4300-5/40
4300-5/40
    DREMEL
    4300-5/40 120V ROTARY TOOL
4300-5/40 数据手册
          Dremel 4300‐5/40 Model # 4300‐5/40  Product Specifications The Dremel 4300 is the first Dremel rotary tool to allow tool‐less and collet‐less accessory changes with the inclusion of the three‐jaw chuck. The chuck accepts all Dremel accessory shank sizes for fast and convenient accessory changes without ever using a wrench. Featuring the all new Pivot Light, your projects are well‐lit with an optimum line of sight since the light pivots to direct illumination where you want it. Experiencing the full range of Dremel rotary tool applications is easier than ever because the 4300 offers our most powerful motor with built‐in variable speed and electronic feedback circuitry. And the slim, ergonomic body design provides a comfortable 360‐degree grip zone no matter how you hold it for extended ease of use. The completely redesigned airflow system lets the Dremel 4300 run cool, quiet, and smooth so completing projects are more enjoyable than ever.  Pivot light rotates to illuminate your project  Universal 3‐jaw chuck for easy accessory changes  Quieter and cooler running due to improved air flow      Our most powerful motor for maximum performance in demanding applications  Compatible with all Dremel rotary tool attachments and accessories (*some applications require the use of a collet system, included in kit)  Variable‐speed with electronic feedback for consistent performance in all applications  Separate on/off switch and speed control dial for added convenience between jobs  Replaceable motor brushes extend tool life  Cool‐running ball bearing construction for smooth and quiet operation  Industry leading customer support  Two‐year warranty   DIMENSIONS   Speed: Variable (5,000 ‐ 35,000 RPM) Contents: Dremel 4300 high performance rotary tool, Pivot Light, A550 Shield attachment redirects debris and sparks during cutting, grinding, sanding, and polishing applications, A576 Sanding/Grinding Guide attachment for increased control during sanding and grinding application, 565 Cutting Guide attachment turns your rotary tool into a rotary saw, 675 Garden Tool Sharpener attachment sharpens your lawn mower blade and garden tools, Storage Case for superior attachment and accessory organization, 40 Genuine Dremel accessories with Mini case Warranty: Limited 2 Years Cord Length: 6[ft] Length: 9["]   Voltage: 120V Amperage: 1.8 Height: 2["] Speed Range: 5,000 ‐ 35,000 RPM Width: 2["] Weight: 1.175[kg, lb, oz] Tool Level: 1 ‐ Corded – variable speed high                                     https://www.dremel.com/en_US/products/‐/show‐product/tools/dremel‐4300‐5‐40 10‐16‐18
4300-5/40 价格&库存
很抱歉,暂时无法提供与“4300-5/40”相匹配的价格&库存,您可以联系我们找货
