2210-S222-P1T2-H0-4A
    E-T-A
    CIRC BRKR THRM
2210-S222-P1T2-H0-4A 数据手册
Thermal-Magnetic Circuit Breaker 2210-S2.. Description One, two and three pole thermal-magnetic circuit breakers with tripfree mechanism and toggle actuation (S-type TM CBE to EN 60934/IEC 934). Designed for panel or plug-in mounting. Available with auxiliary contacts (1 x N/O, 1 x N/C) for status signalling. Two and three pole models are internally linked to ensure that both/all poles trip in the event of an overload on one pole, even if the actuator is held in the ON position. A choice of characteristic curves further extends the range of applications possibilities for these CBEs. Special auxiliary contact versions for industrial atmosphere and low voltages (e. g. 5 V) available on request. Approved to CBE standard EN 60934 (IEC 60934). Suitable for use in distribution rails – see section Power Distribution Systems. 2210-S2.. Typical applications Process control equipment, robotics, machine tool control, communications systems, instrumentation, rail vehicles. Special versions, e.g. for aggressive environmental conditions and low voltages (e. g. 5 V) on request. Ordering information Type No. 2210 single or multipole thermal-magnetic circuit breaker Mounting S socket or panel mounting Actuator design 2 toggle Number of poles 1 1-pole protected 2 2-pole protected 3 3-pole protected 5 2-pole, protected on one pole only Panel mounting 0 without hardware 1 with M3 thread 2 with 6/32 thread Terminal design (main contacts) P1 blade terminals 6.3-0.8 (QC .250) Characteristic curve F1 fast acting: therm.1.01-1.4xIN;magn.2-4xIN DC (DC only) F2 fast acting: therm.1.01-1.4xIN; magn.3.5-6.5xIN AC/ 4.5-8.5xIN DC M1 standard delay: therm. 1.01-1.4xIN; magn. 6-12xIN AC;7.8-15.6xIN DC T1 delayed: therm. 1.01-1.4xIN; magn. 10-20xIN AC T2 thermal only, 1.01-1.4xIN M3 standard delay, low resistance: therm.1.4-1.8xIN; magn. 6-12xIN AC; 7.8-15.6xIN DC Intermediate position H without intermediate position (standard) Z with intermediate position Auxiliary contacts 0 without auxiliary contacts 1 with auxiliary contacts in all poles 2 with auxiliary contacts in pole 1 (only multipole devices) 3 with auxiliary contacts in poles 1 and 3 (≥ 3-pole devices) Auxiliary contact function (see diagram) 1 one each N/C and N/O (standard) 2 one N/O contact (23/24) 3 one N/C contact (11/12) 4 one N/C contact, closed in the intermediate and ON position (-Z only) Auxiliary contact - terminal design 1 same as main terminals Current ratings 0.1...25 A 2 Technical data For further details please see chapter: Technical Information Voltage rating AC 250 V*; 3 AC 433 V (50-60Hz); DC 65 V (*UL: AC 277/480 V; DC 65 V) Current rating range 0.1...25 A for curves M1, T1, T2 0.1...16 A for curves F1, F2, M3 Auxiliary circuit 1 A, AC 240 V/DC 65 V, resistive Typical life 10,000 operations at 1 x IN, inductive Ambient temperature -30...+60 °C (-22...+140 °F) T 60 Insulation co-ordination rated impulse pollution (IEC 60664 and 60664A) withstand voltage degree 2.5 kV 2 reinforced insulation in operating area Dielectric strength (IEC 60664 and 60664A) test voltage operating area AC 3,000 V main/aux. circuit AC 1,500 V aux. circuit 11-12/23-24 AC 1,000 V pole/pole AC 1,500 V Insulation resistance > 100 MΩ (DC 500 V) 0.1...5 A 400 A Interrupting capacity Icn 6...25 A 800 A curves F1, F2, M1, T1: 0.1...16 A 2,500A (at DC 32 V) curve T2 : 0.1...25 A 15 x IN curve M3: 0.1...2 A AC 200 A DC 400 A Interrupting capacity 0.1...16 A 20...25 A (UL 1077) IN AC 277 V 1-pole 5,000 A 