MM422
MM422
    DREMEL
    3/4" WOOD & METAL FLUSH CUT BLAD
MM422 数据手册
Dremel Experts: US: 1 (800) 437-3635 Canada: 1 (888) 285-3476 www.dremel.com THE MAKERS OF Do you like to: EXPLORE Visit the Dremel website and get tips and tricks on projects and products. Plus visit our message board or sign up for our eblast for news on new product introductions. TALK Join the conversation on Facebook. DISCOVER Explore photos on Instagram. LEARN Watch tutorials on YouTube. BE INSPIRED Sign up for weekly project inspiration. SHARE Pin Dremel projects and ideas on Pinterest. STAY UP-TO-DATE Get the latest news from Dremel. Scan this code with your phone for product information, videos, and more. VERSATILE TOOL SYSTEMS IN D EX Cus tom er Sup p or t A well-prepared staff of Dremel Experts is available to answer questions about our tools. With over 650 total years of combined work experience, the Dremel Experts are ready to serve you. Call: 1-800-4-DREMEL 1-800-437-3635 (USA) 1-888-285-3476 (CANADA) ROTARY TOOL S C o r d e d . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-14 C o r d l e s s . . . . . . . . . . . . . . . . . . . . . . . . 1 5 -2 2 At t a c h m e n t s . . . . . . . . . . . . . . . . . . . 2 3 -2 8 Accessories .................... 29-4 4 OSCILL ATIN G TOO L S To o l s . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 5 - 5 4 Accessories .................... 55-58 M U LTI -SAWS U l t r a -S a w ™ . . . . . . . . . . . . . . . . . . . . 5 9 - 6 2 S a w - M a x ™ . . . . . . . . . . . . . . . . . . . . . . . 6 3 - 66 3D PRINTING 3 D I d e a B u i l d e r . . . . . . . . . . . . . . . 6 7-70 SPECIALT Y TOOL S M o to -S a w ™ . . . . . . . . . . . . . . . . . . . . . . . 7 1-74 Ve r s a F l a m e ™ . . . . . . . . . . . . . . . . . . . . . . . . 7 5 Ve r s aT i p ™ B u t a n e . . . . . . . . . . . . . . . . . 7 5 E n g r a v e r a n d A c c e s s o r i e s . . . . 76 ROTA RY TOOLS THE MAKERS OF VERSATILE TO OL SYSTEMS 1 WHAT IS A ROTARY TOOL? Rotary tools are hand held power tools that use high-speed and low torque to undertake a variety of useful tasks with control and precision. Since AJ Dremel invented the first rotary tool over 80 years ago, no other brand has worked harder to bring users a more complete and innovative system of rotary tools, accessories and attachments. Over the years Dremel rotary tools have become the gold standard in versatility, performance, and quality by which all other rotary tools are judged. 2 ROTA RY TOOL OVERVIEW CORDED Model FORTIFLEX™ 4200 4000 3000 Amps 2.5 1.6 1.6 1.2 0.9 0.9 N/A * 0-23,000 5,000— 35,000 5,000— 35,000 5,000— 32,000 15,000 and 35,000 23,000 0-35,000 Versatility Level High High High Intermediate Basic + Basic Basic Electronic Feedback Control Yes Yes Yes No No No No Number of Speeds Variable Variable Variable Variable 2 1 Variable Soft Grip No Yes Yes Yes No No No Separate On/Off Speed Control Yes Yes Yes No No No No Accy. Change System Wrench EZ Change ™ Wrench Wrench Wrench Weight [oz.] 117.0 25.0 22.5 20.0 18.0 18.0 7.0 ** 2 year 2 year 2 year 2 year 2 year 2 year 1 year Speed Range [RPM] Warranty EZ Twist ™ EZ Twist ™ Nose Cap Nose Cap * The VRT1 does not have a motor of its own. It is powered by the air flow from your vacuum. 200 100 SERIES SERIES VRT1 ** During use this VRT1 will weight approximately 7 oz plus the weight of the vacuum hose that it is plugged into. VE RSATI L I TY M ETE R High 3 Intermediate Premium Rotary Tools, able to perform the widest range of applications. High Performance Rotary Tools, able to tackle a wider range of applications. Models: 4200, 4000, 8220, FORTIFLEX™ Models: 3000, 8100 ROTA RY TOOL OVERVIEW Model CORDLESS 8220 8100 MICRO 7700 7300 Voltage 12V MAX 8V MAX 8V MAX 7.2 4.8 Battery Type Lithium Ion Lithium Ion Lithium Ion Ni-Cd Ni-Cd 5,000 33,000 5,00033,000 5,000— 28,000 10,000 and 20,000 6,50014,000 Versatility Level High Intermediate Basic + Basic + Basic Electronic Feedback Control No No No No No LED Lights No No Yes No No Variable Variable Variable 2 2 Soft Grip Yes Yes Yes No No Separate On/Off Speed Control Yes No Yes No No EZ Twist™ Nose Cap EZ Twist™ Nose Cap Wrench Wrench Wrench Attachment Interface Yes Yes No No No Weight [oz.] 22.0 14.0 8.0 10.6 9.2 2 year 2 year 2 year 2 year 2 year Speed Range [RPM] Number of Speeds Accy. Change System Warranty Basic + Enhanced Level Rotary Tools, with improved control across multiple applications. Models: 200 SERIES, MICRO, 7700 Basic Entry Level Rotary Tools, ideal for precision applications. Models: 100 SERIES, 7300, VRT1 4 CORDED ROTARY TOOLS Limited Warranty Versatility Can be used with all For the fastest and easiest Dremel Rotary Tool accessories accessory change. Integrated EZ Change™ and attachments.* Patented pull lever system High-Performance Motor Means you'll never need to For maximum look for the wrench again. performance at all speeds. Variable Speed For maximum accessory versatility and precise tool control. Separate On/Off Switch Electronic Feedback Increased power and air flow Auto adjusts power and speed as needed. PULL Retains speed setting for ease of use. For cooler operation. INS ERT SECURE * Attachment models 225, 575 and 670 are compatible with the 4200 when used with the 4200 Attachment Adapter found in your Dremel 4200 kit. 5 4 200 K IT 4200 - 8 / 6 4 • 4200 High Performance Rotary Tool Flex Shaft, Shield, Detailer’s Grip, Circle Cutter & Straight Edge Guide, Right Angle Attachment, Sanding/Grinding Guide, Cutting Guide, Lawn Mower & Garden Tool Sharpener • Deluxe Storage Case, Product Reference Sheet, Adapter/Drive Coupling 6 4 ASSORT ED ACCESSOR IES Carving/Engraving - 107, 7103 Grinding/Sharpening - 453, 454, 455, EZ541, 8193, 84922, 932 Cutting - 191, EZ409, EZ456, EZ544, 560, 561 Cleaning/Polishing - 403, 421, EZ423 (x3), 428 Sanding - 408 (x10), EZ411SA (x3), EZ412SA (x3), EZ413SA (x3), 432 (x10), 445 (x10) Miscellaneous - 150, EZ402, EZ407, 490 4 200 K IT 4200 - 6/4 0 • 4200 High Performance Rotary Tool, Circle Cutter & Straight Edge Guide, Shield, Cutting Guide, Lawn Mower & Garden Tool Sharpener, Sanding/Grinding Guide, Detailers Grip • Storage Case, Accessory Case, Product Reference Sheet, Adapter/Drive Coupling 4 0 ASSORT ED ACCESSOR IES Carving/Engraving - 107, 191 Grinding/Sharpening - 8193, 84922, 932 Cutting - EZ409, EZ456, 561 Cleaning/Polishing - 403, 428 Sanding - EZ407, 408 (x6), EZ411 (x3), EZ412 (x3), EZ413 (x3), 432 (x6), 445 (x6) Miscellaneous - 150, EZ402 4 200 K IT 4200 - 4/ 3 6 • 4200 High Performance Rotary Tool, Shield, Cutting Guide, Lawn Mower & Garden Tool Sharpener, Sanding/Grinding Guide • Storage Case, Accessory Case, Product Reference Sheet, Adapter/Drive Coupling 3 6 ASSORT ED ACCESSOR IES Carving/Engraving - 107, 191 Grinding/Sharpening - 8193, 84922, 932 Cutting - EZ456, 561 Cleaning/Polishing - 403, 428 Sanding - EZ407, 408 (x5), EZ411 (x3) EZ412 (x3), EZ413 (x3), 432 (x5), 445 (x5) Miscellaneous - 150, EZ402 6 CORDED ROTARY TOOLS Do es i t Al l , Bet t er. Limited Warranty Versatility Electronic Feedback High-Performance Motor Auto adjusts power and speed as needed. For maximum performance at all speeds. EZ Twist™ Nose Cap Wrench for fast Separate On/Off Switch accessory changes. Retains speed setting for ease of use. Variable Speed For maximum accessory versatility and precise tool control. 360º Grip Zone Can be used with all Dremel Rotary Tool Quick Collet Lock accessories and attachments. Integrated nose cap wrench for fast accessory changes. 7 With soft grip for comfort and control. For fast accessory changes. 