628-01
628-01
    DREMEL
    628-01 7 PC. DRILL BIT SET
628-01 数据手册
628-01 Drill Bit Set Model # 628-01 Product Specifications Our set of seven high-speed rotary drill bits ideal for drilling into wood, plastics and soft metals. Includes sizes (in inches): 1/32, 3/64, 1/16, 5/64, 3/32, 7/64 and 1/8. You will require the use of the 4486 Dremel chuck or the 480, 481, 482 and 483 collets. Made of high-grade stainless steel. Click here to view the Dremel Speed Chart Click here to view our Carving and Engraving Accessories Recommended Speed Settings Click here to view our Cleaning and Polishing Accessories Recommended Speed Settings Click here to view our Cutting Accessories Recommended Speed Settings Click here to view our Grinding and Sharpening Accessories Recommended Speed Settings Click here to view our Routing Accessories Recommended Speed Settings Click here to view our Sanding Accessories Recommended Speed Settings • Ideal for drilling • Use on wood, plastics and soft metals • Set of seven high-speed drill bits • Made from high-grade steel DIMENSIONS Bit Diameter mm: (1) 0.8 mm; (1) 1.2 mm; (1) 1.6 mm; (1) 2.0 mm; (1) 2.4 mm; (1) 2.8 mm; (1) 3.2 mm Description: Drill Bit Set Warranty: Product Defects Only Contents: 7 Assorted Drill Bits Color Code: DimGray Bit Diameter Inch: (1) 1/32"; (1) 3/64"; (1) 1/16"; (1) 5/64"; (1) 3/32"; (1) 7/64"; (1) 1/8" https://www.dremel.com/en_US/products/-/show-product/accessories/628-01-drill-bit-set 10-15-18
628-01 价格&库存
很抱歉,暂时无法提供与“628-01”相匹配的价格&库存,您可以联系我们找货
    • 1+121.978891+15.80054
    库存:5
