL Group B)(V) 300 Rated current (UL/CUL Group B)(A) 25 Rated voltage (UL/CUL Group D)(V) 300 Rated current (UL/CUL Group D)(A) 10 Min. solid wire connection (AWG) acc. to UL/CUL 24 Max. solid wire connection AWG acc. to UL/CUL 12 Min. stranded wire connection AWG acc. to UL/CUL 24 Max. stranded wire connection AWG acc. to UL/CUL 12 Environment & Safety Finger protection (YES or NO) YES Operating temperature. max (°C) 120 Operating temperature. min (°C) -40 UL Recognized Wire Range (Group B)(AWG) 24~12 Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 25(FW1)/20(FW2) CUL Recognized Wire Range (Group B)(AWG) 24~12 Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 25(FW1)/20(FW2) VDE Approval Wire Range (mm²) 0.2~2.5 Rated voltage (V) 300 Rated current (A) 24 Drawings TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 3/4 Approvals TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED Powered by TCPDF (www.tcpdf.org) 4/4
EHK2V-03P 价格&库存
很抱歉,暂时无法提供与“EHK2V-03P”相匹配的价格&库存,您可以联系我们找货