4 0 00 K IT 4000 - 6/ 5 0 • 4000 High Performance Rotary Tool, Flex Shaft, Circle Cutter & Straight Edge Guide, Cutting Guide, Detail Nose Piece, Lawn Mower & Garden Tool Sharpener • Storage Case, Accessory Case, Product Reference Sheet, Wrench, 1/8" Collet 5 0 ASSORT ED ACCESSORIES Carving/Engraving - 107, 191, 194 Grinding/Sharpening - 541, 8193, 84922, 932 Cutting - EZ409 (x2), 420 (x4), EZ456 (x2), EZ476 (x2), 540, 561 Cleaning/Polishing - 405, 414 (x3), 421, 428, 429, 442, EZ423 Sanding - 407, 408 (x2), 411 (x2), 412 (x2), 413 (x2), 432 (x2), 445 (x2), EZ511, EZ512 Miscellaneous - 150, 401, 402, EZ402, 481 4 0 00 K IT 4000 - 4/ 3 4 • 4000 High Performance Rotary Tool, Detailer’s Grip, Sanding/Grinding Guide, Cutting Guide, Circle Cutter & Straight Edge Guide • Storage Case, Accessory Case, Product Reference Sheet, Wrench, 1/8" Collet 3 4 ASSORT ED ACCESSORIES Carving/Engraving - 107, 191 Grinding/Sharpening - 8193, 84922, 85602, 932 Cutting - 420 (x2), EZ456, 540, 561 Cleaning/Polishing - 403, 414 (x3), 421, 428, 429 (x2) Sanding - 407, 408, 411 (x2), 412, 413, 432 (x3), 445 (x3) Miscellaneous - 401, 402, EZ402 4 0 00 K IT 4000 - 2 / 3 0 • 4000 High Performance Rotary Tool, Sanding/ Grinding Guide, Circle Cutter & Straight Edge Guide • Storage Case, Accessory Case, Product Reference Sheet, Wrench, 1/8" Collet 3 0 ASSORT ED ACCESSOR IES Carving/Engraving - 191 Grinding/Sharpening - 541, 84922, 932 Cutting - 420 (x2), 426 (x2), 561 Cleaning/Polishing - 414, 421, 428, 429 Sanding - 407, 408 (x2), 411 (x3), 412 (x3), 413 (x2), 432 (x2), 445 (x2) Miscellaneous - 401, 402 8 CORDED ROTARY TOOLS Do es i t Bet t er. Limited Warranty Versatility Can be used with all Nose Cap Wrench for fast Dremel Rotary Tool accessories accessory changes. EZ Twist™ Variable Speed For maximum accessory versatility and precise tool control. Sealed Ball Bearing Motor Runs cool for comfort and longer tool life. Integrated nose cap wrench for fast accessory changes. 9 and attachments except MS400 and PL400 attachments. Separate On/Off Switch Retains speed setting for ease of use. Double hull construction Eliminates direct heat transfer to hand. 3 0 00 K IT 3 000 - 1/ 24 • 3000 Series Variable Speed Rotary Tool, Sanding/Grinding Guide • Storage Case, Accessory Case, Product Reference Sheet, Wrench, 1/8" Collet 24 ASSORT ED ACCESSORIES Carving/Engraving - 191 Grinding/Sharpening - 85422, 932, 952 Cutting - 426 (x2) Cleaning/Polishing - 403, 414 (x2), 421, 428, 429 Sanding - 407, 408, 430, 432 (x2), 438, 445 (x2), 446 Miscellaneous - 401, 402, 415 3 0 00 K IT 3 000 - 1/ 2 5 • 3000 Series Variable Speed Rotary Tool, Shield • Storage Case, Accessory Case, Product Reference Sheet, Wrench, 1/8" Collet 25 ASSORT ED ACCESSORIES Carving/Engraving - 191 Grinding/Sharpening - 84922, 932, 953 Cutting - 426 (x2) Cleaning/Polishing - 414 (x2), 421, 428, 429 (x2) Sanding - 407, 408, 430, 431, 432 (x2), 438 (x2), 445, 446 Miscellaneous - 401, 402, 415 10 CORDED ROTARY TOOLS Limited Warranty Versatility Two Speed control For application versatility and control. Sealed Ball Bearing Motor For cool running and longer tool life. 200 S E R IES K IT 20 0 - 1 /1 5 • Two-Speed Rotary Tool, Lawn Mower and Garden Tool Sharpener • Corrugated Storage Case, Product Reference Sheet • Wrench, 1/8" Collet 15 ASSORTE D ACC ESSO R IES Carving/Engraving - 194 Grinding/Sharpening - 8193, 83322, 932 Cutting - 420, 426 Cleaning/Polishing - 421, 422, 425, 429 Sanding - 407, 408, 432 Miscellaneous - 401, 402 20 0 S ERIES K IT 200 - 1 /21 • Two-Speed Rotary Tool, Cutting Guide • Corrugated Storage Case, Product Reference Sheet • Wrench, 1/8" Collet 21 ASSORT ED ACCESSOR IES Carving/Engraving - 194 Grinding/Sharpening - 8193, 83142, 84922, 932 Cutting - 420, 426, 561 Cleaning/Polishing - 414 (x2), 421, 425 (x2), 429 (x2) Sanding - 407, 432, 445 Miscellaneous - 401, 402, 415 11 Limited Warranty Versatility Single Speed control For fulltime 35,000 rpm operation. Sealed Ball Bearing Motor For cool running and longer tool life. 100 S ER IES K IT 10 0 - LG 1 20 V For better performing lawn and garden tools. • Single-Speed Rotary Tool, Lawnmower and Garden Tool Sharpener, Chainsaw Sharpener, Blade Sharpener • Product Reference Sheet • Wrench, 1/8" Collet 7 ASSORTE D ACC ESSO R IES Grinding/Sharpening - 453, 454, 455, 932 Cutting - 426 (x2) Miscellaneous - 402 100 S ER IES K IT 10 0 - N /7 Ideal for sanding, carving and drilling. • Single-Speed Rotary Tool • Product Reference Sheet • Wrench, 1/8" Collet 7 ASSORTE D ACC ESSO R IES Grinding/Sharpening - 84922, 932 Cutting - 420 Sanding - 407, 432 Miscellaneous - 402, 415 12 CORDED ROTARY TOOLS Power M eet s Prec i s ion Limited Warranty Versatility Variable Speed Foot Pedal Allows you to match the speed with the application, hands-free. Powerful 2.5 AMP (1/5 HP) Motor Three-Jaw Chuck Provides high torque at low speeds. Precision Hand Piece Enhances versatility by accepting accessories from 0" to 5/32". Engineered for control and comfort even with extended use. Interchangeable Hand Piece Heavy Duty Flexible Shaft Compatible with Dremel MotoFlex and other flex shaft tools. Includes a patented bearing system for durability and cool operation. Can be used with all Dremel rotary tool accessories. FORT IF L EX ™ K IT • • • • • • 910 0 - 21 Dremel Fortiflex™ motor unit Variable speed foot pedal Heavy duty flex shaft Hand-piece with three-jaw chuck Wall hook Chuck wrench 2 1 ASSORT ED ACCESSOR IES Carving/Engraving - 191 Grinding/Sharpening - 7103, 84922, 953 Cutting - 117, 9910 Cleaning/Polishing - 403 Sanding - 407, 430, 431, 432 (x2), 438 (x2) Miscellaneous - 628 (7 Piece Set) 13 VACU U M P OW E R E D Limited Warranty Powered by Your Vacuum Perfect for small and dusty projects. Speed Control For greater tool versatility and adjustment of accessory speed. NEW! Versatility On/Off Control Lets you stop the tool but keep the vacuum running. Vacuum Hose Ready Connects with 1-1/4 in. shop vacuum hoses and adapters. Compatible with most Dremel rotary tool accessories. VRT1 KIT VRT1-1/5 • VRT1 Vacuum Powered Rotary Tool • Cutting Guide 6 ASSORT ED ACCESSOR I ES Carving/Engraving - 191 Cutting - 560 Sanding - 407, 408 (x2) Miscellaneous - Wrench 14 CORDLESS ROTARY TOOLS Do es i t Al l , U n p l u gged. NEW! Versatility Limited Warranty Next Generation 12V Max High-Performance Motor For maximum performance For maximum performance at all speeds. and run time. Removable Lithium-Ion Battery Can be used with all Dremel Rotary Tool Always ready with no memory effects. accessories and attachments. EZ Twist™ Separate On/Off Switch Nose Cap Wrench for fast Retains speed setting for ease of use. accessory changes. Variable Speed 360º Grip Zone For maximum accessory versatility and precise tool control. With soft grip for comfort and control. L ITHI UM-I ON TECHNOLOGY • More power in a smaller size • Always ready – holds charge up to 2 years • No memory effects – charge any time 15 8 2 20 K IT 8 2 20 - 1/ 2 8 • 8220 Cordless 12VMAX High Performance Rotary Tool, Cutting Guide • 1-Hour Battery Charger, 12VMAX Lithium-Ion Battery Pack (1) • Storage Case, Accessory Case, Product Reference Sheet • Wrench, 1/8" Collet 28 ASSORT ED ACCESSOR IES Grinding/Sharpening - 541, 8193 Cutting - 426, 561 Cleaning/Polishing - 414 (X4), 421, 425 (X4), 429 (X4) Sanding - 407, 408 (X2), 432 (X3), 445 (X3) Miscellaneous - 401, 402, 8 2 20 K IT 8 2 20 - 2 / 2 8 • 8220 Cordless 12VMAX High Performance Rotary Tool, Shield, Cutting Guide • 1-Hour Battery Charger, 12VMAX Lithium-Ion Battery Packs (2) • Storage Case, Accessory Case, Product Reference Sheet • Wrench, 1/8" Collet Includes 2 batteries 28 ASSORT ED ACCESSOR IES Grinding/Sharpening - 541, 8193 Cutting - 426, EZ456, 561 Cleaning/Polishing - 414 (X3), 421, 425 (x4), 429 (x3) Sanding - 407, 408 (X2), 432 (X3), 445 (X3) Miscellaneous - 401, 402, EZ402 CORDLESS 12V MAX ROTARY TOOL ACCESSORIES 12VMAX Lithium-Ion Battery Pack 875 12VMAX 1-Hour Lithium-Ion Battery Charger 876 16 CORDLESS ROTARY TOOLS Limited Warranty Versatility EZ Twist™ Nose Cap Wrench for fast accessory changes. Variable Speed For maximum accessory versatility and precise tool control. 8V Max Lithium-ion For power in a smaller size, always ready and no memory effects. Can be used with all Dremel Rotary Tool accessories and attachments except 231, 335, PL400 and MS400 attachments. Small and Lightweight For easier handling and less fatigue. 