4000-4/34
4000-4/34
    DREMEL
    4000 SERIES RT, STORAGE CASE, CI
4000-4/34 数据手册
  4000-4/34 High Performance Rotary Tool Kit Model # 4000-4/34 Product Specifications The Dremel 4000 variable speed rotary tool is one of the highest performance and most versatility of all Dremel rotary tools. The increased strength of its motor plus electronic feedback circuitry enables consistent performance at all speed levels. Dremel 4000 can use all existing Dremel rotary tool accessories and attachments plus high-performance attachments to complete the widest range of projects. A slim, ergonomic body provides a 360-degree grip zone for comfort and control in any grip position. The Dremel 4000 comes with a two-year warranty.              High-performance motor for maximum performance at all speeds Electronic feedback for consistent speed under load Variable speed provides maximum control and precision Separate on/off switch and speed control dial for the perfect speed every time Can be used with all Dremel rotary tool attachments and accessories Quick collet lock for fast accessory changes Cool-running ball bearing construction for smooth and quiet operation Replaceable motor brushes extend tool life Two year warranty DIMENSIONS Cord Length: 6[ft] Speed: Variable (5,000 - 35,000 RPM) Tool Level: 1 - Corded – variable speed high 1.3[kg, lb, oz] Weight: Amperage: 1.6 Length: 9["] Warranty: Limited 2 Years Voltage: 120V 2["] Height: Rotary Tool, (4) Attachments, (34) Genuine Dremel Accessories, Deluxe Contents: Carrying Case, Accessory Case, Manuals Width: 2.5["] Speed Range: 5,000 - 35,000 RPM https://www.dremel.com/en_US/products/-/show-product/tools/4000-4-34-high-performance-rotary-tool-kit?bvstate=pg:2/ct:r 10-10-18
4000-4/34 价格&库存
很抱歉,暂时无法提供与“4000-4/34”相匹配的价格&库存,您可以联系我们找货
