670-01
670-01
    DREMEL
    670-01 MINI SAW ATTACHMENT
670-01 数据手册
                            670‐01 Mini Saw Attachment Model # 670‐01  Product Specifications The 670 mini saw attachment is a unique, innovative rotary tool accessory that allows you to cut through wood and wood‐like materials as never before. Attaches to the rotary tool in seconds and makes clean, straight, perpendicular cuts up to ¼ In. thick. Can be used for DIY projects, hobbies, crafts and modeling.  Quick connect attach system  Make clean, straight perpendicular cuts up to 1/4 In. thick  Clear housing provides better visibility  Lower guard retracts when not in use to ensure safety  Full‐length magnetic strip     DIMENSIONS Fits Tool Model:: Dremel models: 4300, 4200*, 4000, 400, 3000, 300, 398, 395, 200, 285, 100, 275, 8220, 8200, 8100, 800. *Compatible with the 4200 when used with the 4200 Attachment Adapter found in your Dremel 4200 kit. Blade Diameter: 1.25 Warranty: Product Defects Only Material: Plastic,metal Stroke Length: 0.25 Contents: Mini Saw Attachment, (1) Blade Size: 2                                       https://www.dremel.com/en_US/products/‐/show‐product/tools/670‐01‐mini‐saw‐attachment 10‐12‐18
670-01 价格&库存
很抱歉,暂时无法提供与“670-01”相匹配的价格&库存,您可以联系我们找货
    • 4+328.861294+42.56767