17 8 10 0 K IT • • • • 8 100-N/ 2 1 8100 Cordless 8VMAX Rotary Tool 1-Hour Charger, 8VMAX Lithium-Ion Battery Pack (1) Compact Storage Case Wrench, 1/8" Collet 21 ASSORT ED ACCESSOR IES Grinding/Sharpening - 84922, 932, 952 Cutting - 540 (x3) Cleaning/Polishing - 403, 414 (x2), 421 Sanding - 407, 408 (x3), 432 (x3), 445 (x2) Miscellaneous - 401, 402 CORDLESS 8V MAX ROTARY TOOL ACCESSORIES 8VMAX 1-Hour Lithium-Ion Battery Charger 8VMAX Lithium-Ion Battery Pack B808-01 876 18 CORDLESS ROTARY TOOLS Bril l i an t l y Powerfu l Limited Warranty Versatility Slim Ergonomic Design Docking Station Makes it light and easy to handle for detailed projects & tight spaces. Continually charges so the tool is always fully charged and ready to use. LED Smart Features Variable Speed Such as front-end lighting, variable speed indicator and fuel gauge allow for optimal use. For maximum accessory versatility and precise tool control. Compact, Lightweight 8V Max Lithium-Ion Battery With soft grip for comfort and control. For power in a smaller size, always ready and no memory effects. 19 360º Grip Zone Quick Collet Lock For fast accessory changes. M I C RO K IT • • • • • 8 050-N/1 8 Dremel Micro Rotary Tool Charging Base Accessory Case Product Reference Sheet Wrench, 1/8" Collet 1 8 ASSORT ED ACCESSOR I ES Carving/Engraving - 105, 125, 191 Cutting - 426 (x2) Grinding/Sharpening - 84922 Cleaning/Polishing - 414 (x2), 421, 429 (x2), 530 Sanding - 407, 408, 432, 445 Miscellaneous - 401, 402 20 CORDLESS ROTARY TOOLS Versatility Limited Warranty Two Speeds For control and accuracy. Removable battery pack Continuous use to finish your projects. 7.2 Volts of Power . . . goes anywhere. Light and Compact Easy to handle and fun to use — anywhere! 3-Hour Charger Quick battery recharge with LED light. Light indicates battery is correctly placed into the charger for proper charging. 7 70 0 K IT 7 700-1/ 15 • 7.2V Two-Speed Cordless Rotary Tool, Lawn Mower and Garden Tool Sharpener • Corrugated Storage Case, Accessory Organizer, Product Reference Sheet • 3-Hour Charger • Wrench, 1/8" Collet 1 5 ASSORT ED ACCESSOR IES Carving/Engraving - 84922 Grinding/Sharpening - 8193, 932, 952 Cutting - 420, 540 Cleaning/Polishing - 421, 430 Sanding - 403, 407, 414 Miscellaneous - 401, 402 7 700 ACCESSOR IES 3-Hour Battery Charger 7.2V Battery Pack 757-01 21 760-01 Versatility Limited Warranty Two Speeds For control and accuracy. Removable battery pack Continuous use to finish your projects. 4.8 Volts of Power For light duty precision jobs. Light and Compact Easy to handle and fun to use — anywhere! 3-Hour Charger Quick battery recharge with LED light. Light indicates battery is correctly placed into the charger for proper charging. 7300 K IT 73 00-N/ 8 • 4.8V Two-Speed MINIMITE® • 3-Hour Charger • Wrench, 1/8" Collet 8 ASSORT ED ACCESSOR I ES Grinding/Sharpening - 84922 Cleaning/Polishing - 414, 428 Sanding - 407, 408, 445 (x2) Miscellaneous - 401 7300 ACCESSOR IES 3-Hour Battery Charger 4.8V Battery Pack 755-01 760-01 22 ROTA RY TOOL AT TACHMENTS ROTA RY TO O L AT TACH M EN T C O M PATIB ILIT Y K E Y 5 A5 50 56 5 56 6 56 8 57 5 A5 76 A5 77 67 0 67 5 67 8- 0 1 A6 7902 14 53 25 00 -01 23 33 1 5 22 4200 4000 400 3000 300 398 395 285 275 200 100 Fortiflex VRT1 8220 8200 8100 8050 800 770 750 1100 7300 7700 22 CORDLESS CORDED TOOL MODEL NUMBER 0 AT TAC H M E N T M O D E L N U M B E R • • • • • • • • • • • * • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • ** • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • * • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • * • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • Use this chart to find out which attachments work with your tool. Adapters may be needed. *This attachment is compatible with the 4200 when used with the 4200 Attachment Adapter found in your Dremel 4200 kit. **Not compatible with the 428 accessory. 23 WORK STAT ION MOD E L 220 - 0 1 Functions as an articulating drill press that rotates 90º, rotary tool holder, and flex-shaft tool stand. • Detents click the tool in place in 15º increments from vertical to horizontal. • “Crow’s Nest” provides on-board storage for Dremel accessories. • Durable, die-cast aluminum base. FLEX SHAFT AT TACHMENT MODEL 225 - 01 Ideal for hard to reach places and fine detail work. • Quick connect attach system. • 36" long cable with new 5" bend radius provides more flexibility. • Comfort grip hand piece. • Integrated shaft lock button. • Holds up to 1/8" shank. • Works with collet system and Dremel chuck. SHAPER/ROUTER TABLE MODEL 231 Converts your corded Rotary Tool into a bench mounted wood shaper. • Features an adjustable fence and large 8" x 6" worktable. • Slot, groove, sand and trim edges. TO O L S N OT I N C L U D E D W I T H AT TAC H M E N T S 24 M ULT I-V IS E MOD EL 25 0 0 - 0 1 Gets a Grip on Anything, Anywhere! • Portable vise holds work piece for projects such as woodworking, home projects, crafts and hobbies. • Clamps to any work surface up to 2-1/2" thick. • Rotates 360º and tilts 50º allowing user to lock the workpiece in any position. • Tool holder turns Dremel Rotary Tools into a stationary sander, grinder or polisher. • Removable clamping jaws creates a stand-alone bar clamp. P LU NG E ROU TER AT TAC HM E N T M O D E L 335 - 0 1 Converts your corded Rotary Tool into a plunge router. • • • • Clear base. Two depth stops. Includes edge guide and circle guide. Rout circles, parallel to edge, signs and inlay work and decorative edges. DUST BLOWER MODEL 490 Blows dust away for greater visibility to work piece. Great for sanding, engraving, and carving. SHIELD KIT MODEL A550 Increased comfort from debris and sparks during cutting, grinding, sanding, and polishing applications. • Easy to Use – Spring friction design allows for quick adjustment and accessibility to accessory. • Compact for greater maneuverability. 4 ASSORT ED ACCESSOR I ES Grinding/Sharpening - 8193 Cutting - EZ456 Cleaning/Polishing - 428 Miscellaneous - EZ402 TO O L S N OT I N C L U D E D W I T H AT TAC H M E N T S 25 MULTIPURPOSE CUTTING KIT MODEL 565 • Allows for sturdy controlled cuts with maximum visibility. • Easy depth adjustment. Set to the correct cutting depth for the material you are working on. • Includes cutting guide, 2 drywall cutting bits for cutting drywall for electrical boxes & air vents. • Includes 1 multipurpose cutting bit for making cuts in ceiling tile, wood, plastic, fiberglass, drywall, laminate and vinyl siding. T I LE CU TTING K IT MODEL 566 • Allows for sturdy controlled cuts with maximum visibility. • Easy depth adjustment. Set to the correct cutting depth for the material you are working on. • Includes cutting guide and tile cutting bit. • Shape ceramic wall tile around fixtures or plumbing pipes. Not for use on floor tile. GROUT REMOVA L AT TACHMENT MODEL 568 For use on wall and floor grout! • Multiple slide depth adjustment. • 30° angle for controlled cutting. • Guides 180° apart to keep bit centered between tiles. • Easy screw-on mounting. • Excellent cutting visibility. • Includes 1/16" Grout Removal Bit – Model 569. Made of solid carbide, the bit will remove both wall and floor grout. 569 570 • Also available: Model 570 1/8" Grout Removal Bit (Not included with 568). TO O L S N OT I N C L U D E D W I T H AT TAC H M E N T S 26 RIGHT ANGLE AT TACHMENT MODEL 575 Enhances the versatility of your Dremel Rotary Tool by allowing you to get into hard-to-reach areas. • Quick connect system easily attaches to your rotary tool in place of the housing cap, no wrenches required. • Compact, durable design for those “hard-to-reach” places. SANDING/GRINDING GUIDE MODEL A576 Stabilizes a handheld tool by providing an edge guide or serves as a work platform when the tool is mounted in a secure position. • Increased control during sanding and grinding applications. • Platform provides greater stability during edge sanding and sharpening. • Adjustable depth control for a precise finish. • Attaches onto a rotary tool in place of its nose piece for quick and easy installation. • Includes 407 1/2" 60 grit sanding drum, 932 932 aluminum oxide grinding stone and instructions. 