EK-3625-2J
EK-3625-2J
    DOODLELABS
    - RM-3625 收发器 3.5GHz 评估板
EK-3625-2J 数据手册
EK-3625-2J Evaluation Kit Datasheet Smart Radio Evaluation Kit (-2J Models) EK-3625-2J Overview The Doodle Labs Evaluation Kit is designed to simplify bench testing and preliminary field testing of Doodle Labs Smart Radios. It contains: - 2 x 3.6 GHz Antennas 2 x Attenuators 1 x Ethernet Test Board (for -2J models) 2 x MMCX to SMA cables 2 x 12 pin cable 1 x Heatsink 1 x Thermal Pad For Design-In Documentation, including Integration and Configuration Guides, please visit Doodle Labs’ Technical Library. Bench Testing with an Attenuator The provided attenuators reduce the voltage and dissipate transmit power, optimizing the setup for indoor bench testing. Without the attenuators, testing in close proximity may result in link saturation, which may result in inaccurate results. For field testing, attenuators are not recommended as they impede the output performance of the Smart Radio at longer distances. ©2020 Doodle Labs. All rights reserved. Updated November 2020 1 EK-3625-2J Evaluation Kit Datasheet Steps for connecting the Attenuator 1. Connect the MMCX Female end of the cable to the MMCX male ports of the Smart Radio. 2. Take the opposite end of the cable and connect it to the SMA port Attenuator. 3. Attach the Antenna to the other end of the Attenuator. Complete Evaluation Kit Setup 2J Ethernet Test Kit 12 pin cables Antennas Smart Radio Attenuators MMCX to SMA Female cables ©2020 Doodle Labs. All rights reserved. Updated November 2020 2
EK-3625-2J 价格&库存
很抱歉,暂时无法提供与“EK-3625-2J”相匹配的价格&库存,您可以联系我们找货
