TR562
TR562
    DREMEL
    Ceramic
    WALL TILE CUTTING BIT
TR562 数据手册
                                        TR562 Trio Wall Tile Cutting Bit Model # TR562 Product Specifications Ideal for shaping ceramic wall tile around bathroom or kitchen fixtures or plumbing pipes. You can also create decorative wall tile by cutting a design, such as a sailboat, and filling it with colored grout. For use on ceramic wall tile, plaster, cement board, and backer board.  Cuts ceramic wall tile, cement board and plaster. (Not for use on floor tile.)  A high‐speed cutter with a 3/16" steel shank  8 flutes to grind through tough material  Scroll cut in any direction  Plunge and cut wall tile, plaster and backer board       DIMENSIONS Tip size US: 1/8" Shank Size US: 3/16" Overall Length: 2 Shank Size mm: 4.8mm Shank Diameter: 0.1875 Warranty: Product Defects Only Material: High Speed Steel Contents: 1 Bit Color Code: Red Tip Size mm: 4.8 mm                                 https://www.dremel.com/en_US/products/‐/show‐product/accessories/tr562‐trio‐wall‐tile‐cutting‐bit 10‐12‐18
TR562 价格&库存
很抱歉,暂时无法提供与“TR562”相匹配的价格&库存,您可以联系我们找货