407 DETAILER'S GRIP MODEL A57 7 Transfers the weight of the tool to the palm of your hand for improved tool balance and control. • Offers enhanced grip and comfort for detailed applications. • Provides optimal tool control when precision is required. • Attaches onto a rotary tool in place of its nose piece for quick and easy installation. • Includes 107 engraving cutter and tracing stencil. 107 TO O L S N OT I N C L U D E D W I T H AT TAC H M E N T S 27 481 M I NI SAW ATTACH MEN T M O D E L 670 Works great on wood and all wood-like materials. • Make clean, straight perpendicular cuts up to 1/4" thick. • Quick connect system attaches to your rotary tool in seconds. • Includes blade. C I RCL E CU TTER A ND STRAIGHT E D GE GU ID E M O D EL 678 - 01 The simple way to cut circular holes in many types of materials. Convenient measurement guides in both inches and centimeters, so you can cut out the right-sized circle every time. • Makes circles from 3/4" -12" (1.9-30 cm). • Attaches quickly and easily without tools. • Depth adjustment allows easy setting of the correct cutting depth. • Straight Edge Guide allows routing or cutting in a straight line. • Includes 1/8" Multipurpose Cutting Bit – Model 561 (see p. 34). 561 LAWN MOWER, GARDEN TOOL, AND CHAIN SAW SHARPENING KIT MODEL A679 - 02 The Dremel chain saw sharpening attachment as well as the Dremel lawn mower and garden tool sharpening attachment are included together in one kit for your convenience. • Guide provides optimum sharpening angle. • Sharpens all rotary lawn mower blades. • Easily sharpen the dullest of chains. • Garden Tool Sharpening • 2 Spacers Attachment, Lawn • Instruction Manual Mower Sharpening • 4 Sharpening Stones Attachment, Chain Saw Nos. 453, 454, 455, Sharpening Attachment (see p. 30) and 932 • Wrench, Gauge (see p. 31) TO O L S N OT I N C L U D E D W I T H AT TAC H M E N T S 28 ROTA RY TOOL ACCESSORIES NEW U N I V ERSA L S HANK STANDARD NO MORE HUNTING FOR THE RIGHT COLLET* Over the next year, all Dremel rotary accessories are transitioning to a 1/8" shank standard. This means never having to search for the right collet again. Collet 480 will soon work for all rotary accessories. 1/8" * As this conversion will take some time, please refer to accessory packaging to verify accessory shank size. Only exception being metal and wood drill bits. 480 CA RV I N G/E N GRAV I NG/GRINDING STONES CA RV ING SOF T MAT E R IALS HIGH SPEED CUTTERS High speed cutters can be used for shaping, hollowing, grooving, slotting, making tapered holes in soft metals, plastics and woods. # 199 cutter can be used to make small slits. 1/4" 6,4 mm 5/16" 7,9 mm 100 114 5/16" 7,9 mm 115 (x2) 1/4" 6,4 mm 116 5/16" 7,9 mm 5/16" 7,9 mm 3/32" 2,4 mm 1/8" 3,2 mm 134 144 190 191 1/4" 6,4 mm 117 (x2) 3/16" 4,8 mm 192 (x2) 1/8" 3,2 mm 1/4" 6,4 mm 5/16" 7,9 mm 118 121 124 5/64" 2,0 mm 1/8" 3,2 mm 193 194 (x2) 7/32" 5,6 mm 1/4" 6,4 125 (x2) 3/8" 9,5 mm 196 (x2) 199 STRUCTURED TOOTH TUNGSTEN CARBIDE CUTTERS Fast-cutting sharp teeth for greater material removal. Use on fiberglass, wood, plastic, epoxy, rubber, laminates, particle board and ceramic tile. 29 1/4" 6,4 mm 5/16" 7,9 mm 5/16" 7,9 mm 5/16" 7,9 mm 3/4" 19,1 mm 9931 9933 9934 9935 9936 CARVING/ E NGRAVING CARV ING H A RD MAT E R IALS TUNGSTEN CARBIDE CUTTERS Use for shaping, smoothing and material removal. Use on hardened steel, stainless steel, cast iron, nonferrous metals, fired ceramics, plastics, hardwoods and other hard materials. Not for use with floor tile. 1/8" 3,2 mm 9901 3/32" 2,4 mm 9902 1/8" 3,2 mm 9903 3/32" 2,4 mm 1/8" 3,2 mm 1/8" 3,2 mm 9904 9905 9906 1/8" 3,2 mm 9909 1/8" 3,2 mm 1/8" 3,2 mm 9910 9911 E NG RAV ING SOF T MATE R IALS ENGRAVING CUTTERS Quality cutters for detail engraving, carving, routing in wood, fiberglass, plastic and soft metals. 1/8" 3,2 mm 105 (x2) 1/8" 3,2 mm 1/8" 3,2 mm 106 (x2) E NG RAV ING 1/8" 3,2 mm 107 (x2) 1/8" 3,2 mm 108 109 1/8" 3,2 mm 110 1/8" 3,2 mm 1/8" 3,2 mm 111 113 H A RD M ATE R IALS DIAMOND WHEEL POINTS For fine detail work, engraving, carving, touch-up and finishing. Use on wood, jade, ceramic, glass, hardened steel, semi precious stones and other hard materials. Bits are covered with diamond particles. 1/8" 1/8" 1/8" 3,2 mm 3,2 mm 3,2 mm 1/8" 3,2 mm 1/8" 3,2 mm 1/8" 3,2 mm 1/8" 3,2 mm Dual Package 7103 (x1) 7103 7105 7120 7122 7123 7134 7144 7144 (x1) 7150 30 ROTA RY TOOL ACCESSORIES ROU TI N G RO U T ER B I TS For routing, inlaying, and mortising in wood and other soft materials. Use with Dremel # 330 Router Attachment, # 335 Plunge Router Attachment, and # 231 Shaper/Router Table. Made of high speed steel. 31 3/32" 2,4 mm Piloted Beading 1/8" 3,2 mm Corner Rounding 1/4" 6,4 mm Core Box 1/2" 12,7 mm Chamfer 1/4" 6,4 mm V-Groove 612 615 617 618 640 1/8" 3,2 mm Straight 3/16" 4,8 mm Straight 1/4" 6,4 mm Straight 5/16" 7,9 mm Keyhole 650 652 654 655 GRINDING/SH ARPE NING FERROUS MATERIALS C H A I N SAW SHA R PENI NG STO N ES – 4 53, 4 54, 4 55 Precision-ground for quick, easy sharpening of chain saw blades. Each package contains 2 stones. ALU MI NU M OX I D E A B R AS IVE W H E E L – 500 Perfect for cleaning, de-burring, removing rust, and polishing of most metals, including stainless steel. ALU MI NU M OX I D E A B R ASIVE P O IN T – 516 Abrasive point is great for finishing work and light de-burring. It can be used for paint and rust removal without removing any of the base material. ALU MI NU M OX I D E GR I ND I N G W HE E L – 54 1 Use for de-burring, rust removal and general purpose grinding. 2 Per Pack. Use 541 with Mandrel 402. E Z Loc k™ 1- ½ " A LU MI NU M OX IDE G R IN DIN G W HE E L – E Z 54 1 G R 1-½ " M U LT I - MAT ER I A L D I A M O N D G R IN DIN G W HE E L – 547 G R Patented diamond embedding technology surfacing wheel that can remove coatings such as rust, thin set, paint, and sticky adhesives from metal, concrete, tile, wood, and more. 1/2" 7/8" 5/32" 3/16" 7/32" 1" 4,0 mm 4,8 mm 5,6 mm 25,4 mm 12,7 mm 22,2 mm 453 (x2) 454 (x2) 455 (x2) 500 516 541 1-1/2" 38,1 mm EZ541GR NEW! For use with EZ Lock™ mandrel EZ402. 1-1/2" 38,1 mm 547GR 32 ROTA RY TOOL ACCESSORIES GR I N D I N G/S H A R P E NING FERROUS MATERIALS A LU M I N I U M OX I D E G R I N D I N G STO N ES (O R A N G E / B ROW N ) Use on metals, castings, welded joints, rivets and rust. Ideal for sharpening, de-burring and general purpose grinding of most materials. 7/16" 11,1 mm 3/8" 9,5 mm 5/8" 15,9 mm 3/16" 4,8 mm 3/8" 9,5 mm 911 932 941 945 952 1/4" 6,4 mm 953 (x2) 5/8" 15,9 mm 1/8" 3,2 mm 3/16" 4,8 mm 3/8" 9,5 mm 5/8" 15,9 mm 1" 25,4 mm 971 997 8153 8175 8193 8215 NON-FERROUS MATERIALS S I L I CO N CA R B I D E G R I N D I N G STO N ES ( B LU E /G R E E N ) Designed to work well on stone, glass, ceramics, porcelain and non-ferrous metals. 33 9/32" 7,1 mm 1/8" 3,2 mm 1/8" 3,2 mm 83142 83322 83702 3/16" 4,8 mm 84922 (x2) 25/32" 19,8 mm 13/32" 10,3 mm 1/2" 12,7 mm 85422 85602 85622 CUTTING E Z Lo ck ™ Faster Accessory Changes – Easy As 1, 2, 3 Pu ll – 1 Tw i st – Release 2 EZ406 EZ409 3 EZ426CU EZ456 EZ456B EZ476 EZ506CU EZ 4 0 4 Sta rter Kit . Includes (1) EZ402 and (1) EZ426. EZ Loc k™ STA RT ER KI T – E Z 4 06 Includes 1 EZ Lock™ mandrel and 5 reinforced cut-off wheels. EZ Loc k™ 1- ½ " T HI N R EI N FO RC E D CU T- O F F W HE E L – E Z 4 09 For use with EZ Lock™. Reinforced cut-off wheels for cutting metal. 2X more cuts compared with 409. 5pc. EZ Lock™ 1-¼" REINFORCED CU T-OFF WHEEL – EZ426CU For use with EZ Lock™. Reinforced cut-off wheels for cutting metal. 2X more cuts compared with 420. 3pc. EZ Loc k™ 1- ½ " R EI NFORC E D CU T- O F F W H E E L – E Z 4 56 For use with EZ Lock™. Reinforced cut-off wheels for cutting metal. 2X more cuts compared with 426. 5pc. EZ Loc k™ 1- ½ " R EI NFORC E D CU T- O F F W H E E L BU LK PACK – EZ4 5 6 B For use with EZ Lock™. Reinforced cut-off wheels for cutting metal. 12pc. Bulk pack. EZ Loc k™ 1- ½ " R EI NFORC E D CU T- O F F W H E E L – E Z 476 For use with EZ Lock™. Reinforced cut-off wheel makes clean cuts in plastic. 5pc. EZ Loc k™ 1- ½ " CB N METAL CU T- O F F W HE E L – E Z 506CU For use with EZ Lock™. Features a super abrasive grit called cubic boron nitride or CBN. Lasts at least 20 times longer than our fiberglass-reinforced cutting wheels. EZ Lock Premium Metal Cutting Wheel. 