Thermal Overcurrent Circuit Breaker 1658-...
Description
Very cost effective design to meet international requirements. No
exposed metal parts which are, or could become, current-carrying
except for terminals. R-type TO CBE to EN 60934.
● Manual reset, cycling trip free mechanism
● Extremely small and lightweight
● UL, CSA, VDE and EN 60934 (IEC 60934) approved
1
Typical applications
Battery chargers, consumer products, power supplies, motors.
1658-...
Ordering information
Type No.
1658 single pole thermal circuit breaker
Threadneck design
G21 manual reset type, 3/8“-27 threadneck
G41 manual reset type, 7/16“-28 threadneck
A21 auto reset type, 3/8“-27 threadneck
A41 auto reset type, 7/16“-28 threadneck
A00 auto reset type, without threadneck
F01 snap in
Hardware
00 no hardware
01 one PAL nut, bulk
02 one PAL nut, one knurled nut, bulk
03 one PAL nut mounted
04 one PAL nut, one knurled nut, mounted
05 one PAL nut mounted, one knurled nut, bulk
06 one knurled nut, bulk
07 one hex nut, bulk
08 two hex nuts, bulk
Terminals
P10 blade terminals A6.3-0.8 (QC .250)
P13 blade terminals A6.3-0.8 (QC .250), 90°
S80 straight screw terminals*
S83 90° bent screw terminals*
Current ratings
5 ...30 A
1658 - G21 - 02 - P10 - 5 A
Technical data
For further details please
Voltage rating
Current ratings
Typical life
AC + DC
5...16 A
17...25 A
Ambient temperature
Insulation co-ordination
(IEC 60664 and 60664 A)
Ordering example
Standard current ratings and typical voltage drop values
Voltage
drop (mV)
≤ 250
≤ 250
≤ 250
≤ 250
≤ 250
≤ 250
Current
rating (A)
12
15
16
30
1,000 operations at 2 x IN, inductive
1,000 operations at 2 x IN, resistive
-20...+60 °C (-4...+140 °F),
≤ 7 A max. +40 °C (+104 °F)
rated impulse
pollution
withstand voltage
degree
2.5 kV
2
reinforced insulation in operating area
Dielectric strength
(IEC 60664 and 60664A)
operating area
Insulation resistance
Interrupting capacity Icn
* Screws and lock washers bulk shipped
Current
rating (A)
5
6
7
8
9
10
see chapter: Technical Information
AC 240 V; DC 28 V
5...30 A
Voltage
drop (mV)
≤ 250
≤ 250
≤ 250
≤ 250
≤ 250
≤ 250
test voltage
AC 3,000 V
> 100 MΩ (DC 500 V)
5...7 A
180 A
8...30 A
200 A
UN
IN
(UL 1077/EN 60934 PC1) 5...16 A
AC 240 V 2,000 A
17...30 A AC 120 V 2,000 A
5...30 A
DC 32 V 2,500 A
5...30 A
DC 28 V 2,000 A (1658-A..)
Degree of protection
operating area IP40
(IEC 60529/DIN 40050)
terminal area IP00
Vibration
8 g (57-500 Hz) ± 0.61 mm (10-57 Hz),
to IEC 60068-2-6, test Fc,
10 frequency cycles/axis
Shock
30 g (11 ms)
to IEC 60068-2-27, test Ea
Corrosion
96 hours at 5 % salt mist,
to IEC 60068-2-11, test Ka
Humidity
240 hours at 95 % RH
to IEC 60068-2-78, test Cab
Mass
approx. 16 g
Approvals
Authority
VDE (EN 60934)
UL
Issue B(020810)
Voltage rating
AC 240 V; DC 28 V
AC 240 V
AC 120 V
AC 120 V
DC 32 V
DC 28 V
Current ratings
5...25 A
5...16 A
1658-G../F..
18...30 A 1658-G../F..
5...30 A
1658-A...
5...30 A
1658-G../F..