2,000 A AC 277/480 V 2-/3-pole 5,000 A 2,000 A DC 65 V 2,000 A 2,000 A Degree of protection operating area IP30 (IEC 60529/DIN 40050) terminal area IP00 Vibration curve F1: 3 g (57-500 Hz), ± 0.23 mm (10-57 Hz) curves M1, M3, T1, T2: 5 g (57-500 Hz), ± 0.38 mm (10-57 Hz) to IEC 60068-2-6, test Fc 10 frequency cycles/axis Shock curve F1: 25 g (11 ms), directions 1, 2, 3, 4, 5 10 g (11 ms), direction 6 curves M1, M3, T1, T2: 25 g (11 ms), directions 1, 2, 3, 4, 5 20 g (11 ms), direction 6 to IEC 60068-2-27, test Ea Corrosion 96 hours in 5 % salt mist to IEC 60068-2-11, test Ka Humidity 240 hours at 95 % RH to IEC 60068-2-78, test Cab Mass approx. 50 g per pole 2210 - S 2 1 0 - P1 F1 - H 1 1 1 - 10 A ordering example Remote trip coil available to special order. Issue C (260111) www.e-t-a.com 2 - 11 Thermal-Magnetic Circuit Breaker 2210-S2.. Current Internal resistance (Ω) rating F1 F2 M1 T1 M3 T2 (A) delayed standard delay thermal for AC + DC for AC + DC 42 11.7 5.6 2.9 1.75 1.42 0.75 0.5 0.22 0.136 0.083 0.057 0.041 0.032 0.021 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 - 77 23 10.2 5.7 3.7 2.6 1.39 0.9 0.36 0.19 0.141 0.091 0.051 0.040 0.027 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 ON 1 .039 OFF 43 1.69 3.5 .138 25 .984 12.5 .492 11.5 .453 24 12 2 10 .394 1 11 23 37.5 1.48 68 2.68 19 .748 6.8 .268 polarizing tooth 12.5 12.5 .492 .492 6x6.8 = 40.8 6x.268 = 1.61 blade terminals DIN 46244-A6.3-0.8 (QC .250) 50 1.97 32 1.26 unit III unit II unit I mounting thread M3 or 6/32 max. screw length 5.8 mm (.228 in.) tightening torque max. 0.5 Nm ø11 .433 12 .472 5.5 .217 0 81 24.2 10.4 6.0 3.9 2.7 1.53 0.98 0.42 0.24 0.17 0.12 0.073 0.055 0.039 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 2A M1 92 26.1 11.6 6,6 4,1 3 1.65 1,10 0.47 0.28 0.183 0.124 0.077 0.063 0.045 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 2A M1 162 39.3 17.5 9.2 6.8 4.2 2.8 1.6 0.78 0.42 0,26 0.18 0.12 0.092 0.054 0.025 0.02 ≤ 0.02 ≤ 0.02 - 2A M1 162 39.3 17.5 9.2 6.8 4.2 2.8 1.6 0.78 0.42 0.26 0.18 0.12 0.092 0.054 0.025 0.022 ≤ 0.02 ≤ 0.02 - multipole devices 16 .630 Approvals Current ratings Cut-out dimensions 0.1...25 A 32 1.26 3-pole 2-pole 1-pole 16 .630 ø11.5 .453 OFF position intermediate position ON position 12.5 12.5 .492 .492 1.5 .059 Toggle positions 90° s ø4 0.1...25 A 57 UL, CSA Voltage ratings AC 250 V; DC 65 V; 3 AC 433 V AC 277 V; DC 65 V; AC 277/480 V .1 Authority GL, VDE (EN 60934) 36.6 1.44 24 .945 recess with panel thickness s > 1.5 mm (.059 in.) ø11.5 .453 Shock directions Installation drawing operating area (reinforced insulation) 3 5 6 4 1 current rating 1 11 23 24 12 2 20 .787 2 5 .197 2 0.1 0.2 0.3 0.4 0.5 0.6 0.8 1 1.5 2 2.5 3 4 5 6 8 10 12 16 20 25 30.5 1.20 18 .709 low resistance for AC + DC for AC + DC nur für AC 0 for DC only Z 25° 25° 0 fast acting fast acting standard delay Dimensions 10.5 .413 Standard current ratings and typical internal resistance values mounting area (standard insulation) This is a metric design and millimeter dimensions take precedence ( mm ) inch 2 - 12 www.e-t-a.com Issue C (260111) Thermal-Magnetic Circuit Breaker 2210-S2.. Internal connection diagrams Typical time/current characteristics with auxiliary contact function 1 (one each N/O and N/C) (...-H111-...) without intermediate position (...