730CS
730CS
    DREMEL
    730CS DREMEL 130 PC RT ACCESSORY
730CS 数据手册
        730CS 130 PC All Purpose Accessory Kit Model # 730CS Product Specifications The Maker in all of us will appreciate this 130‐piece accessory kit because it contains the most popular Dremel rotary tool accessories at a very convenient price. Inside this accessory set are assorted bits for cutting, carving, engraving, grinding, drilling, sharpening, sanding, cleaning and polishing. The kit consists of regular cut off wheels, sanding bands, sandpaper discs, felt polishing wheels, carbon steel brush, aluminum oxide grinding stones, silicon carbide grinding stones, dressing stone, mandrels, wrench, and a reusable storage case.  Comes with re‐useable storage case and 130 accessories  Quality genuine Dremel accessories for long‐lasting applications  Ideal for cutting, sanding, polishing, grinding, and carving      Breadth of accessories helpful for wide assortment of tasks  105 engraving cutter  150 drill bit 1/8‐in  191 High speed cutter  401 mandrel  402 screw mandrel  407 ½”, 60 grit sanding band and mandrel  408 ½”, 60 grit sanding band (6)  409 15/16 In., thin‐cut, cut‐off wheel (12)  411 ¾ In., 180 grit sanding disks (12)  412 ¾ In., 220 grit sanding disks (12)  413 ¾ In., 240 grit sanding disks (12)  414 ¼ In., Felt polishing wheel (5)  415 Dressing stone  420 15/16 In., Cut‐off wheel (32)  421 Polishing Compound  426 1‐1/4 In., Fiberglass‐reinforced cut‐off wheel  428 Carbon Steel Brush  429 1 In., Felt polishing wheel (5)  430 ¼ In., 60 Grit Sanding Band and Mandrel  431 ¼ In., 60 Grit Sanding Band (6)  432 ½ In., 120 Grit Sanding Band (6)  438 ¼ In., 120 Grit Sanding Band (6)      540 Cut off wheel  8193 Aluminum oxide grinding stone  83142 Silicon carbide grinding stone  84922 Silicon carbide grinding stone  952 Aluminum oxide grinding stone  Wrench   DIMENSIONS Warranty: Product Defects Only Color Code: Blue Model Number: 730CS RPM: 15000                   https://www.dremel.com/en_US/products/‐/show‐product/accessories/730cs‐130‐pc‐all‐purpose‐accessory‐kit 10‐16‐18
730CS 价格&库存
很抱歉,暂时无法提供与“730CS”相匹配的价格&库存,您可以联系我们找货
730CS
