FS-01
FS-01
    DREMEL
    DIGILAB AIR FILTRATION UNIT
FS-01 数据手册
www.bofa.co.uk/laser-fume-extraction.asp LASER Fume Extraction Solutions 350 Fume extraction system for light duty laser marking, coding and engraving applications. BOFA’s Advantage 350 fume extraction and filtration system effectively removes potentially harmful fumes and particulates created during the laser marking process. By maintaining a dust-free operating area, the system helps to protect valuable equipment, maintain a higher quality mark, and reduce the number of rejects and contaminants. The quiet and compact Advantage 350 is ideal for use in light duty laser marking applications, including schools, sign making workshops and small scale industrial environments. TYPICAL APPLICATIONS: • Lasering • Marking • Welding • Drilling • Coding • Engraving • Cutting STANDARD FEATURES: • • • • • Blower with high airflow and pressure Low cost replacement filters Filter condition indicator Low noise levels Digital flow control system OPTIONAL FEATURES: • • • • Nitrogen Dioxide sensor VOC gas sensor (Volatile Organic Compound) Remote stop / start interface Filter change / System fail signal TECHNOLOGY: DeepPleat filter technology Advanced Carbon Filter technology HEPA filter technology Reverse Flow Air technology SureCheck Quality Standard Combined HEPA/chemical filter and pre filter Back UNIT PART NUMBERS OPTIONS Model 24V Stop / Start Filter change / System failure signal VOC Monitoring A2001 A2002 A2003 Voltage AD 350 Powder Coated Part No. 90V - 257V AD 350 with NOx sensor Powder Coated AIRFLOW THROUGH FILTERS Chemical Filter L0542A0000 HEPA Filter Full Chemical Layer Pre Filter L0542A8212 Clean Air REPLACEMENT FILTER PART NUMBERS Model Contaminated Air DeepPleat Pre Filter AD 350 Combined HEPA / Gas Filter Particulate A1030055 A1030056 AD 350 with NOx sensor Small particulate is held in the full HEPA material layer Medium sized particulate held in 6m² of filter media A1030355 Large particulate settles to the bottom of the filter box TECHNICAL DATA EU US Dimensions (HxWxD) 590 x 375 x 375 mm 23.2 x 14.8 x 14.8” Cabinet Construction Brushed stainless steel / Powder coated mild steel Airflow / Pressure 380m³/hr / 96mbar Electrical Data 115-230v 1ph 50/60Hz Full load current: 12.5 amps / 1.1kw Noise Level < 60dBA (at typical operating speed) Weight 40kg 88lbs Approvals CE UL DEEPPLEAT PRE FILTER SPECIFICATIONS Surface Media Area 6m² approx Filter Media Glass Fibre Filter Media Construction 100mm DeepPleat construction with Webbing Spacers Filter Efficiency F8 (95% @ 0.9 microns) TECHNICAL SPECIFICATION 1 2 3 223cfm / 96mbar 2 HEPA Filter Media Glass Fibre HEPA Media Construction Maxi Pleat Construction with Webbing Spacers Filter Housing Zintec Mild Steel Treated Activated Carbon 9kgs Filter Efficiency 99.997% @ 0.3 microns 6 7 8 9 Hose Inlet Connection - 100mm Exhaust Outlet Nitrogen Dioxide Sensor 3 1 8 8 7 Back Front Right Side AD350:16/8/16V:2.4 Email: sales@bofa.co.uk Email: sales@bofaamericas.com 9 5 Power Cable Inlet Motor Cooling Inlet Filter Latch 3 Other hose kits and filters are available. All of the above units are fitted with our standard filter combinations. For specific applications please call us for details. Replacement filters should always be ordered using the part number on the filters inside your extractor to ensure the correct filter is ordered. Datasheet correct at time of print. BOFA AMERICAS, INC Tel: (618) 205 5007 Fax: (866) 707 2632 4 5 6 4 COMBINED FILTER SPECIFICATIONS BOFA INTERNATIONAL LTD Tel: +44 (0) 1202 699 444 Fax: +44 (0) 1202 699 446 Filter Condition Display On / Off Switch Signal / Interface Cable Web: www.bofa.co.uk Web: www.bofaamericas.com British Quality
FS-01 价格&库存
很抱歉,暂时无法提供与“FS-01”相匹配的价格&库存,您可以联系我们找货
