MM35-01
MM35-01
    DREMEL
    MM35-01 120V 3.5A OSCILLATINGTOO
MM35-01 数据手册
                       Multi‐Max™ MM35‐01 Tool Kit Model # MM35‐01 Product Specifications The Dremel Multi‐Max MM35 features 3.5 amps of power to easily tackle the toughest applications. The tool‐less innovative design for quick and secure accessory change solves the pain point of needing a wrench to perform the same operation. The extra‐wide 3.2‐ degree angle of oscillation delivers fast and precise cuts. The variable speed 10,000‐21,000 OPM allows for optimal performance and control with a variety of materials. The provided soft bag is a great value added to store tool and accessories.  Powerful: 3.5 Amp motor easily tackles the toughest applications  Tool‐less accessory change: innovative design for quick, secure accessory change without a wrench  Fast and precise cuts: the extra‐wide 3.2 degree oscillation angle provides the right speed to tackle any application  Variable speed – from 10,000‐21,000 OPM for optimal performance and control with a variety of materials  Ergonomically optimized: soft grip for comfort and control  7 Ft. durable rubber cord: for a wide working range     DIMENSIONS Cord Length: 7[ft] Case Type: Bag Tool Level: 1 ‐ Corded – variable speed high Warranty: Limited 2 Years Material: Composite Height: 3.5["] Certifications: CSA Model Number: MM35‐01 Weight: 2.8[kg, lb, oz] Amperage: 3.5 Voltage: 120V Length: 14.2["] Width: 2.5["] Oscillating Angle: 3.2°                        https://www.dremel.com/en_US/products/‐/show‐product/tools/multi‐max‐mm35‐01‐tool‐kit 10‐12‐18
MM35-01 价格&库存
很抱歉,暂时无法提供与“MM35-01”相匹配的价格&库存,您可以联系我们找货
