ED078KC2
ED078KC2
    EINKCORPORATION
    智能,智慧,发光二极管,图形 反射 灰色 TFT - 彩色 7.8"(198.12mm) 1404 x 1872
ED078KC2 数据手册
VB3300-GHC (ED078KC2) Version: 3.0 Technical Specification VB3300-GHC ( ED078KC2 ) MODEL NO: The content of this information is subject to be changed without notice. Please contact E Ink or its agent for further information. Customer’s Confirmation Customer Date By E Ink’s Confirmation Approved By Confirmed By Prepared By The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. I VB3300-GHC (ED078KC2) Revision History Rev. Issued Date Revised Contents 1.0 Apr 19, 2018 New 2.0 Mar 6, 2020 Update new model name 3.0 Dec 13, 2021 1. Modify the description 2. Modify 6.2 Display Module DC Characteristics - VGL The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. II VB3300-GHC (ED078KC2) TECHNICAL SPECIFICATION CONTENTS 1. General Description .........................................................................................................................................1 2. Features ...........................................................................................................................................................1 3. Mechanical Specifications ...............................................................................................................................1 4. Mechanical Drawing of EPD Module ...............................................................................................................2 5. Input / Output Interface ..................................................................................................................................3 6. Display Module Electrical Characteristics........................................................................................................5 7. Power Sequence ............................................................................................................................................11 8. Optical Characteristics ...................................................................................................................................13 9. Handling, Safety and Environmental Requirements and Remark .................................................................15 10. Border Definition ...........................................................................................................................................18 11. Block Diagram ................................................................................................................................................19 12. Packing...........................................................................................................................................................20 The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. III VB3300-GHC (ED078KC2) 1. General Description ED078KC2 is a reflective electrophoretic E Ink® technology display module based on active matrix TFT substrate. It has 7.8” active area with 1404 x 1872 pixels, the display is capable to display images at 2-16 grey levels (1-4 bits) depending on the display controller and the associated waveform file it used. 2. Features  Carta high contrast reflective/electrophoretic technology  1404 x 1872 resolution  Ultra wide viewing angle  Ultra low power consumption  Pure reflective mode  Bi-stable  Commercial temperature range  Landscape, portrait mode 3. Mechanical Specifications Parameter Specifications Unit Screen Size 7.8 (3:4) Inch Display Resolution 1404 (H)×1872 (V) Pixel Active Area 118.638 (H)×158.184 (V) mm Pixel Pitch 0.0845 (H)×0.0845 (V) mm Pixel Configuration Square Outline Dimension 127.6(H) * 173.8(V) * 0.78(D) (EPD w/o FPC) mm Module Weight 36.9 ± 5 g Number of Grey 16 Grey Level (monochrome) Display operating mode Reflective mode Remark The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 1 VB3300-GHC (ED078KC2) Mechanical Drawing of EPD Module 增加 4. The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 2 VB3300-GHC (ED078KC2) 5. Input / Output Interface 5.1 Connector type P-TWO INDUSTRIES INC 196033-40041-1 5.1.1 Pin assignment Pin # 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 Signal VGL NC VGH NC VDD Mode CKV SPV VSS VCOM VDD VSS XCL D0 