-Z111-...) with intermediate position (Z) I line 1 11 12 23 line 1 (Z) 0 I 12 24 I> 2 OFF position 11 23 (Z) 0 I DC only 10000 1000 line 1 11 23 12 24 I> I> 2 Intermediate position 2 ON position Trip time in seconds 0 -F1 0.1…16 A 24 100 10 1 0.1 with auxiliary contact function 4 (1 N/O, leading) 0 (Z) I line 1 23 0 (Z) I line 1 23 0 (Z) line I 1 2 0.01 23 0.001 1 24 24 2 24 4 6 8 10 20 406080100 … times rated current -F2 0.1…7.5 A I> 2 Intermediate position AC/ DC1) I> 10000 2 ON position 1000 Trip time in seconds 2 OFF position I> 100 10 1 0.1 0.01 0.001 1 2 4 6 8 10 20 406080100 … times rated current -F2 8…16 A AC/ DC1) 10000 Trip time in seconds 1000 100 10 1 0.1 0.01 The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section Technical information. 0.001 1 Ambient temperature °F -22 -4 +14 +32 +73.4 +86 +104 +122 +140 °C -30 -20 -10 0 +23 +30 +40 +50 +60 Derating factor 0.76 0.79 0.83 0.88 1 1.04 1.11 1.19 1.29 Multipole devices: all poles symmetrically loaded. With single pole overload, thermal tripping will be at max. 1.7 x IN with curves F1, F2, M1 and T2, and at max. 2.2 x IN with curve M3. Issue C (260111) +60 °C +140 °F 1) 2 4 6 8 10 20 40 6080100 … times rated current +23 °C +73.4 °F -30 °C -22 °F Magnetic tripping currents are increased by 30% on DC supplies. www.e-t-a.com 2 - 13 Thermal-Magnetic Circuit Breaker 2210-S2.. Typical time/current characteristics The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section Technical information. Multi pole devices: all poles symmetrically loaded. With single pole overload, thermal tripping will be at max. 1.7 x IN with curves F1, F2, M1 and T2, and at max. 2.2 x IN with curve M3. 1) Ambient temperature °F -22 -4 +14 +32 +73.4 +86 +104 +122 +140 °C -30 -20 -10 0 +23 +30 +40 +50 +60 Derating factor 0.76 0.79 0.83 0.88 1 1.04 1.11 1.19 1.29 -M1 0.1…6 A -M1 8…32 A 1) AC/DC 1) -T1 0.1…6 A 1000 1000 1000 100 10 1 Trip time in seconds 10000 Trip time in seconds 10000 Trip time in seconds 10000 100 10 1 10 1 0.1 0.1 0.01 0.01 0.01 0.001 1 2 0.001 4 6 8 10 20 40 6080100 … times rated current -T1 8...32 A 1 2 4 6 8 10 20 40 6080100 … times rated current -M3 0.1…5 A AC only AC/DC1) 0.001 1000 1000 10 1 Trip time in seconds 1000 Trip time in seconds 10000 Trip time in seconds 10000 100 10 1 0.01 0.01 0.01 -T2 0.1…6 A 1 AC/DC 2 -T2 8…32 A 4 6 8 10 20 40 6080100 … times rated current 1 2 4 6 8 10 20 40 6080100 … times rated current AC/DC 10000 10000 1000 Trip time in seconds 1000 100 10 1 100 10 1 0.1 0.1 0.01 0.01 0.001 1 2 0.001 4 6 8 10 20 40 6080100 … times rated current +60 °C +140 °F 2 - 14 0.001 0.001 4 6 8 10 20 40 6080100 … times rated current AC/DC1) 1 0.1 2 4 6 8 10 20 40 6080100 … times rated current 10 0.1 1 2 100 0.1 0.001 1 -M3 6...16 A 10000 100 AC only 100 0.1 Trip time in seconds 2 AC/DC Magnetic tripping currents are increased by 30% on DC supplies (curves M1, M3, T1). +23 °C +73.4 °F 1 2 4 6 8 10 20 40 6080100 … times rated current -30 °C -22 °F www.e-t-a.com Issue C (260111) Thermal-Magnetic Circuit Breaker 2210-S2.. Accessories slot for fitting labels from Phoenix, Weidmüller, Wieland Single mounting sockets (with adapter) (up to 16 A max. load) 17-P10-Si 17-P10-Si-20025 17-P70-Si 17-P70-Si-20025 (retaining clip Y 302 974 21 available on request) blade terminal DIN 46244 part 2 C profile (2xA2.8-0.8) (QC 2x.110) polarized blade terminal DIN 46244-A6.3-0.8 (QC .250) 115 4.53 symmetrical rail EN 50022-35x7.5 11 23 2(i) 11 14 14 10 .394 G-profile EN 50035-G32 Bus bar 50 A (6-way) for type 17-P10-Si socket X 221 760 01 71 ± 1.5 2.79 ± .060 25 .984 4.4 .173 6 .236 retaining clip 10 .394 2 .079 12.5 .492 Outer dimensions of female connectors to 6.3-1 DIN 46247 Ms-gal Sn max. 16 A busbar max. 50 A Bus bar (10-way) (supplied as a complete package) for type 17 socket (for