PC363-3
PC363-3
    DREMEL
    PC363-3 POWER CLEANER NON-SCRATC
PC363-3 数据手册
      PC363-3 Versa Power Cleaner Non-Scratch Pad Model # PC363-3 Product Specifications The Dremel Versa Non-Scratch Pad tackles tough jobs, without scratching, so you don't have to. Perfect for all of your general purpose cleaning needs, it can be used for indoor or outdoor application. The non-scratch surface is ideal for pots and pans, the exterior of your grill, or your stove top.     General purpose fiber scouring pad for tough jobs without scratching Recommended uses: pots, pans, grill exterior, sink, stove, and more Quick and easy accessory change with the hook and loop system Oversized accessories get into corners and tight spaces DIMENSIONS Diameter: Weight: Application: Material: RPM: Contents: 2.5" 0.11[kg, lb, oz] Indoor cleaning (sink, pots and pans, stove,...); Outdoor cleaning (grill exterior, …) Non-Scratch Microfiber Sponge 1900 Non-Scratch Microfiber Sponge       https://www.dremel.com/en_US/products/‐/show‐product/tools/pc363‐3‐versa‐power‐cleaner‐non‐scratch‐pad 10‐11‐18
PC363-3 价格&库存
很抱歉,暂时无法提供与“PC363-3”相匹配的价格&库存,您可以联系我们找货