1pc. 34 ROTA RY TOOL ACCESSORIES CUT TI N G M E TA L (Limited use on wood and plastic) CU T- OFF W HEELS – 4 0 9, 4 20, 54 0 For slicing and cutting metal, light wood and plastic. Cut-off wheels make it easy to cut or slot bolts, screws, sheet metal, thin wood and plastic. The cut-off wheel cuts only along its edge. Do not attempt to sand or cut curved holes with them. Use with mandrel 402. 5 0 6 CU – Premium Metal Cutting Wheel. 1pc. Features a super abrasive grit called cubic boron nitride or CBN. Lasts at least 20 times longer than our fiberglass-reinforced cutting wheels. Use with mandrel 402. Mandrel 402 is sold separately. FIBERGLASS REINFORCED CU T-OFF WHEELS – 426, 456 Use with mandrel 402. Mandrel 402 is sold separately. 456 package includes a washer set only used with 456. 15/16" 1-1/4" 15/16" 23,8 mm 31,8 mm 23,8 mm .025" thick .040" thick .0625" thick 36 per pack 20 per pack 5 per pack 409 420 540 1-1/4" 31,8 mm .045" thick 5 per pack 1-1/2" 38,1 mm .045" thick 10 per pack 7/8" 22,2 mm .045" thick 1 per pack Cut-off wheel dispenser 20 per pack 426 456 506CU 426B WOOD CA RB I D E CU T T I NG/SHA P IN G W HE E L – 54 3 For cutting and shaping on soft and hard woods, fiberglass, plastics and laminates. Do not use on metal. Mandrel included. Thickness .070" (1,8 mm). E Z Loc k™ 1- ½" CA R B I D E CU TTIN G W HE E L – E Z 54 4 For cutting soft and hard woods, fiberglass, plastics and laminates. Do not use on metal. For use with EZ Lock™ mandrel. RIP/CROSSCUT B LA D E – 54 6 For use with Mini Saw Attachment 670 only. Thickness .023" (0,6 mm). 1 - 1/4" 31,8 mm 543 35 1 - 1/2" 38,1 mm EZ544 1-1/4" 31,8 mm 546 CUTTING H A RD MAT ER IA LS DIAMOND WHEEL – 545 Great for cutting, sawing and carving of hard materials such as marble, concrete, brick, porcelain, ceramics, hard epoxy, soft and hard wood. Mandrel 402 is included. Thickness .023" (0,6 mm). Do not run in excess of 20,000 RPM. E Z Loc k™ 1- ½ " D I A MOND W H E E L – E Z 54 5 For use with EZ Lock™. Diamond cutting wheel makes clean cuts in hard materials. DRYWALL, MULTIPURPOSE, TILE AND GROUT D RY WA L L CU T T I N G B I T – 5 6 0 * Gives you fast clean cuts in drywall. M U LT I PU R POSE CU T T I NG BIT – 561 * Cuts hardwood up to 3/8" and softwood up to 5/8". Also cuts plastic, fiberglass, drywall, laminate, aluminum & vinyl siding. T I L E CU T T I NG B I T – 56 2 * Cuts ceramic wall tile, cement board, and plaster. (Not for use on floor tile.) CA RB I D E GROU T R EMOVA L BITS – 569 A N D 570 † Ideal for replacing wall and floor grout or removing grout to replace broken tiles. * Use with cutting guide (page 23). † Use with grout removal guide (page 24). 7/8" 22,2 mm 1 - 1/2" 38,1 mm 545 EZ545 560 561 562 1/16" 1,6 mm 1/8" 3,2 mm 569 570 36 ROTA RY TOOL ACCESSORIES CLE A N I N G/P O L I S H I NG P O L I S H I N G AC C E S S O RI E S – 4 1 4 , 4 2 2 , 4 2 9 Ideal for polishing metals and plastics. Using polishing compound # 421 with wheels produces a high luster. Use 414, 422 and 429 with Mandrel 401. P O LI SHI NG CLOT H – 4 23 E Made to take a smooth finish and polish it to a high luster. Use with either EZ402, or with 402. Mandrels sold separately. P O LI SHI NG COM POU ND – 421 Use with felt or cloth accessories to polish metals and plastics. Compound will remove a dull oxidized film and/or light surface imperfections. A solid compound. E M ERY I M PR EGNAT ED PO LIS H IN G W H E E L – 4 25 Ideal for general polishing of most ferrous metal, stone, glass and ceramic. Use 425 with mandrel 402. RUBBER POLISHING POINTS – 461, 462, 463 Blue points for finishing and polishing all ferrous metals. Removes small burrs and scratch marks left by grinding and sanding, and cleans and defines grooves. Also effective on many stones and ceramics. Felt 1/2" dia. 6 per pack Felt 3/8" dia. Felt 1" dia. Cloth 1" dia. 414 422 429 423E 421 37 1" 25,4 mm 1/4" 6,4 mm 1/4" 6,4 mm 1/4" 6,4 mm 425 (x2) 461 462 463 CLE ANING/ POLISH ING P O LI SHI NG W HEEL – 5 20 Use for light stock removal and high luster polishing of metals and hard plastics. The wheel is impregnated with a silicon carbide abrasive and lubricant, eliminating the need for polishing compound. AB RASI V E B RUSH – 5 3 8 Dremel’s strongest and longest lasting brush. Extra-thick nylon bristles are coated with an abrasive grit for material removal on the toughest jobs. Use for de-burring metal or wood and for removing rust and paint. Do not run brush in excess of 20,000 RPM. B R I ST LE B RUSHES – 4 03, 4 04, 4 05 Use for light de-burring, cleaning, polishing of silverware, jewelry and other precious metals; can use with polishing compound. CA RB ON ST EEL B RUSHES – 4 28 , 4 4 2, 4 4 3 Versatile brush for removing rust and corrosion, polish metal surfaces. De-burr and blend surface junctures, clean electrical components. STA I NLESS ST EEL B RUSHES – 53 0, 53 1 , 53 2 Stainless steel brushes do not cause “after-rust” when used on corrosive-resistant materials like pewter, aluminum and stainless steel. B R ASS B RUSHES – 5 3 5, 53 6, 537 Brass brushes are non-sparking and softer than steel. They will not scratch soft metals like gold, copper, brass. Do not run brushes in excess of 15,000 RPM. 1/2" 12,7 mm 1" 25,4 mm 3/4" 19,1 mm 520 (x2) 538 (x2) 403 (x2) 1/2" 1/8" 12,7 mm 3,2 mm 404 (x2) 405 (x2) 3/4" 19,1 mm 428 (x2) 1/2" 1/8" 12,7 mm 3,2 mm 442 (x2) 443 (x2) 3/4" 19,1 mm 1/2" 12,7 mm 1/8" 3,2 mm 3/4" 19,1 mm 1/2" 12,7 mm 1/8" 3,2 mm 530 (x2) 531 (x2) 532 (x2) 535 (x2) 536 (x2) 537 (x2) 38 ROTA RY TOOL ACCESSORIES SA N DI N G D ETA I L A B R ASI V E B RUSHES – E Z 47 1 SA , E Z 472SA , E Z 473 SA Great for detail cleaning and light sanding. Use on metal, glass, wood, aluminum and plastics. Use with either EZ402, or 402. Mandrels sold separately. Not to be used in excess of 15,000 RPM. F I N I SHI NG A B R ASI V E BU F FS – 51 1 E , 51 2E Great for cleaning and light sanding. Use on metal, glass, wood, aluminum and plastics. The 512 fine-grit buff is particularly ideal for removing tarnish from brass. Use 511E and 512E with either EZ402, or 402. Mandrels sold separately. Not to be used in excess of 15,000 RPM. F L A PW HEELS – 5 02 , 5 03, 504, 505 Flapwheels grind and polish flat or contoured surfaces. They are used most effectively as a finishing sander after heavier surface sanding and material removal is completed. CA RB I D E SHA PI NG W HEEL – 8 01 A powerful shaping tool that quickly and efficiently removes material. Easily creates compound curves and works on a variety of materials including woods, fiberglass, laminates, plastic, and leather. Mandrel included. Not to be used for cutting. Grit: EZ471SA EZ472SA 36 Coarse 120 Medium 3/8" 9,5 mm Grit: 39 3/8" 9,5 mm EZ473SA 220 Fine 511E 180 Coarse 512E (x2) 280 Medium 320 Fine 3/16" 4,8 mm 3/16" 4,8 mm 1-1/4" 31,8 mm 502 503 504 505 801 80 120 80 120 60 SANDING SAND I NG BA NDS – 4 07, 4 08 , 4 3 0, 4 3 1 , 4 3 2, 4 3 8 , 4 4 5, 4 4 6 For rough shaping and smoothing wood and fiberglass; removing rust from metal surfaces; shaping rubber surfaces. Sander bands are easily replaceable on drums, and are available in packages of 6 each. E Z D RU M SA ND I NG M A ND R E L – E Z 4 07 SA Resilient rubber sleeve forms around 4 tabs to keep accessory secure. Contoured collar holds entire assembly in place. Currently sold with one sanding band. Compatible with ½” diameter bands (408, 432, and 445). SAND I NG D I SCS – 4 11, 4 12, 4 1 3, E Z 4 1 1 SA , E Z 4 1 2SA , E Z 4 1 3 SA , E Z 4 14 SA For rough shaping and smoothing wood and fiberglass; removing rust from metal surfaces; shaping rubber surfaces. Use 411, 412 and 413 with mandrel 402. 36 pieces per pack. Use EZ411SA, EZ412SA, EZ413SA and EZ414SA only with the EZ402 mandrel. 