5...30 A
1658-A..
www.e-t-a.com
1 - 63
Terminal design
ø6
.236
1
1
2
8.5
.335
terminal screw
6-32 UNC
blade terminals DIN 46244-A6.3-0.8
(QC .250)
2
12
.472
1
2
12
.472
27
1.06
6
.236
1
.039
1
S83
3
.118
P10
0.7
.028
12.7
.500
ON
OFF
Dimensions
P13
lock washer
P10-S83
3
.118
17.5
.689
15.7
.618
2
1
8.5
.335
blade terminals DIN 46244-A6.3-0.8 (QC .250)
angled 90°
13.6
.535
14
.551
1
32
1.26
2
lock washer
terminal screw
6-32 UNC
blade terminals
S80
A00
A21
tightening torque max. 0.8 Nm
3/8-27UNS-2A
mounting hole
terminal screw
6-32 UNC
8.9-0.1
.350-.004
9.6-0.1
.378-.004
G21
2
12
.472
1
3/8-27UNS-2A
lock washer
Installation drawing
7
.276
4
.157
operating area
1
34
1.34
mounting hole
10.2±0.1
.402±.004
10
.394
A41
2
5
.197
5
.197
4
4
.157
.157
7/16-28UNS-2A
double “D“
G41
11.2±0.1
.441±.004
mounting area
10
.394
ø6
.236
Caution:
Please keep a tight grip on the unit
while removing the female connectors.
mounting hole
+0.1
- 0.2
+.004
.543 - .008
13.8
16±0.15
.630±.006
12.7
.500
ON
6
.236
1
.039
OFF
F01
thickness 1- 3 mm
.039 - .118 in.
See ordering information for mounting hardware.
This is a metric design and millimeter dimensions take precedence ( mm )
inch
1 - 64
www.e-t-a.com
Issue B(020810)
Internal connection diagram
Accessories
1
Mounting nut 3/8", 27-thread
Y 306 671 01
14.3
.563
2.5
.098
0.5
.020
Mounting nut 7/16", 28-thread
Y 303 200 01
16
.630
0.5
.020
3
.118
1
2
3/8-27UNS-2B
Typical time/current characteristics
10000
+60 °C
+140 °F
+23 °C
+73.4 °F
-20 °C
-4 °F
Trip time in seconds
1000
7/16-28UNEF-2B
Knurled nut 3/8", 27-thread
plastic (standard)
Y 307 117 02
Knurled nut 7/16", 28-thread
nickel-plated brass
Y 302 294 03
ø15
.591
3
.118
ø16
.630
3.2
.126
100
7/16-28UNEF-2B
3/8-27UNS-2B
nickel-plated brass
Y 300 190 03
10
ø13
.512
1
2.5
.098
0.1
2
4
6 8 10
… times rated current
3/8-27UNS-2B
The time/current characteristic curve depends on the ambient temperature
prevailing. In order to eliminate nuisance tripping, please multiply the circuit
breaker current ratings by the derating factor shown below. See also section
Technical information.
Ambient temperature °F
°C
Derating factor
IN > 7A
IN ≤ 7A
-4
-20
0.83
0.74
+14
-10
0.85
0.76
+32
0.82
+73.4
+23
1
1
Hex nut 3/8", 27-thread
nickel-plated brass
Y 300 192 01
+104 +122 +140
+40 +50 +60
1.1
1.18 1.25
1.23
3/8-27UNS-2B
Hex nut 7/16", 28-thread
nickel-plated brass
Y 302 295 01
2.5
.098
7/16-28UNEF-2B
SW14
.551
SW14
.551
Press to Reset Plate for 3/8"
thread, aluminium
Y 301 059 02
ø21.4
.843
E-T
T
T
BREA
R
PR
E
SE
0.4
.016
KE
A
SS
E
TO RE
PR
SS
E- T
ø24
.945
R
KE
BREA
ø9.9
.390
Press to Reset Plate for 7/16"
thread, aluminium
Y 302 732 01
0.4
.016
A
2.5
.098
SE
1
E
TO R
ø11.2+0.7
.441+.028
inch
Issue B(020810)
www.e-t-a.com
1 - 65
Accessories
Reset button seal for 3/8", 27-thread,
short
long
X 201 285 01
X 200 799 01
1
3/8-27 UNS-2B
3/8-27 UNS-2B
Reset button seal for 7/16", 28-thread,
short
long
X 222 119 01
X 222 119 02
7/16-28 UNS-2B
7/16-28 UNS-2B
All dimensions without tolerances are for reference only. In the interest of improved design,
performance and cost effectiveness the right to make changes in these specifications
without notice is reserved.Product markings may not be exactly as the ordering codes.
Errors and omissions excepted.
1 - 66
www.e-t-a.com
Issue B(020810)