max. 100 A continuous load), e positions available on request mor X 211 157 01 with terminal X 211 157 02 without terminal Phoenix terminal AKG 35 max.cross section 35 mm2 (AWG 2) max. 30 max. 1.18 cylinder head screw washer M4x4 ISO1207 A 4.3 DIN 125 nickel plated nickel plated Bus bar 50 A, 6-way, for type 63-P10-Si socket X 221 760 11 12.5 .492 10 .394 33.2 1.31 .315 7 .276 Outer dimensions of female connectors to 6.3-1 DIN 46247 Ms-gal Sn max. 16 A 12.8 .504 pressure-relief joint (1.1 mm (.043 in.) thick constriction) 154.8 6.09 Insulating sleeving for bus bar (10-way) Y 303 824 01 9 .354 5.4 .213 125 4.92 17 .669 busbar max. 50 A female connector M4 Cu rail, tin-plated blade terminal DIN 46244 A6.3-0.8 (QC .250), max. 25 A 8 71 ± 1.5 2.79 ± .060 25 .984 33.2 1.31 8 21 .827 insulation to DIN 4102-B2 translucent 2 .079 75 2.95 6 x .268 = 1.61 6.8 .268 50 1.97 57.4 2.26 6 x 6.8 = 40.8 50 1.97 3.5 .138 polarized recess 12.5 .492 blade terminal DIN 46244 A6.3-0.8 (QC .250), max. 25 A .315 12 2 12 2 1 Line 1 Line 11 left-side terminal block 22.2 polarized blade terminals 7.4 DIN 46244-A6.3-0.8 (QC .250) .874 .291 6.25 12.5 .246 .492 50 1.97 57.4 2.26 64 2.52 64 2.52 2(i) right-side terminal block 2-way 6-way mounting socket mounting socket 23-P10-Si 63-P10-Si (up to 16 A max. load) (retaining clip Y 302 974 01 available on request) insulation to DIN 4102-B2 translucent 23 symmetrical rail EN 50022-35x7.5 adapter X20040901 module 25 .984 11 12.5 .492 80 3.15 polarization recess 12.5 .492 2(k) 12 24 1 slot for busbar 4.4 .173 2 5 .197 41.3 1.63 2(k) 12 24 1 retaining clip 10 .394 1.4 .055 25 .984 33.3 1.31 25 .984 37 1.46 25.8 1.02 6 .236 G-profile EN 50035-G32 6.5 .256 63 2.48 depth 10 mm (.394 in.) 8.5 .335 57 2.24 47 1.85 42.5 1.67 17 plus 2.8 .110 6.3 .248 slot for fitting labels from Phoenix, Weidmüller 7.4 .291 -P70 10 .394 68 2.64 -P10 45.8 1.80 10.5 .413 Module 17plus For technical data see section Power distribution systems This is a metric design and millimeter dimensions take precedence ( mm ) inch Issue C (260111) www.e-t-a.com 2 - 15 Thermal-Magnetic Circuit Breaker 2210-S2.. Accessories Splash cover (transparent) with fixing plate and screws (IP54) for type 2210-S211-… (1-pole) X 211 117 02 mounting holes ø17+0,2 .669+.008 21 1.2 .047 fixing plate 19 .748 ~70 ~2.76 ø16.8 .661 39 1.54 Toggle guard for 1-pole units, black X 221 617 01 38 1.50 21 .827 max. 4 max .157 Splash cover (transparent) with fixing plate and screws (IP54) for type 2210-S221-… (2-pole) and type 2210-S231-… (3-pole) X 211 118 01 1.2 .047 22 .866 32 1.26 mounting dimensions: M3 - hole dia. 3.5 mm/.138 in. 5.5 .217 20 .787 38 1.50 32 1.26 32 1.26 ø3.5 .138 9.5 .374 2.5 .098 3.6 .142 24 .945 R .4 12 72 1 .039 R1 5 91 .5 12 .472 24.5 .965 fixing plate For front panel mounting. mounting hole 25+0.3 .984+.012 40 1.57 53 2.09 3pole .992±.004 .496±.004 3pole 25.2±0.1 32±0.1 1.26±.004 2pole 12.6±0.1 43 1.69 2 .827 31 1.22 100 quick-connect tabs 6.3 (.250) DIN 46247 tinned brass, insulated max. 2 max .079 Connector bus links -P10 X 210 588 01/ 1.5 mm2, (AWG 16), brown (up to 13 A max. load)2 X 210 588 02/ 2.5 mm2, (AWG 14), black (up to 20 A max. load) X 210 588 03/ 2.5 mm2, (AWG 14), red (up to 20 A max. load) X 210 588 04/ 2.5 mm2, (AWG 14), blue (up to 20 A max. load) This is a metric design and millimeter dimensions take precedence ( mm ) inch All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 2 - 16 www.e-t-a.com Issue C (260111)
2210-S222-P1T2-H0-4A 价格&库存
很抱歉,暂时无法提供与“2210-S222-P1T2-H0-4A”相匹配的价格&库存,您可以联系我们找货
