US520 Masonry Cutting Wheel
Model # US520‐01
Product Specifications
The US520 masonry cutting wheel can cut a wide range of masonry materials including
stone, slate, cement board, bricks, concrete, cement backer board and more. The US520
wheel features a 50% longer life than the SM520 Saw‐Max masonry cutting wheel, allowing
you to cut more material. 3.5 In. diameter wheel.
Abrasive material for high performance masonry cutting applications
Cuts a wide range of masonry materials including stone, slate, cement board, bricks, concrete,
No need to apply excessive pressure – the tool does the work
30 grit, silicon carbide grain
DIMENSIONS
Blade Thickness (in):
0.094
Diameter:
3.5"
Kerf:
0.094["]
Description:
Blade Thickness:
0.094["]
Model Number:
US520‐01
Warranty:
Product Defects Only
Grit:
RPM:
20000
Contents:
1 Blade
Color Code:
Red
https://www.dremel.com/en_US/products/‐/show‐product/accessories/us520‐01‐us520‐masonry‐cutting‐wheel 10‐12‐18
很抱歉,暂时无法提供与“US520-01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+32.795681+4.24569
