3000-2/28
3000-2/28
    DREMEL
    DREMEL 3000 ROTARY TOOL 2 ATTACH
3000-2/28 数据手册
    3000‐2/28 Variable‐Speed Tool Kit  Model # 3000‐2/28 Product Specifications The Dremel 3000 Series variable‐speed rotary tool kit gives DIY‐ers everything they need to tackle projects around the house. It includes our most popular rotary tool, which boasts a range of user‐requested features that improve the tool’s design and ergonomics. Just a few of the improvements include the EZ Twist™ nose cap with an integrated wrench that allows the nose cap to be used as a wrench to tighten accessories, and a more efficient fan design and side vents provide a cooler‐running tool that's comfortable for extended periods of use. In addition, the 3000 Series tool features a symmetrical design and a trumpet‐shaped nose cap to help facilitate a pencil‐grip tool hold. It's also compatible with all existing Dremel rotary tool accessories and most attachments, so you can use the 3000 in a wide range of applications, including cutting, grinding, sanding, carving and polishing.      EZ Twist™ nose cap with wrench for fast accessory changes  Variable speed from 5,000 to 35,000 RPM  Can be used with all Dremel rotary tool accessories and most attachments  Cool‐running ball bearing construction for smooth and quiet operation  Replaceable motor brushes extend tool life DIMENSIONS Speed: Variable (5,000 ‐ 35,000 RPM) Contents: Rotary Tool, (2) Attachments, (28) Dremel Accessories, Plastic Case and Manual Warranty: Limited 2 Years Cord Length: 6[ft] Length: 7.5["] Voltage: 120V Amperage: 1.2 Height: 2["] Width: 2.5["] Weight: 3.37[kg, lb, oz] Tool Level: 1 ‐ Corded – variable speed high             https://www.dremel.com/en_US/products/‐/show‐product/tools/3000‐2‐28‐variable‐speed‐tool‐kit?bvroute=Reviews%2FshowHelpfulPositive 10‐16‐18
3000-2/28 价格&库存
很抱歉,暂时无法提供与“3000-2/28”相匹配的价格&库存,您可以联系我们找货