5 pieces per pack. 1/4" diameter 430 Grit: 1/2" diameter 431 (x6) 438 (x6) 446 (x6) 60 120 407 240 408 (x6) 432 (x6) 445 (x6) 60 120 240 EZ407SA 3/4" diameter Grit: 411 412 413 180 Coarse 220 Medium 240 Fine EZ411SA (x5) EZ412SA (x5) EZ413SA (x5) 60 Coarse 120 Medium 240 Fine EZ414SA (x5) 60 (x2), 120 (x2), 240 40 ROTA RY TOOL ACCESSORIES MISCELLANEOUS M AND RELS A ND COL L E TS M AND R EL – 4 0 1 Use with 414, 422 and 429. M AND R EL – 4 02 Use with 409, 411, 412, 413, 420, 423E, 425, 426, 429, 456, EZ471SA, EZ472SA, EZ473SA, 511E, 512E, 540, 541 and 506CU. E Z Loc k™ MA ND R EL – EZ4 02 Use with EZ409, EZ426CU, EZ456, EZ411SA, EZ412SA, EZ413SA, EZ471SA, EZ472SA, EZ473SA, EZ476, 423E, 511E, 512E, EZ541GR, EZ544, EZ545 and EZ506CU. D R E M E L C H U C K – 4 4 8 6 This chuck allows you to quickly and easily change accessories on Dremel Rotary Tools without changing collets. Accepts accessories with 1/32" - 1/8" shanks. Use with rotary tool models 100, 200, 275, 285, 300, 3000, 395, 398, 400, 4000, 750, 770, 780, 800, 8200 8050, 8100 and 8220. Also use with Dremel attachments 225 and 575. Not compatible with the 4200. Q U I C K C H A N G E CO L L E T N U T S E T – 4 4 8 5 Includes Collet Nut and 4 Collets. For use with all Rotary Tools except models 1, 2 & 260, 270, 280 series 1 or earlier. Collets also available separately. Not compatible with the 4200. E Z CHA NGE COLLETS – 4 200 For specific use with 4200. 1/8" 3,2 mm 3/32" 2,4 mm 1/16" 1,6 mm 1/32" 0,8 mm 481 482 483 480 401 402 EZ402 4486 4485 1/8" 3,2 mm 3/32" 2,4 mm 1/16" 1,6 mm 1/32" 0,8 mm EZ480 EZ481 EZ482 EZ483 CARBON MOTOR BRUSHES B RUSH TO O LS 90828* 90930-04 232 & 332 275, 285, 300, 395 & 595 90930-04 6000 90930-04 TYPE 100, 200, 275, 285, 300, 395, 595 & 3000 90930-04 6000 3, 4, 5&6 1&2 4, 5, &6 1&2 * Available as service part only. 41 B RUS H TO O LS 90931 398 90935 732 90940 4000 TYPE MISCELLANEOUS D RIL L BITS 1 / 8 " D R I LL B I T – 15 0 Available as service part only. 7 P IECE D R I LL B I T SET – 628 For use with 4485 collet nut kit or the 4486 Dremel Chuck. BRAD POINT DRILL BIT SET – 631-01 Titanium coated brad points stay on center and begin drilling immediately. For use on wood. 1 / 3 2 " D R I LL – 6 6 0 4 pc. per pack. Use with 483 collet. 3 / 6 4" D R I LL – 6 6 1 4 pc. per pack. Use with 482 and EZ483 collet. Available as service part only. GLASS DRILLING BITS – 662DR, 663DR Diamond tipped drill bits for use on glass and ceramic wall tile. Lubricant included. NEW! D I A M OND D R I LL FLI PB I T – 664 DR Longer life and faster at eliminating material. FlipBit design lets you drill two hole sizes with one bit by simply flipping the bit over. 661 1/32" 0,8 mm 3/64" 1,2 mm 150 1/16" 1,6 mm 3/32" 2,4 mm 5/64" 2,0 mm 7/64" 2,8 mm 1/8" 3,2 mm 628 1/8" 5/32" 3/16" 1/4" 3,2 mm 4,0 mm 4,8 mm 6,4 mm 1/32" 0,8 mm 631-01 660 1/8" 3,2 mm 662DR 1/4" 6,4 mm 1/16" & 3/32" 1,6 mm & 2,1 mm 663DR 664DR OTH ER EZ T W I ST NOSE CA P – EZ 495 Loosen or tighten the collet and replace an accessory quickly and easily without the need for a wrench. W R E N C H – 9 0 9 6 2 For ease of changing bits. 3/8" x 1" DRESSING STONE – 415 Clean grinding wheels. Shape or reshape for desired applications. Available as service part only. EZ495 90962* 415 42 M I N I ACC ESSO RY K I TS C L EA NI NG/POLI SHI NG KI T – 68 4 - 01 Polish a variety of materials to a high luster, clean those tough-to-reach areas, plus a whole lot more! 20 ASSORT ED ACCESSOR IES Cleaning/Polishing - 403, 404, 405, 414 (x6), 421, 422, 425 (x2), 428, 429 (x3), 520 Miscellaneous - 401, 402 SA N D I NG / GR I ND I NG KI T – 68 6- 01 Sharpen lawn tools, remove rust, sand down a sticking door, and engrave on glass, plus a whole lot more! 3 1 ASSORT ED ACCESSOR IES Grinding/Sharpening - 8193, 84922, 85422, 932 Cutting - 426 Sanding - 407, 408 (x4), 412 (x15), 432 (x4), 511 Miscellaneous - 402 G ENER A L PU R POSE KI T – 687- 01 Everything you need to cut, carve, sand, grind, clean, and polish, plus a whole lot more! 5 2 ASSORT ED ACCESSOR IES Carving/Engraving - 194 Grinding/Sharpening - 85422, 952 Cutting - 409 (x36), 426 Cleaning/Polishing - 403, 414 (x2), 421, 429 (x2) Sanding - 407, 408, 432 (x2) Miscellaneous - 401, 402 CU TT I NG KI T – 6 88- 0 1 Reslot a screw, cut conduit, sheet metal, rusted hose clamps, plus a whole lot more! 69 ASSORT ED ACCESSOR IES Cutting - 409 (x36), 420 (x24), 426 (x3), 540 (x5) Miscellaneous - 402 CA RV I NG /ENGR AV I NG KI T – 689- 01 Carve intricate details, etch glass, stoneware, terracotta, plus a whole lot more! 1 1 ASSORT ED ACCESSOR I ES Carving/Engraving - 105, 106, 107, 108, 7103, 7134 Grinding/Sharpening - 83142, 83322 , 83702, 84922 Miscellaneous - 85602 RO UT ER B I T KI T – 692 For routing, inlaying and mortising in wood and other soft materials. Use with #330 Router Attachment, #335 Plunge Router Attachment, and #231 Shaper/Router Table. 6 ASSORT ED ACCESSOR I ES Routing - 612, 615, 617, 618, 650, 654 43 E Z LOCK™ SA ND I NG/POLI S H IN G K IT – EZ 6 84 - 0 1 Polish a variety of materials to a high luster, clean those tough-to-reach areas, remove rust, plus a whole lot more! 7 ASSORT ED ACCESSOR I ES Cleaning/Polishing - 421, 423E Sanding - EZ471SA, EZ472SA, 511E (180 & 280 Grit), 512E E Z LOCK™ SA ND I NG/GR I N DIN G K IT – EZ 6 86 - 0 1 Contains all of the sanding and grinding products a consumer needs. 1 8 ASSORT ED ACCESSOR I ES Grinding - EZ541GR, 84922, 952 Sanding - 408 (x3), EZ411SA (x2), EZ412SA (x2), EZ413SA (x2), 432 (x3), 511E Miscellaneous - EZ402, EZ407SA E Z LOCK™ CU T T I NG KI T – E Z 68 8 - 01 Reslot a screw, cut conduit, sheet metal, rusted hose clamps, plus a whole lot more! 1 1 ASSORT ED ACCESSOR I ES Cutting - EZ409 (x3), EZ456 (x4), EZ476 (x3) Miscellaneous - EZ402 A L L-PU R POSE ACCESSORY K IT – E Z 725 The EZ All-purpose accessory storage kit is the first Dremel accessory kit offering 100% all EZ accessories. 70 ASSORT ED ACCESSORIES Cutting -EZ544, EZ541, EZ476 (x2), EZ409 (x3), EZ456 (x4) Sanding -EZ407, EZ411SA (x6), 408 (x20) 432 (x20), EZ413SA (x6) Cleaning/Polishing - 511E, 512E, EZ423 (x3) SU P ER ACCESSORY KI T – 709- 02 This versatile and re-usable accessory kit includes everything you need to cut, grind, sand, polish, drill, sharpen, clean and more. 1 10 ASSORT ED ACCESSORIES Carving/Engraving - 191 Grinding/Sharpening - 83142, 84922, 952, 953 Cutting - 409 (x12), 420 (x12), 426, 540 Cleaning/Polishing - 414 (x4), 421, 429 (x4) Sanding - 407, 408 (x6), 411 (x14), 412 (x13), 413 (x13), 430, 431 (x6), 432 (x6), 438 (x5) Miscellaneous - 401 (x2), 402, 415, Wrench A L L-PU R POSE ACCESSORY K IT – 7 10- 08 This versatile and re-usable accessory kit includes everything you need to cut, grind, sand, polish, drill, sharpen, clean and more. 16 0 ASSORT ED ACCESSORIES Carving/Engraving - 191 Grinding/Sharpening - 84922, 932, 952 Cutting - EZ456 (x2), EZ476 Cleaning/Polishing - 414 (x5), 421, 428, 429 (x5) Sanding - 407, 408 (x15), 411 (x25), 412 (x25), 413 (x25), 430, 431 (x15), 432 (x15), 438 (x15) Miscellaneous - 401, 402, EZ402, EZ495, Wrench 44 OSCI LL AT I NG TOOLS THE MAKERS OF VERSATILE TO OL SYSTEMS 45 WHAT IS AN OSCILL ATING TOOL? Multi-Max™ oscillating tools, like rotary tools, use a variety of accessories to accomplish a wide range of DIY tasks for repair, remodeling and restoration. However, rather than spinning like a rotary tool, Multi-Max oscillating tools use rapid side- to-side motion to cut, scrape, sand, remove grout, grind and more. You can rest assured that a Dremel Multi-Max oscillating tool will help you get the job done with superior versatility, durability, and control. 46 OSC I L L AT I NG TO OLS The Only Tool You Need Limited Warranty High Torque Mechanism To power through the most demanding applications. Fold Away Control Foot For cutting stability and accuracy. 9X Faster HYPER-SPEED To complete projects faster - save time & money. Unlock – 1 Insert – 2 Lock 3 Patented Control Foot & New Blade Designs For fast, accurate cuts in long sheet material. More Accurate Easier to use than recip saws in tougher materials. Compatible with Universal Oscillating Tool Accessories Tackle heavy duty and precision applications. 