8220-1/28
8220-1/28
    DREMEL
    8220 SERIES RT TOOL (1 ATTACHMEN
8220-1/28 数据手册
        8220‐1/28 12V Max Lithium‐Ion Cordless Rotary Tool Kit Model # 8220‐1/28 Product Specifications The Dremel 8220 variable‐speed cordless rotary tool kit offers the highest performance and versatility of all Dremel cordless rotary tools. The strength of its motor facilitates maximum performance at all speed levels. In fact, with its 12VMAX lithium‐ion battery technology, the Dremel 8220 has a 33% longer run‐time than the Dremel 8200 cordless rotary tool when cutting screws. Our cordless rotary tool kit's list of included accessories is extensive, but for those who need even more flexibility, you can pair any Dremel rotary tool accessory or attachment with the 8220. Best of all, with the tool's slim ergonomic body, you'll get a 360‐degree grip zone for control in any position.      Separate on/off switch and speed control retains speed setting for the perfect speed every time  EZ Twist™ nose cap with wrench for fast accessory changes  Cool‐running ball bearing construction for smooth and quiet operation  Comfort grip housing for easier handling and better control DIMENSIONS   Speed: Variable (5,000 to 35,000 RPM) Warranty: Limited 2 Years Battery Voltage: 12 Material: Composite Model Number: 8220‐1/28 Weight: 1.6[kg, lb, oz] Charge Time: 1 Hour Contents: Tool, (1) Multi‐purpose Cutting Attachment, (28) Accessories, Micro‐Case, Wrench Battery Amp Hour: 1.5 Length: 6["] Battery Chemistry: Lithium Ion   Battery: 12V Width: 3["]                                             https://www.dremel.com/en_US/products/‐/show‐product/accessories/730cs‐130‐pc‐all‐purpose‐accessory‐kit 10‐16‐18
8220-1/28 价格&库存
很抱歉,暂时无法提供与“8220-1/28”相匹配的价格&库存,您可以联系我们找货
