US600-01
US600-01
    DREMEL
    US600-01 WOOD FLUSH CUT WHEEL
US600-01 数据手册
                       US600‐01 Wood Flush Cut Wheel Model # US600‐01 Product Specifications Specially designed wheel for making flush cuts in a variety of wood materials including soft and hard wood, plywood, composites, laminate flooring, drywall, PVC and plastic. Uses include cutting baseboard for flooring installation and use with the Saw‐Max™ miter guide. Four In. diameter, carbide abrasive.      Dome‐shaped wheel for flush cuts up 3/4 In. thick  Carbide cutting grit for high‐performance wood cutting applications  Cuts a variety of wood materials including soft and hard wood, plywood, composites, laminate flooring, drywall, pvc and plastic  Uses include cutting baseboard for flooring installation DIMENSIONS Blade Thickness (in): 0.035 Diameter: 3.9" (98mm) Kerf: 0.075["] Description: US600 Wood Flush Cut Wheel Blade Thickness: 0.035["] Model Number: US600‐01 Warranty: Product Defects Only Plate Thickness: 0.075 RPM: 13000 Contents: 1 Blade Color Code: Red Bit Diameter Inch: 3/4    https://www.dremel.com/en_US/products/‐/show‐product/tools/us600‐01‐wood‐flush‐cut‐wheel 10‐12‐18
US600-01 价格&库存
很抱歉,暂时无法提供与“US600-01”相匹配的价格&库存,您可以联系我们找货
US600-01
    • 1+206.433281+26.66957