47 CONTROL FOOT Open – 1 Release – 2 Close 3 FO L D -AWAY CONT ROL FO OT TRADITIONAL OSCILLATING VELOCITY™ KIT RIP CUTS VC60-01 • Dremel Velocity™ tool 10 ASSORT ED PI ECES Cutting - MM450, VC490, VC494 Sanding - MM14, MM70P (x3), MM70W (x3) Misc - Storage Case 48 OSC I L L AT I NG TO OLS Repai r. Remodel . Resto re. Faster. ™ Limited Warranty Quick Lock™ For tool-less and secure accessory changes. High-Performance 3.8 Amp Motor For the most demanding applications. Unlock – 1 Insert – 2 Lock 3 Variable Speed For optimal performance and control in a variety of materials. Smart Boost Auto adjusts power and speed as needed. 65% More Power vs. the 6300. Separate On/Off Switch Retains speed setting for ease of use. Accessory Quick Fit™ Interface System Compact Design For fast accessory changes without removing the clamping screw. Provides easy access to tight areas. 49 M ULTI- MA X ™ K IT MM 4 0 - 0 5 • Dremel Multi-Max™ MM40 tool 3 6 ASSORT ED PI ECES Cutting - MM450, MM435, MM480, MM482 Scraping - MM610 Sanding - MM14, MM70P (x14), MM70W (x15) Grout Removal - MM502 Misc - Storage Case 50 OSC I L L AT I NG TO OLS Repai r. Remodel . Resto re.™ Limited Warranty Powerful 3.3 Amp Motor Easily tackles the toughest applications. Variable Speed For optimal performance and control in a variety of materials. Quick Release Integrated wrench for convenient accessory changes. Quick Hold Magnetic flange holds the accessory in place for easier accessory tightening. 3.2° Degree Oscillation Delivers a faster speed of cut. Separate On/Off Switch Retains speed setting for ease of use. Compact Design Provides easy access to tight areas. 51 M ULTI- MA X ™ K IT MM 30 - 0 4 • Dremel Multi-Max™ MM30 tool 1 1 ASSORT ED PI ECES Cutting - MM435, MM450, MM480 Sanding - MM11, MM70P (x3), MM70W (x3) Grout Removal - MM502 Misc - Storage Bag 52 OSC I L L AT I NG TO OLS Repai r. Remodel . Resto re.™ Limited Warranty Powerful 2.3 Amp Motor Efficient Motor Easily tackles the toughest applications. Runs cool and smooth under load. Variable Speed Retains speed setting for ease of use. For optimal performance and control in a variety of materials. Compact Design Separate On/Off Switch Provides easy access to tight areas. Quick Fit™ For fast accessory changes without removing the clamping screw. 50% More Power Accessory Quick Fit™ Interface System vs. the 6300. For fast accessory changes without removing the clamping screw. M ULTI- MA X ™ K IT MM 20 - 07 • Dremel Multi-Max™ MM20 tool 7 ASSORT ED PI ECES Cutting - MM450, MM480 Sanding - MM14, MM70W (x3) Misc - Allen Wrench 53 OSC I L L AT I N G TO OL OV E RV I EW Model VELOCITY™ MM40 MM30 MM20 Amps 7.0 3.8 3.3 2.3 OPM 10,000–16,000 10,000–21,000 10,000–23,000 10,000–21,000 Electronic Feedback Control Yes Yes No No Number of Speeds Variable & Hyper Variable Variable Variable Soft Grip Yes Yes Yes Yes Separate On/Off Yes Yes Yes Yes QuickFit™ Accessories Yes Yes Yes Yes Tool-less Accessory Change System Quick-Change Yes Integrated Wrench No Weight 4 lb. 7oz. 2 lb. 15 oz. 2 lb. 7 oz. 2 lb. 7 oz. Warranty 2 year 2 year 2 year 2 year 54 OSCILLATING TOOL ACCESSORIES Dremel Multi-Max™ accessories undergo rigorous testing so you can feel assured that you are purchasing a product of proven value & performance. CU TTING Flush cut a baseboard to install new flooring or cut out drywall to install a new light switch. Choose from 14 blades to accomplish a variety of tough cuts. 3/8" Wood Flush Cut Blade 3/4" Wood & Metal Flush Cut Blade 3/4" Wood Flush Cut Blade Multi-Knife Drywall Jab Saw MM411 MM422 MM440 MM430 MM435 3" Wood & Drywall Saw Blade 3.5" Wood & Metal Saw Blade MM450 55 1-1/8” Wood Flush Cut Blade MM452 3/4" Wood Flush Cut Blade 3/4" Wood & Metal MM470 MM472 MM460 1-1/4" Caride 1-1/4" Wood Flush Cut Blade Flush Cut Blade MM485 MM480 1-1/8" Wood & Metal Flush Cut Blade MM462 1-1/4" Wood & Metal Flush Cut Blade MM482 MM480U MM482U Bulk Packs - 3 per pack MM480B (x3) 1-5/8" Universal Carbide Flush Cut Blade Bulk Packs - 3 per pack NEW! NEW! 1-5/8" Universal Wood & Metal Flush Cut Blade NEW! 1-5/8" Universal Wood Flush Cut Blade MM485U MM480BU MM485BU 3-Pack Cutting Assortment (MM480U, MM482U, MM485U) 3-Pack Cutting Assortment (MM482, MM480, MM450) MM488BU MM492 MM485B (x3) 3-Pack Cutting Assortment (MM440, MM450, MM422) MM422B (x3) MM440B (x3) MM450B (x3) MM472B (x3) MM491 MULTI-FLEX™ ACCESSORIES Multi Flex™ Bracket* *Not compatible with MM40/MM45 Multi-Flex™ Spiral Blade Multi-Flex™ Saw Blade Multi-Flex™ Carbide Blade MM721 (x4) MM722 (x3) MM723 MM720/MM725 56 OSCILLATING TOOL ACCESSORIES G RIND ING Prepare surfaces for ceramic floor tile replacement. Use the diamond paper to remove cement, plaster, and thin-set mortar. Use the carbide rasp to grind and shape flat surfaces, cement, tile adhesives, stone and rasp wood. 60 Grit Diamond Paper MM900 60 Grit Diamond Paper MM910 Carbide Rasp MM920 SA ND ING Restore windows, make stuck doors work, and remove rust from metal. Available in assorted grit for sanding bare or painted wood and metal. 18 per pack: 80(6), 120(6), 240(6) Grit MM70P Sanding Sheets - Wood 18 per pack: 6 per pack: 60(6), 120(6), 60(2), 120(2), 240(6) Grit 240(2) Grit MM80P MM70W MM730 57 MM14 Contour Sanding Tubes 80(3), 120(3), 240(3) Grit NEW! Contour Sanding Accessory 5 Contours; 80(3), 120(3), 240(3) Grit Sanding Tubes MM80W Hook & Loop Pad NEW! Sanding Sheets - Paint 6 per pack: 80(2), 120(2), 240(2) Grit MM731 GROUT REMOVA L 1/8" Grout Removal Blade 1/16" Grout Removal Blade 1/16" Grout Removal Blade NEW! Remove wall and floor grout to free a broken tile. Available in a 1/8" size and a 1/16" size. MM500 MM501 MM502 SCRA PING Use the rigid scraper blade for removing stuck vinyl flooring, carpeting and carpet pad, and the flexible scraper blade for projects such as removing old caulking around the tub or shower. Rigid Scraper Blade Flexible Scraper Blade MM600 MM610 MISCELLANEOUS 1-3/ 1 6 " U N I V E RS A L A DA P T E R – M M 3 0 0 Adapters allow use of Dremel accessories on most oscillating tools brands. ACC ESSORY K ITS 14-Piece Multi-Max™ Accessory Kit MM300, MM482, MM610, MM450 (2), MM70W (9) MM388 6-Piece Multi-Max™ Cutting Kit MM300, MM480, MM482, MM450 (3) 13-Piece Multi-Max™ Cutting Kit MM430, MM435 (2), MM480 (2), MM482, MM450 (2), MM70W (60, 120 and 240 grit), MM610, MM910 MM389 MM495 58 M ULT I - SAWS THE MAKERS OF VERSATILE TO OL SYSTEMS 59 WHAT IS A DREMEL M U LTI -SAW? A multi-saw like the Dremel Saw-Max, is a powerful and compact circular saw that uses abrasive wheels to cut through virtually any material with ease and speed. The ergonomic design provides comfort in handling, with an excellent line of sight when making straight, flush or plunge cuts in wood, plastic, tile and more. Plus, the Dremel Ultra-Saw offers even more versatility with the ability to perform surface preparation for the removal of paint, rust and thin-set. For fast cuts in a variety of materials, Dremel multi-saws are up for the job. 60 U LT RA- SAW ™ TOO L SYST E M 31 in ULTRA-SAW™ Limited Warranty Cuts Widest Variety of Materials 3 Applications in 1 tool For flush cuts, rip cuts and material removal. Cuts wood, plastic, metal, tile, masonry & more. Powerful 7.5 Amp Motor Clear line of sight For tough applications. Increased power and larger wheels – Faster cutting and improved performance. ULTRA-SAW ™ K IT US40 - 0 1 • ULTRA-SAW™ US40 Tool Handle Attachment, Storage Bag 4 ASSORT ED ACCESSOR I ES Cutting - US500, US510, US600 Grinding - US410 61 Adjustable depth control ULTRA-SAW ™ K IT US40 - 02 • ULTRA-SAW™ US40 Tool Handle Attachment 2 ASSORT ED ACCESSOR I ES Cutting - US500, US510 ULTRA-SAW ™ K IT US40 - 03 • ULTRA-SAW™ US40 Tool Handle Attachment, Storage Bag 5 ASSORT ED ACCESSOR I ES Cutting - US500, US510 (x2), US520, US600 2 CU TTING W H EEL POSITIO N S SAW FLUSH CUT SURFACE PREP Interior Position Exterior Position For standard straight cuts. For flush cuts or surface preparation ULTRA-SAW ™ ACCESSO R IES Paint and Rust Surface Prep Wheel US400 Diamond Surface Prep Abrasive Wheel Wood US410 US500 Masonry Diamond Tile Wood Flush Cut US520 US540 US600 Metal US510 6-Piece Cutting Wheel Kit US500 (x2), US510 (x3), US540 (x1) US700 62 SAW- MA X ™ TO OL SYST E M Limited Warranty Versatile Cutting System Two cutting wheel positions Compact size and gripping zone Cuts wood, plastic, metal, tile, masonry & more. For straight, plunge and flush cuts. For user friendly one handed operation. Powerful 6 Amp Motor Adjustable Depth Guide For tough applications. And plunge action for precision and control. Worm Drive Gearing For durability and power. Excellent line of sight For confident, precise cuts. SAW-MA X ™ K IT S M20 - 02 • SAW-MAX™ SM20 Tool, 2 x 4 Guide, Dust Port Adapter • Storage Case 4 ASSORT ED ACCESSOR I ES Cutting - SM500, SM510, SM540, SM600 63 Dust Extraction Port For clean work environment. SAW-MA X ™ K IT S M20 - 03 • SAW-MAX™ SM20 Tool 2 ASSORT ED ACCESSOR I ES Cutting - SM500, SM510 Plunge Into Material For clean and precise cuts. One-handed Operation 2 CU T TING W H EEL POSITIO NS 1 2 Interior Position Exterior Position For standard straight cuts. For flush cuts with SM600. 