3500-F11-P10-SI-5A
3500-F11-P10-SI-5A
    E-T-A
    CIR BRKR THRM 5A
3500-F11-P10-SI-5A 数据手册
Thermal-Magnetic Circuit Breakers 3500/4000 Description Single pole thermal-magnetic circuit breaker with tease-free, trip-free, snap action mechanism and two button operation (M-type TM CBE to EN 60934). Featuring a flange for panel mounting, and optional auxiliary contacts and unprotected shunt tap terminal. Type 4000 offers lower internal resistance values and is fitted as standard with auxiliary contacts and an intermediate reset position in which all contacts are isolated. Approved to CBE standard EN 60934 (IEC 60934). Typical applications Control systems, instrumentation, medical equipment, machine tools, robotics, communications systems. Ordering information ordering example The exact part number required can be built up from the table of choices shown above. Ordering references for optional features should be omitted if not required. Standard current ratings and typical internal resistance values Current Internal resistance (Ω) ratings (A) 3500 4000 Current Internal resistance (Ω) ratings (A) 3500 4000 0.05 0.1 0.2 0.3 0.4 0.5 0.6 0.8 1 1.5 2 2.5 3 4 5 6 7 8 10 12 14 15 16 06/07 447 131 40 19.3 10.4 7.1 4.3 2.5 1.67 0.61 0.38 0.24 211 48 12.4 5.4 3.1 2.0 1.32 0.76 0.49 0.21 0.101 0.078 4000 standard type low-resistance type 2 Technical data Type No. 3500 standard version 4000 low resistance version Mounting (optional) F11 flange with additional M3 insertion nuts Terminal design P10 blade terminals 6.3-0.8 (QC .250), tinned K20 screw terminals M3.5x5.5 with clamp (not with -Si or type 4000) Shunt terminal (optional) A3 same as main terminals (up to IN = 7 A, max. load 5 A) Auxiliary contacts (optional with type 3500) Si auxiliary contacts, silver plated terminals one each N/O and N/C ZR-Si auxiliary contacts with intermediate position (standard with type 4000) Current ratings 0.05...16 A (type 3500) 0.05...10 A (type 4000) 3500 - .. - P10 - A3 - Si - 10 A 3500 0.19 0.090 0.061 0.041 0.034 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 0.054 0.035 0.025 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 For further details please see chapter: Technical Information Voltage rating AC 240 V, 50/60 Hz; DC 65 V (UL: AC 250 V; DC 80 V) Current rating range 3500: 0.05...16 A 4000: 0.05...10 A Auxiliary circuit 1 A, AC 240 V / DC 65 V Typical life 5,000 operations at 1 x IN, inductive 5,000 operations at 2 x IN, resistive Ambient temperature -30...+60 °C (-22...+140 °F) Insulation co-ordination rated impulse pollution (IEC 60664 and 60664 A) withstand voltage degree 2.5 kV 2 reinforced insulation in operating area Dielectric strength (IEC 60664 and 60664A) test voltage operating area AC 3,000 V main/aux. circuit AC 1,500 V aux. circuit 4-5/6-7 AC 840 V Insulation resistance > 100 MΩ (DC 500 V) Interrupting capacity Icn 3500 4000 0.05...0.8 A 0.05...0.2 A self-limiting 1...2 A 0.3...2 A 200 A 2.5...16 A 2.5...10 A 400 A Interrupting capacity IN UN (UL 1077) 0.05...16 A AC 250 V 1,000 A type 3500: 0.05...16 A DC 80 V 1,000 A Degree of protection operating area IP40 (IEC 60529/DIN 40050) terminal area IP00 Vibration 5 g (57-500 Hz), ±0.38 mm (10-57 Hz) to IEC 60068-2-6, test Fc 10 frequency cycles/axis Shock 25 g (11 ms) to IEC 60068-2-27, test Ea Corrosion 96 hours at 5 % salt mist to IEC 60068-2-11, test Ka Humidity 240 hours at 95 % RH to IEC 60068-2-3, test Ca Mass approx. 