1410-F110-P1F1-W19QE2-3.15A
    E-T-A
    CIR BRKR THRM 3.1A 250VAC 48VDC
1410-F110-P1F1-W19QE2-3.15A 数据手册
Thermal Overcurrent Circuit Breaker 1410-F1... Description Miniaturised single pole rocker switch/thermal circuit breaker combining ON/OFF switching and extremely fast overload performance in a single component (S-type TO CBE to EN 60934/IEC 60934). Under overload conditions an internal neon (filament bulb for low voltages) illuminates to give a clear signal of the tripped status of the mechanism and thereby the cause of power interruption, suffix -B. Alternatively the illumination can be conventionally wired to indicate the ON status of the device, suffix -E. Returning the rocker switch through the OFF position and back ON will reset the mechanism and restore the supply. Largely temperature-insensitive. 1 Typical applications Motors, transformers, solenoids, PCBs, hand-held machines, appliances, instrumentation. Ordering information 1410-F1.. Technical data Type No. 1410 single pole rocker switch/circuit breaker Mounting F snap-in panel mounting Size of frame 1 to fit mounting cut-out 28 x 12.7 mm (1.1 x .5 in) Number of poles 1 single pole, thermally protected Accessories 0 without accessories Terminal design P1 blade terminals 2.8-0.8 (QC .110/2x.110)silver-plated Characteristic curve F1 fast acting Actuator style W rocker, rounded profile Actuator colour 14 red translucent 19 green translucent Actuator markings Q I and 0 Trip/ON illumination (optional) B illuminated when tripped E illuminated when ON .. without illumination Illumination voltage range (optional) 2 20- 28V marked 24V 35mA 3 90-140V marked 115V 6.3 A DC 300 break operations at 2 x IN protection circuit 1-2 Ambient temperature Insulation co-ordination (IEC 60664 and 60664A) Dielectric strength (IEC 60664 and 60664A) operating area Insulation resistance Interrupting capacity Icn Interrupting capacity (UL 1077) Current rating (A) 0.63 Internal resistance (Ω) 1.8 Current rating (A) Internal resistance (Ω) 3.15 < 0.12 0.8 1.7 4 < 0.1 1 1.3 5 < 0.1 1.5
1410-F110-P1F1-W19QE2-3.15A 价格&库存
很抱歉,暂时无法提供与“1410-F110-P1F1-W19QE2-3.15A”相匹配的价格&库存,您可以联系我们找货