D1 D2 D3 D4 D5 D6 D7 VSS D8 D9 D10 D11 D12 D13 D14 D15 XSTL XLE XOE TEST NC VPOS NC VNEG NC Border Description Negative power supply gate driver NO Connection Positive power supply gate driver NO Connection Digital power supply drivers Output mode selection gate driver Clock gate driver Start pulse gate driver Ground Common voltage Digital power supply drivers Ground Clock source driver Data signal source driver Data signal source driver Data signal source driver Data signal source driver Data signal source driver Data signal source driver Data signal source driver Data signal source driver Ground Data signal source driver Data signal source driver Data signal source driver Data signal source driver Data signal source driver Data signal source driver Data signal source driver Data signal source driver Start pulse source driver Latch enable source driver Output enable source driver E Ink internal test pin (Note 1) NO Connection Positive power supply source driver NO Connection Negative power supply source driver NO Connection Border connection Note 1: Please connect to VDD voltage. The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 3 VB3300-GHC (ED078KC2) 5.2 Panel Scan Direction Gate Scan Direction G1404 G1 S1 Source AA CENTER Scan Direction S1872 40 1 The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 4 VB3300-GHC (ED078KC2) 6. Display Module Electrical Characteristics 6.1 Absolute Maximum Ratings Parameter Symbol Rating Unit Remark Logic Supply Voltage VDD -0.3 to +5 V -- Positive Supply Voltage VPOS -0.3 to +18 V -- Negative Supply Voltage VNEG +0.3 to -18 V -- Max .Drive Voltage Range VPOS - VNEG 36 V -- Supply Voltage VGH -0.3 to VGL+50 V -- Supply Voltage VGL -25 to +0.3 V -- Supply Range VGH-VGL +10 to +50 V -- Operating Temp. Range TOTR 0 to +50 ℃ -- Storage Temperature TSTG -25 to +70 ℃ -- 6.2 Display Module DC Characteristics Parameter Symbol Signal ground Min Typ Max Unit VSS - 0 - V VDD 3.0 3.3 3.6 V - 12 15 mA -24 -23 -22 V - 2 20 mA 24 25 26 V - 1 5 mA -15.4 -15 -14.6 V - 2 200 mA 14.6 15 15.4 V - 2 200 mA - Adjusted - V -800 0 800 mV VCOM -4 Adjusted -0.3 V ICOM - 0.2 - mA Panel Power P - 164.6 6574.5 mW Standby power panel PSTBY - - 0.17 mW Logic Voltage supply Gate Negative supply Gate Positive supply Source Negative supply Source Positive supply IVDD IGL VGL =-23V VGH IGH VGH = 25V VNEG INEG VNEG = -15V VPOS IPOS VCOM Asymmetry source VAsym - VDD=3.3V VGL Border supply Common voltage Conditions VPOS = 15V VPOS+VNEG The maximum power consumption is measured using 85Hz waveform with following pattern transition: from pattern of repeated 1 consecutive black scan lines followed by 1 consecutive white scan line to that of repeated 1 consecutive white scan lines followed by 1 consecutive black scan lines (Note 6-1). - The Typical power consumption is measured using 85Hz waveform with following pattern transition: from horizontal 4 grey scale pattern to vertical 4 grey scale patterns (Note 6-2). The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 5 VB3300-GHC (ED078KC2) - The standby power is the consumed power when the panel controller is in standby mode. - The listed electrical/optical characteristics are only guaranteed under the controller & waveform provided by E Ink. - Vcom is recommended to be set in the range of assigned value ± 0.1V - The maximum ICOM inrush current is about 1500 mA Note 6-1 The maximum power consumption Note 6-2 The typical power consumption The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 6 VB3300-GHC (ED078KC2) 6.3 Display Module AC characteristics Symbol Min. Typ. Max. Unit Clock frequency fckv - - 200 kHz Minimum “L” clock pulse width twL 500 - - ns Minimum “H” clock pulse width twH 500 - - ns Clock rise time trckv - - 100 ns Clock fall time tfckv - - 100 ns SPV setup time tSU 100 - - ns SPV hold time tH 100 - - ns Pulse rise time Pulse fall time trspv tfspv - - 100 100 ns ns Clock XCL cycle time D0 .. D15 setup time D0 .. D15 hold time XSTL setup time XSTL hold time XLE on delay time XLE high-level pulse width (When VDD=3.0V to 3.6V) XLE off delay time Output setting time to +/30mV(Cload=200pF) tcy tsu th tstls tstlh tLEdly 16.67 8 8 0.5*tcy 0.5*tcy 10.5*tcy 300 50 - 0.8*tcy 240*tcy-tstls - ns ns ns ns ns ns 200 - - 20 ns us Parameter tLEw tLEoff tout ns OUTPUT LATCH CONTROL SIGNALS The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 7 VB3300-GHC (ED078KC2) CLOCK & DATA TIMING D0~D15 CKV & SPV TIMING GATE OUTPUT TIMING The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosedOUT1~OUT1872 in whole or in part without prior written permission of E Ink Holdings Inc. 8 VB3300-GHC (ED078KC2) Note:First gate line on timing 6.4 Refresh Rate The module is applied at a maximum refresh rate of 85 Hz. Refresh Rate Min Max - 85 Hz 6.5 Controller Timing The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 9 VB3300-GHC (ED078KC2) 6.6 Timing Parameters Table Mode 3 SDCK [MHz] 33.33 Pixels Per SDCK 8 Line Parameters[SDCK] LSL LBL LDL LEL GDCK_STA LGONL 18 17 234 7 34 192 Line Parameters[us] - - - - - - 0.54 0.51 7.02 0.21 1.02 5.76 Frame Parameters [lines] FSL FBL FDL FEL - FR [Hz] 1 4 1404 12 - 84.99 Frame Parameters [us] - - - - - - 8.28 33.12 11625.12 99.36 - - Resolution 1872x1404 Note 1: For parameters definition, see Appendix- EPD Panel Timing Note 2: For Isis Controller GDCK_STA and LGONL are not settable parameter; GDCK_STA = LBL, LGONL=LDL+0.5 Note 3: For Freescale SoC GDOE Low pulse represent FSL and GDSP pulses with the first period of FBL The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 10 VB3300-GHC (ED078KC2) 7. Power Sequence Power Rails must be sequenced in the following order: 1. VSS  VDD  VNEG  VPOS (Source driver)  VCOM 2. VSS  VDD  VGL  VGH (Gate driver) POWER ON Ten Tng Tgv VGH VPOS VDD VSS Data VCOM VNEG VGL Tsd Tde Tep Tpv Tvd Min Max Tsd 30us - Tde 100us - Tep 1000us - Tpv 100us - Tvd 100us - Ten 0us - Tng 1000us - Tgv 100us - The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 11 VB3300-GHC (ED078KC2) POWER OFF Min Max Remark Tdv 100μs - - Tvg 0μs - - Tgp 0μs - - Tpn 0μs - - Tne 0μs - - Ted 0.5s - Discharged point @ -7.4 Volt Note 1:Supply voltages decay through pull-down resistors. Note 2:Begin to turn off VGL power after VNEG and VPOS are completely or almost discharged to GND state. Note 3:VGL must remain negative of Vcom during decay period The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 12 VB3300-GHC (ED078KC2) Optical Characteristics 8. 8.1 Specifications Measurements are made with that the illumination is at an angle of 45 degrees from the perpendicular at the center of sample surface, the detector is perpendicular unless otherwise specified. T = 25oC Symbol Parameter Conditions Min Typ. Max Unit Note R Reflectance White 35 45 - % Note 8-1 Gn Nth Grey Level - - DS+(WS-DS)×n/(m-1) - L* - CR Contrast Ratio - 10 16 - - - WS: White state , DS: Dark state, Grey state from Dark to White :DS、G1、G2…、Gn…、Gm-2、WS m:4、8、16 when 2、3、4 bits mode Note 8-1: Luminance meter: Eye – One Pro Spectrophotometer 8.2 Definition of Contrast Ratio The contrast ratio (CR) is the ratio between the reflectance in a full white area (Rl) and the reflectance in a dark area (Rd): CR = Rl/Rd Eye–One Spectrophotometer Detector Light Sources in a ring 45° 45° EPD Sample The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 13 VB3300-GHC (ED078KC2) 8.3 Reflection Ratio The reflection ratio is expressed as: R = Reflectance Factorwhite board x ( Lcenter / Lwhite board ) Lcenter is the luminance measured at center in a white area (R=G=B=1). Lwhite board is the luminance of a standard white board. Both are measured with equivalent illumination source. The viewing angle shall be no more than 2 degrees. The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 14 VB3300-GHC (ED078KC2) 9. Handling, Safety and Environmental Requirements and Remark WARNING The display glass may break when it is dropped or bumped on a hard surface. Handle with care. Should the display break, do not touch the electrophoretic material. In case of contact with electrophoretic material, wash with water and soap. CAUTION The display module should not be exposed to harmful gases, such as acid and alkali gases, which corrode electronic components. Disassembling the display module can cause permanent damage and invalidate the warranty agreements. IPA solvent can only be applied on active area and the back of a glass. For the rest part, it is not allowed. Mounting