64 SAW- MA X ™ ACC ESSO R I ES Dremel Saw-Max™ tool only uses Dremel Saw-Max™ accessories. CU T TING Wood & Plastic Cutting Blade SM500 Metal Cutting Blade Masonry Cutting Blade SM510 (x3) 7 pc Cutting Kit SM500, SM540, SM520 (x2), SM510 (x3) SM700 65 SM520 (x3) Tile Cutting Blade Wood & Plastic Flush Cut Blade SM540 SM600 12 pc Cutting Kit SM600, SM500 (x2), SM540, SM520 (x2), SM510 (x6) SM710 SAW- MA X ™ AT TACH M E N TS 2 x 4 Guide Dust Port Adapter SM842 TRSM810 Straight Edge/ Circle Guide Miter Guide TRSM800 SM840 Crown Moulding Guide SM844 I D E A L FOR T R IMWOR K 1 Angle cut to create miter joint (SM840) 2 Bevel Cut for Corner Joint (SM840) 3 Straight Cut to Butt Joint Trim at Door Jamb (SM840) 4 Compound Miter Cuts for Crown Molding Joints (SM844) 66 3 D P R I N T I NG THE MAKERS OF VERSATILE TO OL SYSTEMS 67 SE T YOUR IMAGINATION FREE WITH 3D PRINTING TECHNOLO GY Expand your creativity by building your own prototypes or take a hobby to exciting new levels. You can also design or personalize items that reflect your individuality. It satisfies your desire to challenge your mind, while also inspiring others to explore their version of 3D possibilities. Trust the Dremel 3D Idea Builder to be your most reliable and user-friendly 3D printer on the market. Backed by superior quality and unbeatable customer support, the Dremel 3D Idea Builder allows you to begin building your creations instantly. 68 3D I D E A BU I L D E R Onboard Software Enables stand-alone operation. Pre-Installed Extruder Provides fast out-of-the-box use. Full Color Touch Screen Lets you go from file to building effortlessly. Active Cooling Fan Prevents warping of objects while they are built. Best-In Class Build Resolution Removable Build Platform For higher quality objects. For precise object removal. Easy To Use Software Bright Led Lights For simple customization of 3d models. For optimal viewing of the build platform. Fully Enclosed Gripped Feet For noise reduction and stable operation. For reduced vibration and added stability. 3D ID EA BU IL D ER K IT • • • • 69 3D 20 - 0 1 3D IDEA BUILDER PLA Filament Dremel 3D Software 100+ Dremel Quality Projects Included Build Instantly It is easy to build objects with the Dremel on-board software and color touchscreen, which enables a preview of each model before you build. Additionally, the Dremel 3D Idea Builder comes equipped with a pre-installed extruder (the part where the filament comes out and builds your model), unlike other 3D printers that require you to install it yourself. This makes setup as simple as plugging in your printer, and you're ready to build! Along with easy-to-use software, you can start turning your ideas into models and projects in minutes. Easy-to-Use Software When working with print-ready files, Dremel 3D software gives you the ability to change your object’s location, orientation and size on the build platform. Plus, the build settings allow you to customize both the build quality and the build time with temperature, infill and speed control. The easy-to-use toolbar icons let you import, layout, repair, support and preview your objects to make them fit your imagination. I m po r t L ayo u t Re pa i r Su ppo r t s Prev i ew Ex po r t The Dremel Difference Dremel PLA filament has been specifically engineered for optimal printing with the Idea Builder. PLA is a thermal plastic that softens and melts when it’s heated, building your designs strand by strand and layer by layer. Our PLA has been designed to melt at a temperature compatible with the Idea Builder, producing a stable, strong object with a high quality finish. FI LA MENT Black DF02-01 Purple DF05-01 Blue Gold Green Orange DF06-01 DF51-01 DF07-01 DF04-01 Red Silver White DF03-01 DF50-01 DF01-01 White Translucent DF70-01 70 SPECIALTY TOOLS THE MAKERS OF VERSATILE TO OL SYSTEMS 71 WHAT IS A SPECIALT Y TOOL? For dedicated projects where a multi-purpose tool just won’t do, Dremel Specialty Tools have you covered. From engraving and soldering, to scroll cutting and precision carving, the tool line-up includes the features to complete a project effortlessly, and the accessories to make it efficient. Cut wood, carve stone, fuse rope, engrave glass and more with the versatile line of Specialty Tools. 72 M OTO - SAW ™ TO OL SYST E M MOTO-SAW™ Portable. Precise. Ea sy ™ 21 in Limited Warranty 1,500-2,250 SPM 2.4 lbs. Detachable Coping Function Clamp Base For handheld use to take the tool to the work piece. For optimal cutting in a variety of materials. Auto Tensioning Quick Change Dust Port Adapter For easy accessory change and optimal tensioning. M OTO- SAW ™ K IT MS 20 - 0 1 • Dremel MS20 Moto-Saw, Fast Clamp Base Vacuum Adapter, Storage Case 10 ASSORT ED ACCESSORIES Cutting - MS51 (x4), MS52 (x4), MS53, MS50 73 Attaches to various tables, benches and surfaces. Variable Speed Control Keeps line of sight clear and work space clean. M OTO- SAW ™ ACCESSO R IES Side Cutting Wood & Plastic MS50 Wood & Plastic MS51 Fine Wood Metal MS52 MS53 4" Long Blades (standard scrollsaw blades are 5") 74 BUTA N E TO O LS Integrated Ignition Button Easy startup, no independent ignition tool required. Limited Warranty Variable Temperature and Flame Control Versatile use in both torch and flame mode. Detachable Base For hands-free operation. FillingValve Allows for quick recharge. V E RSA F L A ME ™ K IT • • • • 2 20 0 - 0 1 VersaFlame™ Multi-function Butane Torch 4 Tips: Soldering, Blower, Deflector, Flame Diffuser Solder, Sponge, Tin, Wrench Storage Case Integrated Ignition Trigger Easy startup, no independent ignition tool required. Safety Lock Prevents accidental ignition. Flame Control Slider Lets you select the right temperature for your project. Filling Valve Allows for quick recharge. V ERSATIP K IT ™ 2000 - 0 1 • VersaTip™ Butane Soldering Torch • 6 Tips: Soldering, Cutting Knife, Shaping Knife, Hot Air, Wide Blower, Deflector • Solder, Sponge, Storage Tins, and Wrenches • Protective Cap, Storage Case, Manual 75 Limited Warranty E NGRAVE R Identify and personalize your valuables. Use for decorative engraving. Engraves metal, glass, wood, plastic, and ceramics. Holding area allows for extended use. Soft grip adds extra comfort and control. Limited Warranty Motor: 120V, AC/115V, 60Hz, .2 amps/0,2 A Strokes: 7,200/SPM | Tool Weight: 12 oz. (340 g) ENG RAV E R K IT 29 0 - 0 1 • Engraver Tool, Letter / Number Template • Carbide Point (9924) ENG RAV E R ACC ESSO R IES Carbide Point – 9924 For most applications D ia mond Po int – 9929 For continuous use 9924 9929 76
MM422
1. 物料型号:文档列出了Dremel不同系列的电动旋转工具,包括FORTI-4200、DREMEL 4000、3000、200、100和VRT1等型号,以及它们的技术参数和特点。
2. 器件简介:文档介绍了Dremel电动旋转工具的历史和多功能性,它们可以用于各种任务,具有高速度和低扭矩的特点。
3. 引脚分配:文档中没有提到具体的引脚分配信息,因为这些是电动工具而非电子元件。
4. 参数特性:每个工具型号都有详细的参数列表,包括安培数(Amps)、速度范围(Speed Range [RPM])、多功能性等级(Versatility Level)、是否有电子反馈控制(Electronic Feedback Control)、速度选择数量(Number of Speeds)、是否有软握把(Soft Grip)、附件更换系统(Accy.Change System)、重量(Weight [oz.])和保修期(Warranty)。
5. 功能详解:文档详细描述了每个工具的功能,例如FORTI-4200型号具有集成的EZ Change™系统,可以快速轻松地更换附件,以及可变速度和电子反馈控制功能。
6. 应用信息:文档提供了各种工具的应用范围,例如某些型号适用于广泛的应用,而其他型号则适用于特定的精密应用。
7. 封装信息:文档中没有提到封装信息,因为这与电子元件的封装不同,但提供了工具的物理描述,如握把设计、重量和附件接口等。
MM422 价格&库存
很抱歉,暂时无法提供与“MM422”相匹配的价格&库存,您可以联系我们找货
