3000-1/25
3000-1/25
    DREMEL
    DREMEL 3000 ROTARY TOOL 1 ATTACH
3000-1/25 数据手册
        3000 1/25 120V Rotary Tool Kit Model # 3000‐1/25 Product Specifications The Dremel 3000 is the result of upgrading our most popular rotary tool using user‐ requested features to improve the tool’s design and ergonomics. The tool also features the EZ Twist™ nose cap with an integrated wrench that allows the nose cap to be used as a wrench to tighten accessories and eliminates the need for a separate wrench. A more efficient fan design and side vents provide a cooler running tool making it comfortable for extended periods of use. The tool also features a symmetrical design including a trumpet‐ shaped nose cap to facilitate a pencil‐grip tool hold. The ability to use all existing Dremel rotary tool accessories and most attachments let the 3000 complete a wide range of applications including cutting, grinding, sanding, carving and polishing a variety of materials.      EZ Twist™ nose cap with wrench for fast accessory changes  Variable speed from 5,000 to 35,000 RPM  Can be used with all Dremel rotary tool accessories and most attachments  Cool‐running ball bearing construction for smooth and quiet operation  Replaceable motor brushes extend tool life  Two year warranty   DIMENSIONS   Cord Length: 6[ft] Speed: Variable (5,000 ‐ 35,000 RPM) Tool Level: 1 ‐ Corded – variable speed high Weight: 3.24[kg, lb, oz] Model Number: 3000‐1/25 Amperage: 1.2 Length: 7.5["] Warranty: Limited 2 Years Voltage: 120V Height: 2["]   Contents: Rotary Tool, (1) Attachment, (25) Dremel Accessories, Plastic Case, Accessory Case, Manuals Width: 2.5["]                                                    https://www.dremel.com/en_US/products/‐/show‐product/tools/3000‐1‐25‐3000‐1‐25‐120v‐rotary‐tool‐kit 10‐12‐18
3000-1/25 价格&库存
很抱歉,暂时无法提供与“3000-1/25”相匹配的价格&库存,您可以联系我们找货