Precautions (1) It`s recommended that you consider the mounting structure so that uneven force (ex. Twisted stress) is not applied to the module. (2) It`s recommended that you attach a transparent protective plate to the surface in order to protect the EPD. Transparent protective plate should have sufficient strength in order to resist external force. (3) You should adopt radiation structure to satisfy the temperature specification. (4) Acetic acid type and chlorine type materials for the cover case are not desirable because the former generates corrosive gas of attacking the PS at high temperature and the latter causes circuit break by electro-chemical reaction. (5) Do not touch, push or rub the exposed PS with glass, tweezers or anything harder than HB pencil lead. And please do not rub with dust clothes with chemical treatment. Do not touch the surface of PS for bare hand or greasy cloth. (Some cosmetics deteriorate the PS) (6) When the surface becomes dusty, please wipe gently with absorbent cotton or other soft materials like chamois soaks with petroleum benzene. Normal-hexane is recommended for cleaning the adhesives used to attach the PS. Do not use acetone, toluene and alcohol because they cause chemical damage to the PS. (7) Wipe off saliva or water drops as soon as possible. Their long time contact with PS causes deformations and color fading. Data sheet status Product specification This data sheet contains final product specifications. Limiting values Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Application information Where application information is given, it is advisory and does not form part of the specification. Remark All the specifications listed in this document are guaranteed for module only. Post-assembled operation or component(s) may impact module performance or cause unexpected effect or damage and therefore listed specifications is not warranted after any post-assembly operation. The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 15 VB3300-GHC (ED078KC2) The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 16 VB3300-GHC (ED078KC2) Reliability test TEST 1 High-Temperature Operation 2 Low-Temperature Operation 3 High-Temperature Storage 4 Low-Temperature Storage 5 High-Temperature, High-Humidity Operation 6 CONDITION T = +50°C, RH = 30% for 240 hrs T = 0°C for 240 hrs T = +70°C, RH = 40% for 240 hrs Test in white pattern T = -25°C for 240 hrs Test in white pattern T = +40°C, RH = 90% for 168 hrs High-Temperature, T = +60°C, RH = 80% for 240 hrs High-Humidity Storage Test in white pattern METHOD REMARK IEC 60 068-2-2Be -- IEC 60 068-2-1Ae -- IEC 60 068-2-2Bb IEC 60 068-2-1Ab -- IEC 60 068-2-78 -- IEC 60 068-2-3CA -25℃+70℃, 100 Cycles 7 Temperature Cycle 30min 30min IEC 68-2-14-Nb -- IEC60 068-2-5Sa -- Test in white pattern 2 8 Solar radiation test 765 W/m for 168hrs,40℃ Test in white pattern 1.04G, Frequency: 10~500Hz 9 Package Vibration Direction: X,Y,Z Duration: 1 hours in each direction Full packed for shipment -- Drop from height of 122 cm 10 Package Drop Impact on concrete surface. Full packed for Drop sequence: 1 corner,3 edges,6 faces shipment -- One drop for each. 11 Electrostatic Effect (Machine model)+/- 250V (non-operating) 0Ω, 200pF IEC 62179, IEC 62180 -- -- -- Rubber Pen : Top D=0.8mm 12 Stylus Tapping Load: 300gf Speed: 30 times/min Total 13500times Actual EMC level to be measured on customer application Note: The protective film must be removed before temperature test. < Criteria > In the standard conditions, there is not display function NG issue occurred. (including : line defect ,no image). All the cosmetic specification is judged before the reliability stress. The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 17 VB3300-GHC (ED078KC2) 10. Border Definition Active Area Border 40 1 The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 18 VB3300-GHC (ED078KC2) 11. Block Diagram The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 19 VB3300-GHC (ED078KC2) 12. Packing The information contained herein is the exclusive property of E Ink Holdings Inc., and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of E Ink Holdings Inc. 20
ED078KC2 价格&库存
很抱歉,暂时无法提供与“ED078KC2”相匹配的价格&库存,您可以联系我们找货
