520-02 1/2" SIC Impregnated Wheels
Model # 520-02
Product Specifications
A polishing wheel for your rotary tool that has the polishing compound inside. The 520-02
polishing wheel is impregnated with a silicon carbide abrasive and lubricant, eliminating
the need for polishing compound. Easy to use and less messy, the 520-02 is perfect for
high-luster polishing. Pack includes two polishing wheel accessories. Please click here to
see the recommended speed settings for our accessories.
Click here to view the Dremel Speed Chart
Click here to view our Carving and Engraving Accessories Recommended Speed
Settings
Click here to view our Cleaning and Polishing Accessories Recommended Speed
Settings
Click here to view our Cutting Accessories Recommended Speed Settings
Click here to view our Grinding and Sharpening Accessories Recommended Speed
Settings
Click here to view our Routing Accessories Recommended Speed Settings
Click here to view our Sanding Accessories Recommended Speed Settings
Designed for light stock removal and high luster polishing
Works on a variety of surfaces including steel, aluminum, brass, silver, hard plastics, gold and
other metals
Impregnated with silicone abrasive and lubricant
Eliminates the need for polishing compound
DIMENSIONS
Shank Size US:
1/8["]
Contents:
2 Bits
Warranty:
Product Defects Only
Description:
Polishing wheel
Tip size US:
1/2"
Color Code:
Yellow
Overall Length:
3
Material:
Silicone Carbide Abrasive
Shank Size mm:
3.2[mm]
Tip Size mm:
12.7 mm
https://www.dremel.com/en/products/-/show-product/tools/520-02-1-2-sic-impregnated-wheels-2pk 10-16-18
很抱歉,暂时无法提供与“520-02”相匹配的价格&库存,您可以联系我们找货
