SCD722002
SCD722002
    EINKCORPORATION
    字符显示模块 6 段 E-INK 段码式显示器 无背光 26.30mm x 8.50mm x 0.58mm
SCD722002 数据手册
E Ink Segmented TM Monochrome Electronic Paper Displays Sunlight Readable Wide Viewing Angle Low Power Consumption E Ink Segmented displays are ultra-low power, thin, and rugged. E Ink’s unique reflective display technology is sunlight readable and can display an image with no power. This enables engineers and designers to add displays to products where power and space limitations have made it impossible to do so before. Divided into discrete segments, these products can be controlled individually to convey information using letters, numbers and icons. Creative layouts enable overlapping images and unique fonts. The result is a black and white display with the readability of paper that is less than 650 microns thick. Specifications Parameter Model # Segments 5 Bar Capacity Gauge SDC722002 6 Overall Dimmensions 8.50 x 26.30 mm Active Area Dimmensions 3.00 x 10.30 mm Thickness Backplane Substrate Connection Pins 580 um PET 7 Tail Pitch 0.5 mm Tail Connector 0.3 mm Connection Type Tyco 5-1734592-6 Drive Voltage 15v or 5v Power Draw Image Static 0 Power Draw Image Static 0.5 micro-amps per cm2 Storage -25c to 70c Operating Range -10c to 60c Applications Markets Watches Medical Smartcards & Smart Locks Industrial Glucose Meters Consumer Usb Drives Finance Battery Indicators Mobile Fitness Devices Retail REV. E Ink reserves the right to make changes in design or specification at any time and without notice. For additional information, please contact sales@eink.com www.eink.com/prism E Ink Holdings
SCD722002
物料型号:SDC722002
器件简介:E Ink Segmented displays 是超低功耗、轻薄且坚固的电子纸显示屏。它们具有阳光下可读性,并且可以在不消耗电力的情况下显示图像。这种显示屏由离散的段组成,可以单独控制以显示字母、数字和图标,创造出具有纸张可读性的黑白显示屏,厚度小于650微米。
引脚分配:共有7个连接引脚。
参数特性: - 总尺寸:8.50x26.30 mm - 有效显示区域尺寸:3.00x10.30mm - 厚度:580um - 基板材料:PET - 尾间距:0.5mm - 尾连接器:0.3mm - 连接类型:Tyco5-1734592-6 - 驱动电压:15V或5V - 图像静态功耗:0 - 每平方厘米图像静态功耗:0.5微安培 - 存储温度:-25°C至70°C - 工作温度范围:-10°C至60°C
功能详解:E Ink的电子纸显示屏使用独特的反射显示技术,能够在不消耗电力的情况下显示图像,适合在电力和空间受限的产品中使用。
应用信息:这些显示屏适用于手表、智能卡和智能锁、血糖仪、U盘、电池指示器、健身设备、医疗、工业、消费电子、金融、移动和零售市场。
封装信息:文档中未提供详细的封装信息,但提到了显示屏的厚度和基板材料。
SCD722002 价格&库存
很抱歉,暂时无法提供与“SCD722002”相匹配的价格&库存,您可以联系我们找货
SCD722002
  • 1+41.017041+5.33209
  • 10+30.2006510+3.92599
  • 100+23.77870100+3.09116
  • 500+20.96153500+2.72494
  • 1000+20.044861000+2.60577
  • 2000+19.269302000+2.50495
  • 5000+18.424585000+2.39514
库存:6424
