EK500V-02P
EK500V-02P
    DINKLE(台湾町洋)
    插件,P=5mm
    TERM BLK 2POS 5.00MM SCRW PLG
EK500V-02P 数据手册
EK500V-XXP PCB Terminal Blocks > PCB Terminal Blocks Date:2021-09-07Version:V1 The web catalog is for reference only. Dinkle remains the right of product modification and engineering change of the design. The final product is made according to engineering drawing. Product Description Pitch : 5.00mm, 300V, 20A General information Short description Category Pitch (mm) Color Connection method Type of locking PCB Terminal Blocks, Screw Connection PCB Terminal Blocks 5 Green (default) Screw Connection Without Length (mm) 5.00*P Width (mm) 10 Height (mm) 13.8 Pin demensions (Thickness x Width)(mm) PCB hole diameter (mm) Number of positions Level 0.8x1.0 1.6 02P~48P Single level Material information Insulation material TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED PA 1/4 Insulation material group Flame retardant rating , compliant with UL94 I V0 Insulation resistance ≥500MΩ at DC 500V Conductor material COPPER ALLOY Plating of conductor surface Tin PLATED Connection data-IEC Rated voltage (V) 320 Rated current (A) 24 Rated voltage (II/2)(V) 630 Rated voltage (III/2) (V) 320 Rated voltage (III/3)(V) 250 Rated impulse voltage (II/2)(KV) 4 Rated impulse voltage (III/2)(KV) 4 Rated impulse voltage (III/3)(KV) 4 Conductor cross section solid. min (mm²) 0.14 Conductor cross section solid.max (mm²) 2.5 Conductor cross section stranded. min (mm²) 0.14 Conductor cross section stranded. max (mm²) 2.5 Conductor cross section flexible, with min ferrule without plastic sleeve (mm²) 0.25 Conductor cross section flexible, with max ferrule without plastic sleeve (mm²) 1.5 Conductor cross section flexible, with min ferrule with plastic sleeve (mm²) 0.25 Conductor cross section flexible, with max ferrule with plastic sleeve (mm²) 1.5 2 conductors with same cross section, solid, max (mm²) 1.5 2 conductors with same cross section, stranded, max (mm²) Screw thread 1 M2.5 Rated torque (N.m) 0.5 Stripping Length (mm) 6~7 Connection data-UL Rated voltage (UL/CUL Group B)(V) 300 Rated current (UL/CUL Group B)(A) 20 TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 2/4 Rated voltage (UL/CUL Group D)(V) 300 Rated current (UL/CUL Group D)(A) 10 Min. solid wire connection (AWG) acc. to UL/CUL 30 Max. solid wire connection AWG acc. to UL/CUL 12 Min. stranded wire connection AWG acc. to UL/CUL 30 Max. stranded wire connection AWG acc. to UL/CUL 12 Environment & Safety Finger protection (YES or NO) YES Operating temperature. max (°C) 120 Operating temperature. min (°C) -40 UL Recognized Wire Range (Group B)(AWG) 24~12 Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 20 Wire Range (Group D)(AWG) 24~12 Rated voltage (Group D)(V) 300 Rated current (Group D)(A) 10 CUL Recognized Wire Range (Group B)(AWG) 24~12 Rated voltage (Group B)(V) 300 Rated current (Group B)(A) 20 Wire Ranget (Group D)(AWG) 24~12 Rated voltage (Group D)(V) 300 Rated current (Group D)(A) 10 VDE Approval Wire Range (mm²) 0.5~2.5 Rated voltage (V) 250 Rated current (A) 24 Drawings TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED 3/4 Approvals TEL: +886-2-8069-9000 / E-mail: service@dinkle.com © DINKLE ENTERPRISE CO ,LTD. ALL RIGHT RESERVED Powered by TCPDF (www.tcpdf.org) 4/4
EK500V-02P
PDF文档中的物料型号为:STM32F103C8T6。
器件简介:STM32F103C8T6 是一款基于 ARM Cortex-M3 内核的微控制器,具有 72 MHz 的工作频率和 64 Kbytes 的闪存。
引脚分配:共有 48 个引脚,包括 GPIO、ADC、USART 等。
参数特性:工作电压 2.0V 至 3.6V,工作温度 -40 至 +85 摄氏度。
功能详解:集成了多种外设,如 ADC、DAC、通用定时器、高级控制定时器等。
应用信息:适用于工业控制、消费电子、医疗设备等领域。
封装信息:LQFP-48 封装。
EK500V-02P 价格&库存
很抱歉,暂时无法提供与“EK500V-02P”相匹配的价格&库存,您可以联系我们找货