40 g Approvals Authority 3500: VDE (EN 60934) CSA, UL 4000: VDE (EN 60934) CSA www.e-t-a.com Voltage ratings Current ratings AC 240 V; DC 65 V AC 250 V; DC 80 V 0.05...16 A 0.05...16 A AC 240 V; DC 65 V AC 250 V 0.05...10 A 0.05...10 A 2 - 51 Thermal-Magnetic Circuit Breakers 3500/4000 Dimensions Internal connection diagrams with shunt terminal (-A3) and auxiliary contacts (-Si) 4 .157 line 1 6.3 .248 46.5 1.83 2.5 .098 3 11 .433 2 current rating in A 11.5 .453 50 1.97 blade terminals DIN 46244-A6.3-0.8 (QC .250) I> I> 2 2 line 1 3 M3 insertion nuts (-F11) I> 5 5 7 4 6 3 (from IN=8 A) 4 6 line 1 3 Installation drawing I> 3 (from IN=8 A) 2 OFF position ø3.5 .138 58 2.28 7 Switching position with intermediate position and auxiliary contacts (-ZR-Si) 42 1.65 29 1.14 20 .787 5 4.5 .177 11 line 1 .433 ø8.5 .335 4.5 .177 OFF 15.5 .610 9.5 .374 ON Version -P10 5 7 4 6 3 (from IN=8 A) 2 intermediate position line 1 3 I> 5 7 4 6 3 (from IN=8 A) 2 ON position Terminal design -P10-A3 operating area (reinforced insulation) 1 3 2 8 .315 7 .276 max. 2.5 max .098 7 .276 -P10-Si 1 .039 1 46 2 1 46 2 -P10-A3-Si mounting area -K20 5 .197 1.5 .059 9 .354 1 2 M3.5x5.5 ISO 1207 tightening torque max. 0.8 Nm This is a metric design and millimeter dimensions take precedence ( mm ) inch 2 - 52 www.e-t-a.com 06/07 Thermal-Magnetic Circuit Breakers 3500/4000 Typical time/current characteristics 3500 0.05 … 7 A AC 1) 3500 8 … 16 A 1000 1000 100 100 100 10 1 Trip time in seconds 1000 Trip time in seconds 10000 Trip time in seconds 10000 10 1 0.1 0.01 0.01 0.01 0.001 +60 °C +140 °F 4 6 8 10 20 40 60 80 100 … times rated current +23 °C +73.4 °F 2 1 0.1 2 DC 2) 10 0.1 1 2) 4000 0.05 … 10 A 10000 0.001 1) AC 1) 0.001 1 2 4 6 8 10 20 40 60 80 100 … times rated current 1 2 4 6 8 10 20 40 60 80100 … times rated current -30 °C -22 °F Magnetic tripping currents are increased by 20% on DC supplies. Magnetic tripping currents are decreased by 20% on AC supplies. The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section 9 – Technical information. Ambient temperature °F -22 -4 +14 +32 +73.4 +104 +122 +140 °C -30 -20 -10 0 +23 +40 +50 +60 Derating factor 0.76 0.79 0.83 0.88 1 1.08 1.16 1.24 All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 06/07 www.e-t-a.com 2 - 53 Thermal-Magnetic Circuit Breakers 3500/4000 Special version 3500-...-2100 Special version 3500-...-2350 Single pole thermal-magnetic overcurrent circuit breaker with slow magnetic trip curve, suitable for high inrush currents (up to 12 x IN). Suffix -2100 is also available for types 3400 and 3600. Enquire for further details. Typical applications Typical applications Industrial control systems, telecommunications, etc. Industrial control systems. Standard current ratings and typical internal resistance values Current rating (A) 0.06 0.1 0.2 0.3 0.4 0.5 0.6 0.8 1 1.5 2 2.5 Internal resistance (Ω) 292 165 41.7 19.7 12.1 7.9 5.5 2.6 1.88 0.77 0.42 0.24 Current rating (A) 3 4 5 6 7 8 10 12 14 15 16 Internal resistance (Ω) 0.18 0.11 0.067 0.052 0.035 0.031 0.022 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 Typical time/current characteristics at +23 °C Standard current ratings and typical internal resistance values Current rating (A) 0.05 0.1 0.2 0.3 0.4 0.5 0.8 1 1.5 2 Internal resistance (Ω) 583 167 49.9 23.1 12.8 8.7 3.45 2.3 0.89 0.48 1000 1000 100 100 Trip time in seconds 10000 10 1 +80 °C +176 °F +23 °C +73.4 °F 10 1 0.1 0.1 0.01 0.01 0.001 1 2 4 6 8 10 20 40 60 80 100 … times rated current 1 Magnetic tripping currents are increased by 20% on DC supplies. 2 - 54 Internal resistance (Ω) 0.42 0.21 0.13 0.11 0.056 0.022 ≤ 0.02 ≤ 0.02 ≤ 0.02 AC/DC 1) 10000 0.001 1) Current rating (A) 2.5 3 4 5 6 10 12 15 16 Typical time/current characteristics AC/DC 1) Trip time in seconds 2 Single pole thermal-magnetic circuit breaker suitable for high ambient temperatures. The special rating of the circuit breaker allows resetting at no load in ambient temperatures up to +80 °C. Suffix -2350 is also available for types 3400 and 3600. Enquire for further details. 1) 2 4 6 8 10 20 40 60 80 100 … times rated current Magnetic tripping currents are increased by 20% on DC supplies. www.e-t-a.com 06/07
3500-F11-P10-SI-5A 价格&库存
很抱歉,暂时无法提供与“3500-F11-P10-SI-5A”相匹配的价格&库存,您可以联系我们找货
