1410-G112-P3F1-B04-2.5A
    E-T-A
    CIR BRKR THRM 2.5A 250VAC 50VDC
1410-G112-P3F1-B04-2.5A 数据手册
Thermal Overcurrent Circuit Breaker 1410-L2/G1 Description Single pole press-to-reset thermal circuit breaker with extremely fast overload switching performance (R-type TO CBE to EN 60934). Single hole threadneck, PCB or integral mounting with a choice of designs. Miniaturised construction minimises PCB real estate required. Type 1410-L2 and 1410-G1 versions feature changeover contacts suitable for providing status output signals. Largely temperature-insensitive. 1 Typical applications Motors, transformers, solenoids, PCBs, hand-held machines, appliances, instrumentation. 1410-L2... 1410-G1... Ordering information Type No. 1410 single pole circuit breaker Configuration L PCB mounting or integral mounting G threadneck panel mounting or PCB mounting Mounting 1 threadneck 3/8-27UNS-2A (1410-G) 2 PCB 10.15x7.62 (1410-L) 3 PCB 10.15without shunt terminal (1410-L) Number of poles 1 1-pole, thermally protected Hardware 0 without 1 with hexnut and knurled nut (only1410-G) > 5 pcs hexnut and knurled nut bulk shipped 2 without hexnut and knurled nut and without shunt terminal (only 1410-G) 4 with hexnut and knurled nut, without shunt terminal (only 1410-G) 8 with actuator guard and marking CB.. (only 1410-G) Terminal design L2 solder pins 1x0.8 silver-plated P2 blade terminals DIN 46244-A2.8-0.8 silver-plated (only -G) P3 blade terminals DIN 46244-A4.8-0.5 silver-plated (only -G) Characteristic curve F1 fast acting Actuator B flat reset-slide (only 1410-G) S reset slide/button Actuator colour 01 black (for -G1..) 02 white (for -L2..) 04 red (for 1410-G..-...B) Current ratings 0.63...10 A 1410 - L 2 1 0 - L2 F1 - S 02 - 0.8 A ordering example *mounting hardware bulk shipped Standard current ratings and typical internal resistance values Current rating (A) 0.63 0.8 1 1.5 1.8 2 2.5 Issue C Internal resistance (Ω) 1.8 1.7 1.3
1410-G112-P3F1-B04-2.5A 价格&库存
很抱歉,暂时无法提供与“1410-G112-P3F1-B04-2.5A”相匹配的价格&库存,您可以联系我们找货
