7300-PT
7300-PT
    DREMEL
    PET GROOMING KIT (4.8V NI-CD 2-
7300-PT 数据手册
  7300-PT 4.8V Pet Grooming Kit Model # 7300-PT Product Specifications The use of dog nail clippers can be painful for your pet. Dremel simplifies pet grooming for owners and animals with this cordless Pet Nail Rotary Tool. This kit allows you to quickly, easily and safely trim your pet's nails. The rechargeable, battery-powered device uses a 60-grit sanding drum to comfortably trim toenails in a manner that is designed to be harmless and humane. With easy to follow instructions included in the kit, you'll be grooming pet nails in minutes.         The rotary action of the tool comfortably trims your pet's nails making it a much more enjoyable experience for both the owner and the dog Two speeds 6,500 and 15,000 RPM to match the proper speed required Quickly, easily, and safely trim your pet's nails in minutes Two-year warranty DIMENSIONS Warranty: Limited 2 Years Material: High Density Plastic Height: 2.58["] Battery Voltage: 4.8 Speed: Two Speeds (6,500 and 13,000 RPM) Model Number: 7300-PT Weight: 0.6[kg, lb, oz] Charge Time: 3 Hours Length: 8["] Battery: Integrated NiCd Battery N Provantage: Battery Amp Hour: 3 Contents: MiniMite, Charger, battery and 3 accessories Width: 4.5["] Battery Chemistry: Nickel-Cadmium (NiCd) https://www.dremel.com/en_US/products/-/show-product/tools/7300-pt-pet-nail-grooming-tool?WT.ac=DR_Manuals_PDF_DogGroomingInstructions 10-10-18
7300-PT 价格&库存
很抱歉,暂时无法提供与“7300-PT”相匹配的价格&库存,您可以联系我们找货
