MM404E
MM404E
    DREMEL
    MM404E EDGE BIM FLUSH CUT BLADE
MM404E 数据手册
     MM404E Dremel Edge™ Wood & Metal Flush Cut Blades Model # MM404E Product Specifications The Edge™ Cutting System Was Created For People Who Do A Lot Of Cutting With Their Oscillating Tool And Want To Save Time And Money On New Cutting Blades. The Edge™ Wood And Metal Flush Cut Four Pack Comes With Four Bracket-less Blades.     Wood flush cut blade—bi-metal teeth optimized for fast cutting in wood and metal materials Bracket-less design blades-- passing value on to users Saves money--four cutting edges, offer more cutting value Blades fit universal adapter for use on most competitive brand oscillating tools DIMENSIONS Blade Thickness (in): Description: Blade Thickness: Blade Length: Application: Warranty: Blade Width: Color Code: 0.024 MM404E Edge Wood & Metal Flush Cut Blade 4-Pack 0.024["] 2.22 Wood & Metal cutting Product Defects Only 1.28 Red https://www.dremel.com/en_US/products/-/show-product/tools/mm404e-dremel-edge-wood-metal-flush-cut-blades 10-10-18
MM404E 价格&库存
很抱歉,暂时无法提供与“MM404E”相匹配的价格&库存,您可以联系我们找货
