VC494
VC494
    DREMEL
    VELOCITY VC494 PIPE & 2X4 BLADE
VC494 数据手册
VC494 Velocity Pipe & 2x4 Blade Model # VC494 Product Specifications The Dremel VC494 pipe and 2X4 blade is made for cutting pipe and thick materials such as 2X4 studs. With an extra wide cutting edge, the VC494 adds control and convenience because users can now easily cut PVC, conduit, and copper pipe without the blade slipping off of the work-piece. Cuts through a 2X4 can now be done in one pass as well. The blade's Bi-Metal construction optimizes the VC494 for metal cutting, so you'll experience no more destroyed teeth if you hit a nail while cutting. • Bi-Metal blade material for high performance wood/metal cutting applications • Extra-wide cutting edge adds control and convenience • Ideal for cutting pipe and 2 x 4 lumber • Universal Quick Fit interface - directly fits all Dremel®, Rockwell®, Ridgid®, Fein®, Makita®, Craftsman®, RYOBI® and Milwaukee® oscillating tools DIMENSIONS Blade Thickness (in): 0.024 Description: VC494 Velocity Pipe & 2x4 Blade Blade Thickness: 0.024[" ]Model Number: VC494 Blade Length: 3.44 Application: The VC494 Pipe and 2x4 blade is great for making cuts in wood and metal materials, specifically cutting a 2x4 in one pass and cutting pipe materials, such as conduit, PVC, and copper tubing. Cutting Edge: 2.8 - inch Blade Length: 3.44 – inch Warranty: Product Defects Only Blade Width: 2.88 Color Code: Red Depth of Cut: 1-11/16" https://www.dremel.com/en_US/products/-/show-product/tools/vc494-velocity-pipe-2x4-blade 10-10-18
VC494 价格&库存
很抱歉,暂时无法提供与“VC494”相匹配的价格&库存,您可以联系我们找货
