PC362‐3 Versa Power Cleaner Eraser Pad
Model # PC362‐3
Product Specifications
The Dremel Versa Eraser Pad gently removes dirt, stains and scuff marks from hard surfaces.
Perfect for doors, walls, floors and more, the micro-abrasive surface can be used dry or with
water. Combine the multi-purpose cleaning pad with the Dremel Versa's high speed scrubbing
action, and jobs will be complete in no time.
Multi-purpose micro-abrasive for use on hard surfaces
Recommended uses: walls, floors, doors, shoes, glass and more
Quick and easy accessory change with the hook and loop system
Oversized accessories get into corners and tight spaces
DIMENSIONS
Diameter:
Weight:
Application:
Material:
RPM:
2.5"
0.11[kg, lb, oz]
Indoor cleaning (counter tops, baseboards, appliances, walls,...); Outdoor
cleaning (glass on your patio furniture, tiles, sneakers…)
Melamine Foam
1900
https://www.dremel.com/en_US/products/‐/show‐product/accessories/pc362‐3‐versa‐power‐cleaner‐eraser‐pad 10‐11‐18
很抱歉,暂时无法提供与“PC362-3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+112.673921+14.64725
