Dremel MM488BU
Universal Dual
Interface Carbide
Bi‐Metal Wood
Blade Variety Set (3‐
Pieces)
Model # MM488BU
Product Specifications
Three blade variety pack. Dremel universal oscillating accessories are the first truly
universal oscillating accessories available that require no adapter. The unique dual
interface fits all competitive oscillating tools, including those with a quick change feature.
MM482U universal wood and metal blade may be used on non-ferrous metals, wood,
plastic, drywall and other soft materials. MM480U universal wood blade may be used on
wood, plastic, drywall and other soft materials. The Dremel MM485U universal carbide
flush cut blade has high-performance carbide teeth designed to cut hard and abrasive
materials like: nails, screws, stainless steel bolts, galvanized pipe, plaster and lathe, cement
board, fibre board, sheet metal, slate, ceramic tile and more.
Universal dual interface directly fits all oscillating tools without the use of an adapter,
*excluding StarLock
Compatible with Dremel, Bosch, Makita, Milwaukee, Rockwell, DeWalt, Fein, Porter
Cable, Ridgid
Three-piece variety pack for cutting all types of materials - wood, metal, plastic, nails,
screws, stainless steel bolts, galvanized pipe, plaster and lathe, cement board, fiber
board, sheet metal, slate, and ceramic tile
MM482U: Dremel bi-metal blades in wood with nails provide up to 15X life vs. standard
bi-metal oscillating blades in wood with nails. MM485U: High performance carbide
teeth provide up to 30X life in hardened material vs. standard bi-metal oscillating
blades.
Ideal for making precise cuts in a variety of materials
Three high-performance blades: high carbon steel blade for wood cutting applications,
bi-metal blade for wood/metal cutting applications, and carbide-toothed blade fo
DIMENSIONS
Depth of Cut:
1‐5/8"
Warranty:
Product Defects Only
Description:
Cutting Variety Pack
Blade Length:
3.5
Color Code:
Red
Quantity:
3
Application:
cutting
Tool Level:
11 ‐ Accessories ‐ MPT and UQF
Blade Width:
1.25
https://staging.dremel.com/en_US/products/‐/show‐product/accessories/dremel‐mm488bu‐universal‐
dual‐interface‐carbide‐bi‐metal‐wood‐blade‐variety‐set‐3‐pieces/1‐25‐22
很抱歉,暂时无法提供与“MM488BU”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+336.576821+43.67057
