MM402E
MM402E
    DREMEL
    MM402E EDGE WOOD FLUSH CUT BLADE
MM402E 数据手册
  MM402E Edge™ Wood Flush Cut 4-Pack Model # MM402E Product Specifications The Edge™ Wood Flush Cut Four Pack Comes With Four Bracketless Blades That Mount In The Rigid Adapter Plate Sold Separately In The Edge™ Starter Cutting Kit.     Wood flush cut blade—high carbon steel teeth optimized for fast cutting in wood and plastic materials Bracket-less design blades-- passing value on to users Saves money--four cutting edges, offer more cutting value Blades fit universal adapter for use on most competitive brand oscillating tools DIMENSIONS Blade Thickness (in): Description: Blade Thickness: Blade Length: Application: Warranty: Blade Width: Color Code: 0.024 MM402E Edge Wood Flush Cut 4-Pack 0.024["] 2.22 Wood and plastic cutting. Product Defects Only 1.28 Red https://www.dremel.com/en_US/products/-/show-product/accessories/mm402e-edge-wood-flush-cut-4-pack 10-10-18
MM402E 价格&库存
很抱歉,暂时无法提供与“MM402E”相匹配的价格&库存,您可以联系我们找货
MM402E
